Fwd: Identify 3rd party source in spec?
Gedare Bloom
gedare at rtems.org
Wed Nov 2 15:10:24 UTC 2022
On Wed, Nov 2, 2022 at 1:10 AM Christian MAUDERER
<christian.mauderer at embedded-brains.de> wrote:
> Hello Chris,
> Am 01.11.22 um 22:08 schrieb Chris Johns:
> > On 2/11/2022 3:25 am, oss at c-mauderer.de wrote:> Is it a good idea to make it a
> > mandatory attribute? It makes the yaml files
> >> bigger. It will only mean that we have to look for copy and paste bugs instead
> >> of missing attributes if someone adds a new third party library.
> > Can you avoid having to add the item to all? I am no spec build system expert
> > (having invested time) and seem to remember needing to hit a lot of files when
> > adding something ...
> > https://git.rtems.org/rtems/commit/?id=6f2aa8ad36e3aaffc9fa2cb8c744b04da7339ee2
> > Chris
> The documentation mentions at least some optional attributes in the
> specification files. For example "format" in a build option item or the
> "do-configure" in a build script item:
> https://docs.rtems.org/branches/master/eng/req/items.html#build-option-item-type
> https://docs.rtems.org/branches/master/eng/req/items.html#build-script-item-type
> But I think the wscript has to take into account that the value might
> not exist. I'm not sure whether it does that for the existing "optional"
> attributes. For example my first guess would be that the "do-configure"
> could throw a KeyError:
> https://git.rtems.org/rtems/tree/wscript#n1127
> def do_configure(self, conf, cic):
> script = self.data["do-configure"]
> if script:
> exec(script)
> Usually I would have expected the following code instead:
> try:
> except KeyError:
> script = None
> if script:
> exec(script)
Thanks for this recommendation and the discussion/example. Indeed, the
plumbing right now in the wscript is not very robust to optional
attributes. For this particular third-party attribute I will take a
stab at making it optional.
I think the additional metadata we would like to track regarding
third-party sources can be added incrementally or even separately. I
would like to first solve the problem of how to separate third-party
from project-owned sources. Once that is done, then we can discuss
more ways to improve or use this capability.
> So I can't clearly answer your question. I would have to try it. But
> regardless whether there are currently such options or not: They
> shouldn't be hard to implement. I just hope that this doesn't break some
> use case. I'll try to remember to ask Sebastian about it next week.
Thanks, I will appreciate that feedback and any tricky things to watch out for.
> Best regards
> Christian
> embedded brains GmbH
> Herr Christian MAUDERER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> phone: +49-89-18 94 741 - 18
> mobile: +49-176-152 206 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
