[PATCH] MAINTAINERS: Add myself to Write After Approval
Thu May 26 21:51:49 UTC 2022
I did not see a message in the vc list?
On 27/5/2022 5:14 am, Karel Gardas wrote:
> On 5/26/22 20:49, Joel Sherrill wrote:
>> This looks good to me.
> Thanks!
>> Try and commit it so we can see if everything works. :)
> push looks fine except error on buildbot. Is that expected?
> $ git push
> Enumerating objects: 5, done.
> Counting objects: 100% (5/5), done.
> Delta compression using up to 12 threads
> Compressing objects: 100% (3/3), done.
> Writing objects: 100% (3/3), 415 bytes | 415.00 KiB/s, done.
> Total 3 (delta 2), reused 0 (delta 0)
> remote: 0: init
> remote: 1: mail vc at rtems.org
> remote: Warning: Permanently added 'devel.int.rtems.org' (ECDSA) to the list of
> known hosts.
> remote: 4: IRC
> remote: 5: Buildbot
> remote: git_buildbot: ERROR: Could not connect to buildbot.int.rtems.org:9899:
> Connection was refused by other side: 61: Connection refused.
> To ssh://dispatch.rtems.org/data/git/rtems.git
>    495f8363de..f91f30f69a  master -> master
> rtems at silence:~/git/rtems/ssh-rtems$
> Karel
>> --joel
>> On Thu, May 26, 2022 at 1:42 PM Karel Gardas <karel at functional.vision> wrote:
>>     Add myself also to Localized Write Permission for x86_64.
>>       MAINTAINERS | 3 ++-
>>       1 file changed, 2 insertions(+), 1 deletion(-)
>>     diff --git a/MAINTAINERS b/MAINTAINERS
>>     index 446bec7d19..2c997cb58d 100644
>>     --- a/MAINTAINERS
>>     +++ b/MAINTAINERS
>>     @@ -55,6 +55,7 @@ Christian Mauderer
>>     christian.mauderer at embedded-brains.de
>>     <mailto:christian.mauderer at embedded-brains.de>
>>       Hesham Almatary heshamelmatary at gmail.com
>>     <mailto:heshamelmatary at gmail.com>
>>       Vijay Kumar Banerjee vijay at rtems.org <mailto:vijay at rtems.org>
>>       Jan Sommer jan at rtems.org <mailto:jan at rtems.org>
>>     +Karel Gardas               karel at functional.vision
>>     @@ -62,7 +63,7 @@ sparc                      Daniel Hellstrom
>>     (daniel at gaisler.com <mailto:daniel at gaisler.com>)
>>       beagle                     Ben Gras (beng at rtems.org
>>     <mailto:beng at rtems.org>)
>>       tms570                     Pavel Pisa (pisa at cmp.felk.cvut.cz
>>     <mailto:pisa at cmp.felk.cvut.cz>)
>>       raspberrypi                Pavel Pisa (pisa at cmp.felk.cvut.cz
>>     -x86_64                     TBD
>>     +x86_64                     Karel Gardas (karel at functional.vision)
>>       beagle                     Vijay Kumar Banerjee (vijay at rtems.org
>>     <mailto:vijay at rtems.org>)
>>       Emeritus Maintainers
>>     --     2.25.1
>>     _______________________________________________
>>     devel mailing list
>>     devel at rtems.org <mailto:devel at rtems.org>
>>     http://lists.rtems.org/mailman/listinfo/devel
>>     <http://lists.rtems.org/mailman/listinfo/devel>
> devel mailing list
> devel at rtems.org
