[PATCH] wscript: fix formatting with yapf
Gedare Bloom
gedare at rtems.org
Fri Nov 4 20:23:08 UTC 2022
wscript | 305 ++++++++++++++++++++++++++------------------------------
1 file changed, 139 insertions(+), 166 deletions(-)
diff --git a/wscript b/wscript
index 4071cc9ef8..6bf3b25012 100755
--- a/wscript
+++ b/wscript
@@ -73,13 +73,10 @@ class VersionControlKeyHeader:
#define _RTEMS_VERSION_VC_KEY_H_
try:
- rev = bld.cmd_and_log(
- "git rev-parse HEAD", quiet=Context.STDOUT
- ).strip()
+ rev = bld.cmd_and_log("git rev-parse HEAD",
+ quiet=Context.STDOUT).strip()
content += """#define RTEMS_VERSION_VC_KEY "{}"
-""".format(
- rev
+""".format(rev)
except WafError:
content += """/* No version control key found; release? */
@@ -96,6 +93,7 @@ class VersionControlKeyHeader:
class EnvWrapper(object):
def __init__(self, env):
self._env = env
@@ -155,9 +153,8 @@ def _is_enabled(enabled, enabled_by):
def _asm_explicit_target(self, node):
- task = self.create_task(
- "asm", node, self.bld.bldnode.make_node(self.target)
+ task = self.create_task("asm", node,
+ self.bld.bldnode.make_node(self.target))
try:
self.compiled_tasks.append(task)
except AttributeError:
@@ -180,6 +177,7 @@ def process_start_files(self):
class Item(object):
def __init__(self, uid, data):
self.uid = uid
self.data = data
@@ -192,8 +190,7 @@ class Item(object):
uid = link["uid"]
if not os.path.isabs(uid):
uid = os.path.normpath(
- os.path.join(os.path.dirname(self.uid), uid)
+ os.path.join(os.path.dirname(self.uid), uid))
self._links.append(items[uid])
self.links = self._yield_links
for link in self._links:
@@ -248,9 +245,7 @@ class Item(object):
except Exception as e:
ctx.fatal(
"In item '{}' substitution in '{}' failed: {}".format(
- self.uid, value, e
+ self.uid, value, e))
if isinstance(value, list):
more = []
for item in value:
@@ -284,7 +279,8 @@ class Item(object):
asflags=self.substitute(bld, self.data["asflags"]),
cppflags=self.substitute(bld, self.data["cppflags"]),
features="asm_explicit_target asm c",
- includes=bic.includes + self.substitute(bld, self.data["includes"]),
+ includes=bic.includes +
source=[source],
target=target,
@@ -297,8 +293,10 @@ class Item(object):
cflags=self.substitute(bld, self.data["cflags"]),
cppflags=cppflags + self.substitute(bld, self.data["cppflags"]),
features="c",
- rule="${CC} ${CFLAGS} ${CPPFLAGS} ${DEFINES_ST:DEFINES} ${CPPPATH_ST:INCPATHS} -c ${SRC[0]} -o ${TGT}",
+ rule=
+ "${CC} ${CFLAGS} ${CPPFLAGS} ${DEFINES_ST:DEFINES} ${CPPPATH_ST:INCPATHS} -c ${SRC[0]} -o ${TGT}",
source=[source] + deps,
target=target,
@@ -311,8 +309,10 @@ class Item(object):
cxxflags=self.substitute(bld, self.data["cxxflags"]),
features="cxx",
- rule="${CXX} ${CXXFLAGS} ${CPPFLAGS} ${DEFINES_ST:DEFINES} ${CPPPATH_ST:INCPATHS} -c ${SRC[0]} -o ${TGT}",
+ rule=
+ "${CXX} ${CXXFLAGS} ${CPPFLAGS} ${DEFINES_ST:DEFINES} ${CPPPATH_ST:INCPATHS} -c ${SRC[0]} -o ${TGT}",
target=target,
@@ -322,14 +322,14 @@ class Item(object):
from waflib.Task import Task
class link(Task):
def __init__(self, item, bic, cmd, env):
super(link, self).__init__(self, env=env)
self.cmd = cmd
self.ldflags = bic.ldflags + item.data["ldflags"]
