[PATCH 1/1] kern_tc.c: th_generation starts with 1 after overflow for single-core
Fri May 27 08:51:17 UTC 2022
Hello Gabriel,
the uniprocessor version uses an optimization at the reader side:
#if defined(RTEMS_SMP)
	} while (gen == 0 || gen != th->th_generation);
#else
	} while (gen != th->th_generation);
#endif
This is possible since the windup happens with interrupts disabled. I
guess you need this optimization somewhere in the PPS/NTP code.
Could you please add the details to the commit message and not the cover
letter. The cover letter is not committed.
Could you please have a look at:
https://lists.rtems.org/pipermail/devel/2022-May/071609.html
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
