GCC version for RTEMS 6?
Tue May 24 22:29:50 UTC 2022
On 24/5/2022 5:01 pm, Sebastian Huber wrote:
> On 24/05/2022 08:43, Sebastian Huber wrote:
>> On 24/05/2022 02:32, Chris Johns wrote:
>>> On 6/5/2022 4:16 pm, Sebastian Huber wrote:
>>>>> - aarch64 bsps
>>>>> These BSPs generated lots of warnings in the testsuite due to this line:
>>>>> https://git.rtems.org/rtems/tree/bsps/aarch64/include/bsp/start.h#n175
>>>>> The warning is about comparing arrays. I have not looked deeper.
>>>> This can be fixed by using RTEMS_OBFUSCATE_VARIABLE().
>>> Sorry, I do not know how to use this macro to remove the warning?
>> For this macro you need a stack variable.
>> I guess the warning could be also removed using this compiler note:
>> rtems/bsps/aarch64/include/bsp/start.h:175:28: note: use
>> '&bsp_vector_table_end[0] != &bsp_vector_table_size[0]' to compare the addresses
I have done this and it is quieter now.
>> What is the purpose of AArch64_start_set_vector_base()? Do we need this at all
>> on the aarch64 target?
> Also why is this function exposed by <bsp.h>?
I do not know. I am only the messenger :)
Kinsey?
