Fwd: Identify 3rd party source in spec?
Wed Nov 2 15:13:56 UTC 2022
On Wed, Nov 2, 2022 at 10:10 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Nov 2, 2022 at 1:10 AM Christian MAUDERER
> <christian.mauderer at embedded-brains.de> wrote:
> > Hello Chris,
> > Am 01.11.22 um 22:08 schrieb Chris Johns:
> > > On 2/11/2022 3:25 am, oss at c-mauderer.de wrote:> Is it a good idea to
> make it a
> > > mandatory attribute? It makes the yaml files
> > >> bigger. It will only mean that we have to look for copy and paste
> bugs instead
> > >> of missing attributes if someone adds a new third party library.
> > > Can you avoid having to add the item to all? I am no spec build system
> expert
> > > (having invested time) and seem to remember needing to hit a lot of
> files when
> > > adding something ...
> https://git.rtems.org/rtems/commit/?id=6f2aa8ad36e3aaffc9fa2cb8c744b04da7339ee2
> > > Chris
> > The documentation mentions at least some optional attributes in the
> > specification files. For example "format" in a build option item or the
> > "do-configure" in a build script item:
> https://docs.rtems.org/branches/master/eng/req/items.html#build-option-item-type
> https://docs.rtems.org/branches/master/eng/req/items.html#build-script-item-type
> > But I think the wscript has to take into account that the value might
> > not exist. I'm not sure whether it does that for the existing "optional"
> > attributes. For example my first guess would be that the "do-configure"
> > could throw a KeyError:
> > https://git.rtems.org/rtems/tree/wscript#n1127
> >      def do_configure(self, conf, cic):
> >          script = self.data["do-configure"]
> >          if script:
> >              exec(script)
> > Usually I would have expected the following code instead:
> >          try:
> >          except KeyError:
> >              script = None
> >          if script:
> >              exec(script)
> Thanks for this recommendation and the discussion/example. Indeed, the
> plumbing right now in the wscript is not very robust to optional
> attributes. For this particular third-party attribute I will take a
> stab at making it optional.
> I think the additional metadata we would like to track regarding
> third-party sources can be added incrementally or even separately. I
> would like to first solve the problem of how to separate third-party
> from project-owned sources. Once that is done, then we can discuss
> more ways to improve or use this capability.
Are you thinking of a more distinct placement of third party sources
in the source tree?  like a cpukit/thirdparty/... sub-tree?
> > So I can't clearly answer your question. I would have to try it. But
> > regardless whether there are currently such options or not: They
> > shouldn't be hard to implement. I just hope that this doesn't break some
> > use case. I'll try to remember to ask Sebastian about it next week.
> Thanks, I will appreciate that feedback and any tricky things to watch out
> for.
> > Best regards
> > Christian
> > embedded brains GmbH
> > Herr Christian MAUDERER
> > Dornierstr. 4
> > 82178 Puchheim
> > Germany
> > email:  christian.mauderer at embedded-brains.de
> > phone:  +49-89-18 94 741 - 18
> > mobile: +49-176-152 206 08
> > Registergericht: Amtsgericht München
> > Registernummer: HRB 157899
> > Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> > Unsere Datenschutzerklärung finden Sie hier:
> > https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221102/ebd6d9dc/attachment.htm>