self.stlib = item.data["stlib"]
- self.use = (
- item.data["use-before"] + bic.use + item.data["use-after"]
+ self.use = (item.data["use-before"] + bic.use +
+ item.data["use-after"])
def run(self):
cmd = [self.cmd]
@@ -368,6 +368,7 @@ class Item(object):
class gnatmake(Task):
def __init__(self, bld, bic, objdir, objs, main, target, item):
super(gnatmake, self).__init__(self, env=bld.env)
self.objdir = objdir
@@ -382,9 +383,8 @@ class Item(object):
self.adaincludes.append(bld.path.make_node(i))
- self.use = (
def run(self):
cwd = self.get_cwd()
@@ -428,7 +428,9 @@ class Item(object):
return target
def ar(self, bld, source, target):
- bld(rule="${AR} ${ARFLAGS} ${TGT} ${SRC}", source=source, target=target)
+ bld(rule="${AR} ${ARFLAGS} ${TGT} ${SRC}",
+ source=source,
+ target=target)
return target
def gzip(self, bld, source):
@@ -442,12 +444,13 @@ class Item(object):
return target
def tar(self, bld, source, remove, target):
def run(task):
import tarfile
- tar = tarfile.TarFile(
- task.outputs[0].abspath(), "w", format=tarfile.USTAR_FORMAT
+ tar = tarfile.TarFile(task.outputs[0].abspath(),
+ "w",
+ format=tarfile.USTAR_FORMAT)
srcpath = bld.path.abspath() + "/"
bldpath = bld.bldnode.abspath() + "/"
for src in task.inputs:
@@ -463,6 +466,7 @@ class Item(object):
return target
def bin2c(self, bld, source, name=None, target=None):
def run(task):
cmd = [bld.env.BIN2C[0]]
if name is not None:
@@ -488,6 +492,7 @@ class Item(object):
return target
def rtems_rap(self, bld, base, objects, libs, target):
def run(task):
cmd = [
bld.env.RTEMS_LD[0],
@@ -514,6 +519,7 @@ class Item(object):
class GroupItem(Item):
super(GroupItem, self).__init__(uid, data)
@@ -533,14 +539,14 @@ class GroupItem(Item):
class ConfigFileItem(Item):
super(ConfigFileItem, self).__init__(uid, data)
def do_configure(self, conf, cic):
content = self.substitute(conf, self.data["content"])
- f = conf.bldnode.make_node(
- conf.env.VARIANT + "/" + self.get(conf, "target")
+ f = conf.bldnode.make_node(conf.env.VARIANT + "/" +
+ self.get(conf, "target"))
f.parent.mkdir()
f.write(content)
conf.env.append_value("cfg_files", f.abspath())
@@ -550,6 +556,7 @@ class ConfigFileItem(Item):
class ConfigHeaderItem(Item):
super(ConfigHeaderItem, self).__init__(uid, data)
@@ -567,6 +574,7 @@ class ConfigHeaderItem(Item):
class StartFileItem(Item):
super(StartFileItem, self).__init__(uid, data)
@@ -585,6 +593,7 @@ class StartFileItem(Item):
class ObjectsItem(Item):
super(ObjectsItem, self).__init__(uid, data)
@@ -614,6 +623,7 @@ class ObjectsItem(Item):
class BSPItem(Item):
super(BSPItem, self).__init__(uid, data)
arch_bsps = bsps.setdefault(data["arch"].strip(), {})
@@ -621,9 +631,8 @@ class BSPItem(Item):
def prepare_build(self, bld, bic):
return BuildItemContext(
- bic.includes
- + bld.env.BSP_INCLUDES
- + self.substitute(bld, self.data["includes"]),
+ bic.includes + bld.env.BSP_INCLUDES +
bld.env.BSP_CFLAGS + self.substitute(bld, self.data["cflags"]),
@@ -647,6 +656,7 @@ class BSPItem(Item):
class LibraryItem(Item):
super(LibraryItem, self).__init__(uid, data)
@@ -677,6 +687,7 @@ class LibraryItem(Item):
class TestProgramItem(Item):
