[rtems-libbsd commit] Implement portable kernel symbol namespace tool
Sebastian Huber
Wed May 25 06:22:27 UTC 2022
On 02/09/2021 04:43, Chris Johns wrote:
> Module: rtems-libbsd
> Branch: 6-freebsd-12
> Commit: 59f652fe881de4a170d4916d148fe72f33e35ef2
> Changeset:http://git.rtems.org/rtems-libbsd/commit/?id=59f652fe881de4a170d4916d148fe72f33e35ef2
> Author: Chris Johns<chrisj at rtems.org>
> Date: Tue Jul 27 17:39:20 2021 +1000
> - The script's use of sort proved to not be portable
> - No need to check the commits as symbols are only added
> - Regenerated kernel header to reset the sort order
> Update #4475
While converting the libbsd.txt in the 6-freebsd-12 branch I noticed
that this tool is not present on the master branch. If we ever want to
update libbsd from FreeBSD 12 to a newer version, it is important that
everything is available in the 6-freebsd-12 and master branches.
I do currently some preparations to make an update of the 6-freebsd-12
branch. The last update was:
commit 46b3858b27d78e14a220f8d251fd7ab28a5244f4
Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
Date: Mon Feb 10 15:34:55 2020 +0100
Update to FreeBSD stable/12 2020-02-10
Git mirror commit 0d1c391321b34b3025cf0e72f2231d836ff76da8.
This update will cover more than two years of FreeBSD development. Also
FreeBSD switched from SVN to Git in the mean time.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
