[PATCH] MAINTAINERS: Add myself to Write After Approval
Joel Sherrill
joel at rtems.org
Thu May 26 22:06:27 UTC 2022
On Thu, May 26, 2022, 4:52 PM Chris Johns <chrisj at rtems.org> wrote:
> I did not see a message in the vc list?
Does that mean Karel needs to be on a white list or subscribed to sen
--joel
> Chris
> On 27/5/2022 5:14 am, Karel Gardas wrote:
> > On 5/26/22 20:49, Joel Sherrill wrote:
> >> This looks good to me.
> > Thanks!
> >> Try and commit it so we can see if everything works. :)
> > push looks fine except error on buildbot. Is that expected?
> > $ git push
> > Enumerating objects: 5, done.
> > Counting objects: 100% (5/5), done.
> > Delta compression using up to 12 threads
> > Compressing objects: 100% (3/3), done.
> > Writing objects: 100% (3/3), 415 bytes | 415.00 KiB/s, done.
> > Total 3 (delta 2), reused 0 (delta 0)
> > remote: 0: init
> > remote: 1: mail vc at rtems.org
> > remote: Warning: Permanently added 'devel.int.rtems.org' (ECDSA) to the
> list of
> > known hosts.
> > remote: 4: IRC
> > remote: 5: Buildbot
> > remote: git_buildbot: ERROR: Could not connect to
> buildbot.int.rtems.org:9899:
> > Connection was refused by other side: 61: Connection refused.
> > To ssh://dispatch.rtems.org/data/git/rtems.git
> > 495f8363de..f91f30f69a master -> master
> > rtems at silence:~/git/rtems/ssh-rtems$
> > Karel
> >> --joel
> >> On Thu, May 26, 2022 at 1:42 PM Karel Gardas <karel at functional.vision>
> wrote:
> >> Add myself also to Localized Write Permission for x86_64.
> >> MAINTAINERS | 3 ++-
> >> 1 file changed, 2 insertions(+), 1 deletion(-)
> >> diff --git a/MAINTAINERS b/MAINTAINERS
> >> index 446bec7d19..2c997cb58d 100644
> >> --- a/MAINTAINERS
> >> +++ b/MAINTAINERS
> >> @@ -55,6 +55,7 @@ Christian Mauderer
> >> christian.mauderer at embedded-brains.de
> >> <mailto:christian.mauderer at embedded-brains.de>
> >> Hesham Almatary heshamelmatary at gmail.com
> >> <mailto:heshamelmatary at gmail.com>
> >> Vijay Kumar Banerjee vijay at rtems.org <mailto:vijay at rtems.org>
> >> Jan Sommer jan at rtems.org <mailto:jan at rtems.org>
> >> +Karel Gardas karel at functional.vision
> >> @@ -62,7 +63,7 @@ sparc Daniel Hellstrom
> >> (daniel at gaisler.com <mailto:daniel at gaisler.com>)
> >> beagle Ben Gras (beng at rtems.org
> >> <mailto:beng at rtems.org>)
> >> tms570 Pavel Pisa (pisa at cmp.felk.cvut.cz
> >> <mailto:pisa at cmp.felk.cvut.cz>)
> >> raspberrypi Pavel Pisa (pisa at cmp.felk.cvut.cz
> >> -x86_64 TBD
> >> +x86_64 Karel Gardas (karel at functional.vision)
> >> beagle Vijay Kumar Banerjee (vijay at rtems.org
> >> <mailto:vijay at rtems.org>)
> >> Emeritus Maintainers
> >> -- 2.25.1
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org <mailto:devel at rtems.org>
> >> http://lists.rtems.org/mailman/listinfo/devel
> >> <http://lists.rtems.org/mailman/listinfo/devel>
> > devel mailing list
> > devel at rtems.org
