Fwd: Identify 3rd party source in spec?
Fri Nov 4 14:38:49 UTC 2022
On Fri, Nov 4, 2022 at 2:59 AM Sebastian Huber
> On 31/10/2022 20:01, Gedare Bloom wrote:
> > I would like to float the idea of managing 3rd party source tracking
> > through the build system spec files. I believe this would be the most
> > efficient way to maintain this information, and we can leverage the
> > existing build system code for tasks such as automatic format checks,
> > generating lists of third-party code, etc.
> > This will require refactoring some spec files to pull 3rd party code
> > out to a separate .yml file that gets linked. Once that is done, then
> > we could add another attribute for this tracking purpose. I would like
> > to keep it simple as a boolean, maybe just "third-party: true/false"
> > Attached is an example patch showing how this might work for the
> > dtc/libfdt code as a build objects item type 'obj', and for zlib
> > library as a build library item type 'lib' with some proof-of-concept
> > code for generating a listing of third party source files.
> In the future we could expand this third-party attribute to a dictionary
> to provide more detailed information about the third-party sources, for
> example the upstream Git repository, the import commit, path translation
> mappings, post and pre import actions. This could be used to
> automatically generate updates from upstream changes.
Nice. I don't see an explicit "dictionary" type for attributes, but I
do see that dict-like behavior could be achieved using a 'list' of
attributes nested below an attribute. I have the time allocated that i
could try to learn how to do this with a simple example, for example
to add a "upstream" and an "import-commit" field. Then, the
third-party indicator will change from
third-party: false   ->
    third-party: []
third-party: true    ->
     third-party:
         - upstream: URL
         - import-commit: git-sha
I would guess. Would this kind of structure "just work" in the current
support of spec/build or will it require some integration with
rtems-central?  Or, am I following the wrong ideas,
-Gedare
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
