[rtems-libbsd commit] Implement portable kernel symbol namespace tool
    Chris Johns
    chrisj at rtems.org
    Wed May 25 07:03:44 UTC 2022
On 25/5/2022 4:22 pm, Sebastian Huber wrote:
> On 02/09/2021 04:43, Chris Johns wrote:
>> Module:    rtems-libbsd
>> Branch:    6-freebsd-12
>> Commit:    59f652fe881de4a170d4916d148fe72f33e35ef2
>> Changeset:http://git.rtems.org/rtems-libbsd/commit/?id=59f652fe881de4a170d4916d148fe72f33e35ef2
>> Author:    Chris Johns<chrisj at rtems.org>
>> Date:      Tue Jul 27 17:39:20 2021 +1000
>> - The script's use of sort proved to not be portable
>> - No need to check the commits as symbols are only added
>> - Regenerated kernel header to reset the sort order
>> Update #4475
> While converting the libbsd.txt in the 6-freebsd-12 branch I noticed that this
> tool is not present on the master branch. If we ever want to update libbsd from
> FreeBSD 12 to a newer version, it is important that everything is available in
> the 6-freebsd-12 and master branches.
Yes. This will need to be brought across to master then the changes come across.
It can move at anytime.
> I do currently some preparations to make an update of the 6-freebsd-12 branch.
> The last update was:
> commit 46b3858b27d78e14a220f8d251fd7ab28a5244f4
> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date:   Mon Feb 10 15:34:55 2020 +0100
>     Update to FreeBSD stable/12 2020-02-10
>     Git mirror commit 0d1c391321b34b3025cf0e72f2231d836ff76da8.
> This update will cover more than two years of FreeBSD development. Also FreeBSD
> switched from SVN to Git in the mean time.
Thanks. FYI I get an SSL cert error on the https FreeBSD git repo and so I have
had to switched to github.
