Fwd: Identify 3rd party source in spec?
Fri Nov 4 08:59:16 UTC 2022
On 31/10/2022 20:01, Gedare Bloom wrote:
> I would like to float the idea of managing 3rd party source tracking
> through the build system spec files. I believe this would be the most
> efficient way to maintain this information, and we can leverage the
> existing build system code for tasks such as automatic format checks,
> generating lists of third-party code, etc.
> This will require refactoring some spec files to pull 3rd party code
> out to a separate .yml file that gets linked. Once that is done, then
> we could add another attribute for this tracking purpose. I would like
> to keep it simple as a boolean, maybe just "third-party: true/false"
> Attached is an example patch showing how this might work for the
> dtc/libfdt code as a build objects item type 'obj', and for zlib
> library as a build library item type 'lib' with some proof-of-concept
> code for generating a listing of third party source files.
In the future we could expand this third-party attribute to a dictionary
to provide more detailed information about the third-party sources, for
example the upstream Git repository, the import commit, path translation
mappings, post and pre import actions. This could be used to
automatically generate updates from upstream changes.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
