xz_crc64.c not compiled
Fri Nov 4 19:46:35 UTC 2022
On Fri, Nov 4, 2022 at 1:39 PM Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Nov 4, 2022, 2:37 PM Gedare Bloom <gedare at rtems.org> wrote:
>> Hi all,
>> I don't see an entry in spec/build anywhere for xz_crc64.c
>> From what I can tell it is not compiled/tested. I guess the
>> This leads me to believe it is not compiled. And therefore is not
>> being called or tested anywhere.
>> Should it be compiled, or should it be removed?
> What about in 5 and the autotools build system?
It appears to be omitted from 5's cpukit/Makefile.am
I don't see the code in 4.11. It was added by Chris to support untar
of tgz files.
> --joel
>> Gedare
>> devel mailing list
>> devel at rtems.org