super(TestProgramItem, self).__init__(uid, data)
name = uid.split("/")[-1].upper().replace("-", "_")
@@ -689,9 +700,8 @@ class TestProgramItem(Item):
- bic.cppflags
- + bld.env[self.cppflags]
- + self.substitute(bld, self.data["cppflags"]),
+ bic.cppflags + bld.env[self.cppflags] +
bic.cflags + self.substitute(bld, self.data["cflags"]),
bic.cxxflags + self.substitute(bld, self.data["cxxflags"]),
self.data["use-before"] + bic.use + self.data["use-after"],
@@ -717,6 +727,7 @@ class TestProgramItem(Item):
class AdaTestProgramItem(TestProgramItem):
super(AdaTestProgramItem, self).__init__(uid, data)
@@ -735,6 +746,7 @@ class AdaTestProgramItem(TestProgramItem):
class OptionItem(Item):
super(OptionItem, self).__init__(uid, data)
@@ -783,8 +795,7 @@ class OptionItem(Item):
def _do_append_test_cppflags(self, conf, name, state):
- "TEST_" + name.upper().replace("-", "_") + "_CPPFLAGS", state
+ "TEST_" + name.upper().replace("-", "_") + "_CPPFLAGS", state)
def _append_test_cppflags(self, conf, cic, value, arg):
self._do_append_test_cppflags(conf, arg, value)
@@ -794,45 +805,34 @@ class OptionItem(Item):
if value is not None and value % arg != 0:
conf.fatal(
"Value '{}' for option '{}' is not aligned by '{}'".format(
- value, self.data["name"], arg
+ value, self.data["name"], arg))
return value
def _assert_eq(self, conf, cic, value, arg):
if value is not None and value != arg:
- conf.fatal(
- "Value '{}' for option '{}' is not equal to {}".format(
+ conf.fatal("Value '{}' for option '{}' is not equal to {}".format(
return value
def _assert_ge(self, conf, cic, value, arg):
if value is not None and value < arg:
conf.fatal(
- "Value '{}' for option '{}' is not greater than or equal to {}".format(
+ "Value '{}' for option '{}' is not greater than or equal to {}"
+ .format(value, self.data["name"], arg))
return value
def _assert_gt(self, conf, cic, value, arg):
if value is not None and value <= arg:
conf.fatal(
"Value '{}' for option '{}' is not greater than {}".format(
return value
def _assert_in_interval(self, conf, cic, value, arg):
if value is not None and (value < arg[0] or value > arg[1]):
conf.fatal(
- "Value '{}' for option '{}' is not in closed interval [{}, {}]".format(
- value, self.data["name"], arg[0], arg[1]
+ "Value '{}' for option '{}' is not in closed interval [{}, {}]"
+ .format(value, self.data["name"], arg[0], arg[1]))
return value
def _assert_int8(self, conf, cic, value, arg):
@@ -842,49 +842,38 @@ class OptionItem(Item):
return self._assert_in_interval(conf, cic, value, [-32768, 32767])
def _assert_int32(self, conf, cic, value, arg):
- return self._assert_in_interval(
- conf, cic, value, [-2147483648, 2147483647]
+ return self._assert_in_interval(conf, cic, value,
+ [-2147483648, 2147483647])
def _assert_int64(self, conf, cic, value, arg):
- conf, cic, value, [-9223372036854775808, 9223372036854775807]
+ conf, cic, value, [-9223372036854775808, 9223372036854775807])
def _assert_le(self, conf, cic, value, arg):
if value is not None and value > arg:
conf.fatal(
- "Value '{}' for option '{}' is not less than or equal to {}".format(
+ "Value '{}' for option '{}' is not less than or equal to {}".
