[PATCH] MAINTAINERS: Add myself to Write After Approval
Joel Sherrill
joel at rtems.org
Thu May 26 19:27:39 UTC 2022
On Thu, May 26, 2022, 2:14 PM Karel Gardas <karel at functional.vision> wrote:
> On 5/26/22 20:49, Joel Sherrill wrote:
> > This looks good to me.
> Thanks!
> > Try and commit it so we can see if everything works. :)
> push looks fine except error on buildbot. Is that expected?
Unfortunately I think buildbot isn't back up after the recent round of
updates.
> $ git push
> Enumerating objects: 5, done.
> Counting objects: 100% (5/5), done.
> Delta compression using up to 12 threads
> Compressing objects: 100% (3/3), done.
> Writing objects: 100% (3/3), 415 bytes | 415.00 KiB/s, done.
> Total 3 (delta 2), reused 0 (delta 0)
> remote: 0: init
> remote: 1: mail vc at rtems.org
> remote: Warning: Permanently added 'devel.int.rtems.org' (ECDSA) to the
> list of known hosts.
> remote: 4: IRC
> remote: 5: Buildbot
> remote: git_buildbot: ERROR: Could not connect to
> buildbot.int.rtems.org:9899: Connection was refused by other side: 61:
> Connection refused.
> To ssh://dispatch.rtems.org/data/git/rtems.git
> 495f8363de..f91f30f69a master -> master
> rtems at silence:~/git/rtems/ssh-rtems$
> Karel
> > --joel
> > On Thu, May 26, 2022 at 1:42 PM Karel Gardas <karel at functional.vision>
> > wrote:
> > Add myself also to Localized Write Permission for x86_64.
> > MAINTAINERS | 3 ++-
> > 1 file changed, 2 insertions(+), 1 deletion(-)
> > diff --git a/MAINTAINERS b/MAINTAINERS
> > index 446bec7d19..2c997cb58d 100644
> > --- a/MAINTAINERS
> > +++ b/MAINTAINERS
> > @@ -55,6 +55,7 @@ Christian Mauderer
> > christian.mauderer at embedded-brains.de
> > <mailto:christian.mauderer at embedded-brains.de>
> > Hesham Almatary heshamelmatary at gmail.com
> > <mailto:heshamelmatary at gmail.com>
> > Vijay Kumar Banerjee vijay at rtems.org <mailto:vijay at rtems.org>
> > Jan Sommer jan at rtems.org <mailto:jan at rtems.org>
> > +Karel Gardas karel at functional.vision
> > @@ -62,7 +63,7 @@ sparc Daniel Hellstrom
> > (daniel at gaisler.com <mailto:daniel at gaisler.com>)
> > beagle Ben Gras (beng at rtems.org
> > <mailto:beng at rtems.org>)
> > tms570 Pavel Pisa (pisa at cmp.felk.cvut.cz
> > <mailto:pisa at cmp.felk.cvut.cz>)
> > raspberrypi Pavel Pisa (pisa at cmp.felk.cvut.cz
> > -x86_64 TBD
> > +x86_64 Karel Gardas (karel at functional.vision)
> > beagle Vijay Kumar Banerjee (vijay at rtems.org
> > <mailto:vijay at rtems.org>)
> > Emeritus Maintainers
> > 2.25.1
> > devel mailing list
> > devel at rtems.org <mailto:devel at rtems.org>
> > <http://lists.rtems.org/mailman/listinfo/devel>
