[PATCH] MAINTAINERS: Add myself to Write After Approval
Karel Gardas karel at functional.vision
Thu May 26 19:14:55 UTC 2022
On 5/26/22 20:49, Joel Sherrill wrote:
> This looks good to me.
Thanks!
> Try and commit it so we can see if everything works. :)
push looks fine except error on buildbot. Is that expected?
$ git push
Enumerating objects: 5, done.
Counting objects: 100% (5/5), done.
Delta compression using up to 12 threads
Compressing objects: 100% (3/3), done.
Writing objects: 100% (3/3), 415 bytes | 415.00 KiB/s, done.
Total 3 (delta 2), reused 0 (delta 0)
remote: 0: init
remote: 1: mail vc at rtems.org
remote: Warning: Permanently added 'devel.int.rtems.org' (ECDSA) to the
list of known hosts.
remote: 4: IRC
remote: 5: Buildbot
remote: git_buildbot: ERROR: Could not connect to
buildbot.int.rtems.org:9899: Connection was refused by other side: 61:
Connection refused.
To ssh://dispatch.rtems.org/data/git/rtems.git
    495f8363de..f91f30f69a  master -> master
rtems at silence:~/git/rtems/ssh-rtems$
Karel
> --joel
> On Thu, May 26, 2022 at 1:42 PM Karel Gardas <karel at functional.vision>
> wrote:
>     Add myself also to Localized Write Permission for x86_64.
>       MAINTAINERS | 3 ++-
>       1 file changed, 2 insertions(+), 1 deletion(-)
>     diff --git a/MAINTAINERS b/MAINTAINERS
>     index 446bec7d19..2c997cb58d 100644
>     --- a/MAINTAINERS
>     +++ b/MAINTAINERS
>     @@ -55,6 +55,7 @@ Christian Mauderer
>     christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>
>       Hesham Almatary heshamelmatary at gmail.com
>     <mailto:heshamelmatary at gmail.com>
>       Vijay Kumar Banerjee vijay at rtems.org <mailto:vijay at rtems.org>
>       Jan Sommer jan at rtems.org <mailto:jan at rtems.org>
>     +Karel Gardas               karel at functional.vision
>     @@ -62,7 +63,7 @@ sparc                      Daniel Hellstrom
>     (daniel at gaisler.com <mailto:daniel at gaisler.com>)
>       beagle                     Ben Gras (beng at rtems.org
>     <mailto:beng at rtems.org>)
>       tms570                     Pavel Pisa (pisa at cmp.felk.cvut.cz
>     <mailto:pisa at cmp.felk.cvut.cz>)
>       raspberrypi                Pavel Pisa (pisa at cmp.felk.cvut.cz
>     -x86_64                     TBD
>     +x86_64                     Karel Gardas (karel at functional.vision)
>       beagle                     Vijay Kumar Banerjee (vijay at rtems.org
>     <mailto:vijay at rtems.org>)
>       Emeritus Maintainers
>     2.25.1
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
>     <http://lists.rtems.org/mailman/listinfo/devel>