+ format(value, self.data["name"], arg))
return value
def _assert_lt(self, conf, cic, value, arg):
if value is not None and value >= arg:
- conf.fatal(
- "Value '{}' for option '{}' is not less than {}".format(
+ conf.fatal("Value '{}' for option '{}' is not less than {}".format(
return value
def _assert_ne(self, conf, cic, value, arg):
if value is not None and value == arg:
conf.fatal(
"Value '{}' for option '{}' is not unequal to {}".format(
return value
def _assert_power_of_two(self, conf, cic, value, arg):
if value is not None and (value <= 0 or (value & (value - 1)) != 0):
conf.fatal(
"Value '{}' for option '{}' is not a power of two".format(
+ value, self.data["name"]))
return value
def _assert_uint8(self, conf, cic, value, arg):
@@ -897,9 +886,8 @@ class OptionItem(Item):
return self._assert_in_interval(conf, cic, value, [0, 4294967295])
def _assert_uint64(self, conf, cic, value, arg):
- conf, cic, value, [0, 18446744073709551615]
+ [0, 18446744073709551615])
def _check_cc(self, conf, cic, value, arg):
result = conf.check_cc(
@@ -975,9 +963,8 @@ class OptionItem(Item):
except configparser.NoOptionError:
value = self.default_value(conf.env.ARCH_BSP, conf.env.ARCH_FAMILY)
except ValueError as ve:
- conf.fatal(
- "Invalid value for configuration option {}: {}".format(name, ve)
+ conf.fatal("Invalid value for configuration option {}: {}".format(
+ name, ve))
return value
def _get_env(self, conf, cic, value, arg):
@@ -996,10 +983,8 @@ class OptionItem(Item):
return eval(value)
conf.fatal(
- "Value '{}' for option '{}' is an invalid integer expression: {}".format(
- value, name, e
+ "Value '{}' for option '{}' is an invalid integer expression: {}"
+ .format(value, name, e))
def _get_string(self, conf, cic, value, arg):
name = self.data["name"]
@@ -1029,18 +1014,15 @@ class OptionItem(Item):
def _test_state_exclude(self, conf, name):
- "ENABLE", "TEST_" + name.upper().replace("-", "_") + "_EXCLUDE"
+ "ENABLE", "TEST_" + name.upper().replace("-", "_") + "_EXCLUDE")
def _test_state_expected_fail(self, conf, name):
- self._do_append_test_cppflags(
- conf, name, "-DTEST_STATE_EXPECTED_FAIL=1"
+ self._do_append_test_cppflags(conf, name,
+ "-DTEST_STATE_EXPECTED_FAIL=1")
def _test_state_indeterminate(self, conf, name):
- conf, name, "-DTEST_STATE_INDETERMINATE=1"
+ "-DTEST_STATE_INDETERMINATE=1")
def _test_state_user_input(self, conf, name):
self._do_append_test_cppflags(conf, name, "-DTEST_STATE_USER_INPUT=1")
@@ -1116,6 +1098,7 @@ class OptionItem(Item):
class ScriptItem(Item):
super(ScriptItem, self).__init__(uid, data)
@@ -1142,6 +1125,7 @@ class ScriptItem(Item):
class ConfigItemContext(object):
def __init__(self, cp, path_list):
self.cp = cp
self.options = set()
@@ -1152,9 +1136,9 @@ class ConfigItemContext(object):
class BuildItemContext(object):
- def __init__(
- self, includes, cppflags, cflags, cxxflags, use, ldflags, objects
+ def __init__(self, includes, cppflags, cflags, cxxflags, use, ldflags,
+ objects):
self.includes = includes
self.cppflags = cppflags
self.cflags = cflags
@@ -1289,39 +1273,45 @@ def options(ctx):
rg.add_option(
"--rtems-bsps",
metavar="REGEX,...",
- help="a comma-separated list of Python regular expressions which select the desired BSP variants (e.g. 'sparc/erc32'); it may be used in the bsp_defaults and bsp_list commands",
+ help=
+ "a comma-separated list of Python regular expressions which select the desired BSP variants (e.g. 'sparc/erc32'); it may be used in the bsp_defaults and bsp_list commands",
rg.add_option(
"--rtems-compiler",
metavar="COMPILER",
- help="determines which compiler is used to list the BSP option defaults [default: 'gcc']; it may be used in the bsp_defaults command; valid compilers are: {}".format(
- ", ".join(compilers)
+ help=
+ "determines which compiler is used to list the BSP option defaults [default: 'gcc']; it may be used in the bsp_defaults command; valid compilers are: {}"
+ .format(", ".join(compilers)),
rg.add_option(
"--rtems-config",
metavar="CONFIG.INI,...",
- help="a comma-separated list of paths to the BSP configuration option files [default: 'config.ini']; default option values can be obtained via the bsp_defaults command; it may be used in the configure command",
+ help=
