bsp/riscv: Store/AMO address misaligned trap occured
Padmarao.Begari at microchip.com
Fri Nov 4 09:44:01 UTC 2022
Hi Sebastian,
> On Fri, 2022-11-04 at 08:07 +0100, Sebastian Huber wrote:
> On 03/11/2022 06:40, Padmarao.Begari at microchip.com wrote:
> > > On Wed, 2022-11-02 at 09:58 -0600, Gedare Bloom wrote:
> > > t0 contains the address of .Lsecondary_processor_go
> > > start.S has:
> > > ```asm
> > > #if __riscv_xlen == 32
> > > .align 2
> > > #elif __riscv_xlen == 64
> > > .align 3
> > > #endif
> > > .Lsecondary_processor_go:
> > > Can you confirm the value of __riscv_xlen is properly defined to
> > > 64
> > > for the PolarFire?
> > No, the value of __riscv_xlen is showing 32(config.log) instead of
> > 64
> > for PolarFire SoC and other 64-bit RISCV BSPs.
> This is a compiler built-in define. It doesn't matter what is in the
> config.log. What matters is that the compiler is invoked with the
> right
> options. In my build this looks all right.
> What is the value of t0 in
> amoswap.w zero, zero, 0(t0)
The "t0" value is 0x10000000ae
> Does it help to revert the commit?
Yes, removed ".option norelax" from start.S and it's working fine.
Regards
Padmarao
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
> Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
