bsp/riscv: Store/AMO address misaligned trap occured
Fri Nov 4 09:49:28 UTC 2022
On 04/11/2022 10:44, Padmarao.Begari at microchip.com wrote:
> Hi Sebastian,
>> On Fri, 2022-11-04 at 08:07 +0100, Sebastian Huber wrote:
>> On 03/11/2022 06:40,Padmarao.Begari at microchip.com  wrote:
>>>> On Wed, 2022-11-02 at 09:58 -0600, Gedare Bloom wrote:
>>>> t0 contains the address of .Lsecondary_processor_go
>>>> start.S has:
>>>> ```asm
>>>> #if __riscv_xlen == 32
>>>>     .align  2
>>>> #elif __riscv_xlen == 64
>>>>     .align  3
>>>> #endif
>>>> .Lsecondary_processor_go:
>>>> Can you confirm the value of __riscv_xlen is properly defined to
>>>> 64
>>>> for the PolarFire?
>>> No, the value of __riscv_xlen is showing 32(config.log) instead of
>>> 64
>>> for PolarFire SoC and other 64-bit RISCV BSPs.
>> This is a compiler built-in define.  It doesn't matter what is in the
>> config.log. What matters is that the compiler is invoked with the
>> right
>> options. In my build this looks all right.
>> What is the value of t0 in
>> amoswap.w zero, zero, 0(t0)
> The "t0" value is 0x10000000ae
Ok, is this the address of .Lsecondary_processor_go?
It is a value > 4GiB. I am not sure how such a value is loaded through
la or lla.
>> Does it help to revert the commit?
> Yes, removed ".option norelax" from start.S and it's working fine.
Ok, thanks for testing.
I guess we need a hand crafted instruction sequence to load absolute
addresses instead of using la or lla.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