+ "a comma-separated list of paths to the BSP configuration option files [default: 'config.ini']; default option values can be obtained via the bsp_defaults command; it may be used in the configure command",
rg.add_option(
"--rtems-specs",
metavar="SPECDIRS,...",
- help="a comma-separated list of directory paths to build specification items [default: 'spec/build']; it may be used in the bsp_defaults, bsp_list, and configure commands",
+ help=
+ "a comma-separated list of directory paths to build specification items [default: 'spec/build']; it may be used in the bsp_defaults, bsp_list, and configure commands",
rg.add_option(
"--rtems-tools",
metavar="PREFIX,...",
- help="a comma-separated list of prefix paths to tools, e.g. compiler, linker, etc. [default: the installation prefix]; tools are searched in the prefix path and also in a 'bin' subdirectory of the prefix path; it may be used in the configure command",
+ help=
+ "a comma-separated list of prefix paths to tools, e.g. compiler, linker, etc. [default: the installation prefix]; tools are searched in the prefix path and also in a 'bin' subdirectory of the prefix path; it may be used in the configure command",
rg.add_option(
"--rtems-top-group",
metavar="UID",
- help="the UID of the top-level group [default: '/grp']; it may be used in the bsp_defaults and configure commands",
+ help=
+ "the UID of the top-level group [default: '/grp']; it may be used in the bsp_defaults and configure commands",
rg.add_option(
"--rtems-version",
metavar="VALUE",
- help="sets the RTEMS major version number; it is intended for RTEMS maintainers and may be used in the bsp_defaults and configure commands",
+ help=
+ "sets the RTEMS major version number; it is intended for RTEMS maintainers and may be used in the bsp_defaults and configure commands",
rg.add_option(
"--rtems-option",
@@ -1329,29 +1319,30 @@ def options(ctx):
action="append",
dest="rtems_options",
default=[],
- help="sets the option identified by KEY to the VALUE in the build specification; it is intended for RTEMS maintainers and may be used in the bsp_defaults and configure commands",
+ help=
+ "sets the option identified by KEY to the VALUE in the build specification; it is intended for RTEMS maintainers and may be used in the bsp_defaults and configure commands",
def check_environment(conf):
for ev in [
- "AR",
- "AS",
- "ASFLAGS",
- "CC",
- "CFLAGS",
- "CPPFLAGS",
- "CXX",
- "CXXFLAGS",
- "IFLAGS",
- "LD",
- "LIB",
- "LINK_CC",
- "LINK_CXX",
- "LINKFLAGS",
- "MFLAGS",
- "RFLAGS",
- "WFLAGS",
+ "AR",
+ "AS",
+ "ASFLAGS",
+ "CC",
+ "CFLAGS",
+ "CPPFLAGS",
+ "CXX",
+ "CXXFLAGS",
+ "IFLAGS",
+ "LD",
+ "LIB",
+ "LINK_CC",
+ "LINK_CXX",
+ "LINKFLAGS",
+ "MFLAGS",
+ "RFLAGS",
+ "WFLAGS",
if ev in os.environ:
conf.msg("Environment variable set", ev, color="RED")
@@ -1390,10 +1381,8 @@ def inherit(conf, cp, bsp_map, arch, bsp, path):
if not cp.has_section(base_variant):
if (not arch in bsps) or (not base in bsps[arch]):
conf.fatal(
- "BSP variant '{}' cannot inherit options from not existing variant '{}'".format(
- variant, base_variant
+ "BSP variant '{}' cannot inherit options from not existing variant '{}'"
+ .format(variant, base_variant))
bsp_map[bsp] = base
return base
top = inherit(conf, cp, bsp_map, arch, base, path + [variant])
@@ -1416,20 +1405,15 @@ def resolve_option_inheritance(conf, cp):
except:
conf.fatal(
"Section name '{}' is a malformed 'arch/bsp' tuple".format(
- variant
+ variant))
inherit(conf, cp, bsp_map, arch, bsp, [])
return bsp_map
def check_compiler(ctx, compiler):
if compiler not in compilers:
- ctx.fatal(
- "Specified compiler '{}' is not one of {}".format(
- compiler, compilers
+ ctx.fatal("Specified compiler '{}' is not one of {}".format(
+ compiler, compilers))
def get_compiler(conf, cp, variant):
@@ -1497,10 +1481,8 @@ def check_forbidden_options(ctx, opts):
for o in opts:
if getattr(ctx.options, "rtems_" + o):
ctx.fatal(
- "The --rtems-{} command line option is not allowed in the {} command".format(
- o.replace("_", "-"), ctx.cmd
+ "The --rtems-{} command line option is not allowed in the {} command"
+ .format(o.replace("_", "-"), ctx.cmd))
def get_path_list(conf):
@@ -1520,10 +1502,8 @@ def get_top_group(ctx):
top_group = "/grp"
if top_group not in items:
ctx.fatal(
- "There is no top-level group with UID '{}' in the specification".format(
- top_group
+ "There is no top-level group with UID '{}' in the specification".
