Fwd: Identify 3rd party source in spec?
Gedare Bloom
gedare at rtems.org
Wed Nov 2 15:20:41 UTC 2022
On Wed, Nov 2, 2022 at 9:14 AM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Nov 2, 2022 at 10:10 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Wed, Nov 2, 2022 at 1:10 AM Christian MAUDERER
>> <christian.mauderer at embedded-brains.de> wrote:
>> > Hello Chris,
>> > Am 01.11.22 um 22:08 schrieb Chris Johns:
>> > > On 2/11/2022 3:25 am, oss at c-mauderer.de wrote:> Is it a good idea to make it a
>> > > mandatory attribute? It makes the yaml files
>> > >> bigger. It will only mean that we have to look for copy and paste bugs instead
>> > >> of missing attributes if someone adds a new third party library.
>> > > Can you avoid having to add the item to all? I am no spec build system expert
>> > > (having invested time) and seem to remember needing to hit a lot of files when
>> > > adding something ...
>> > > https://git.rtems.org/rtems/commit/?id=6f2aa8ad36e3aaffc9fa2cb8c744b04da7339ee2
>> > > Chris
>> > The documentation mentions at least some optional attributes in the
>> > specification files. For example "format" in a build option item or the
>> > "do-configure" in a build script item:
>> > https://docs.rtems.org/branches/master/eng/req/items.html#build-option-item-type
>> > https://docs.rtems.org/branches/master/eng/req/items.html#build-script-item-type
>> > But I think the wscript has to take into account that the value might
>> > not exist. I'm not sure whether it does that for the existing "optional"
>> > attributes. For example my first guess would be that the "do-configure"
>> > could throw a KeyError:
>> > https://git.rtems.org/rtems/tree/wscript#n1127
>> > def do_configure(self, conf, cic):
>> > script = self.data["do-configure"]
>> > if script:
>> > exec(script)
>> > Usually I would have expected the following code instead:
>> > try:
>> > except KeyError:
>> > script = None
>> > if script:
>> > exec(script)
>> Thanks for this recommendation and the discussion/example. Indeed, the
>> plumbing right now in the wscript is not very robust to optional
>> attributes. For this particular third-party attribute I will take a
>> stab at making it optional.
>> I think the additional metadata we would like to track regarding
>> third-party sources can be added incrementally or even separately. I
>> would like to first solve the problem of how to separate third-party
>> from project-owned sources. Once that is done, then we can discuss
>> more ways to improve or use this capability.
> Are you thinking of a more distinct placement of third party sources
> in the source tree? like a cpukit/thirdparty/... sub-tree?
No. I would like to support 3rd party sources wherever they are best
found, and to keep track of them separately through the build system
since it already understands the various files/sources involved. I
think this makes the most sense for maintenance in the longer-term.
>> > So I can't clearly answer your question. I would have to try it. But
>> > regardless whether there are currently such options or not: They
>> > shouldn't be hard to implement. I just hope that this doesn't break some
>> > use case. I'll try to remember to ask Sebastian about it next week.
>> Thanks, I will appreciate that feedback and any tricky things to watch out for.
>> > Best regards
>> > Christian
>> > embedded brains GmbH
>> > Herr Christian MAUDERER
>> > Dornierstr. 4
>> > 82178 Puchheim
>> > Germany
>> > email: christian.mauderer at embedded-brains.de
>> > phone: +49-89-18 94 741 - 18
>> > mobile: +49-176-152 206 08
>> > Registergericht: Amtsgericht München
>> > Registernummer: HRB 157899
>> > Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> > Unsere Datenschutzerklärung finden Sie hier:
>> > https://embedded-brains.de/datenschutzerklaerung/
>> devel mailing list
>> devel at rtems.org
