xz_crc64.c not compiled
Joel Sherrill
joel at rtems.org
Fri Nov 4 19:39:26 UTC 2022
On Fri, Nov 4, 2022, 2:37 PM Gedare Bloom <gedare at rtems.org> wrote:
> Hi all,
> I don't see an entry in spec/build anywhere for xz_crc64.c
> From what I can tell it is not compiled/tested. I guess the
> This leads me to believe it is not compiled. And therefore is not
> being called or tested anywhere.
> Should it be compiled, or should it be removed?
What about in 5 and the autotools build system?
--joel
> Gedare
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221104/a561fe8c/attachment.htm>