+ format(top_group))
return top_group
@@ -1535,8 +1515,7 @@ def prepare_rtems_options(conf):
conf.rtems_options[k] = v
except:
conf.fatal(
- "The RTEMS option '{}' is not in KEY=VALUE format".format(x)
+ "The RTEMS option '{}' is not in KEY=VALUE format".format(x))
version = conf.options.rtems_version
if version is not None:
key = "__RTEMS_MAJOR__"
@@ -1574,7 +1553,8 @@ def append_variant_builds(bld):
for var in bld.env["VARIANTS"]:
- for c in (BuildContext, CleanContext, InstallContext, UninstallContext):
+ for c in (BuildContext, CleanContext, InstallContext,
+ UninstallContext):
name = c.__name__.replace("Context", "").lower()
class magic(c):
@@ -1607,9 +1587,8 @@ def build(bld):
return
long_command_line_workaround(bld)
- bic = BuildItemContext(
- bld.env.ARCH_INCLUDES.split(), [], [], [], [], [], []
+ bic = BuildItemContext(bld.env.ARCH_INCLUDES.split(), [], [], [], [], [],
bsps[bld.env.ARCH][bld.env.BSP_BASE].build(bld, bic)
items[bld.env.TOPGROUP].build(bld, bic)
@@ -1618,6 +1597,7 @@ def add_log_filter(name):
msg = "'" + name + "' finished successfully"
class Filter:
def filter(self, rec):
return not msg in rec.getMessage()
@@ -1644,11 +1624,8 @@ def is_in_white_list(variant, white_list):
def no_matches_error(ctx, white_list):
if white_list:
- ctx.fatal(
- "No BSP matches with the specified patterns: '{}'".format(
- "', '".join(white_list)
+ ctx.fatal("No BSP matches with the specified patterns: '{}'".format(
+ "', '".join(white_list)))
else:
ctx.fatal("The build specification contains no BSPs")
@@ -1673,18 +1650,14 @@ def bsp_defaults(ctx):
if not first:
print("")
first = False
- print(
+ print("""[{}]
# Selects the compiler used to build the BSP (allowed values are "gcc" and
# "clang"). Please note that the values of some options depend on the compiler
# selection and changing the compiler may lead to unpredictable behaviour if
# these options are not adjusted as well. Use the --rtems-compiler command line
# option to get the default values for a particular compiler via
# ./waf bsp_defaults.
-COMPILER = {}""".format(
- variant, compiler
+COMPILER = {}""".format(variant, compiler))
enable = [compiler, arch, variant]
bsp_item = bsps[arch][bsp]
family = arch + "/" + bsp_item.data["family"]
@@ -1697,8 +1670,8 @@ COMPILER = {}""".format(
def bsp_list(ctx):
"""lists base BSP variants"""
- ctx, ["compiler", "config", "options", "tools", "top_group", "version"]
+ ctx,
+ ["compiler", "config", "options", "tools", "top_group", "version"])
add_log_filter(ctx.cmd)
load_items_from_options(ctx)
white_list = get_white_list(ctx)
2.34.1
