Apple's Ventura OS issue with RSB.
Karel Gardas
karel at functional.vision
Sun Nov 6 18:38:28 UTC 2022
Side note before answering : the email was motivated by the fact that I
provided few patches to RSB to make that working well on Monterey
running on M1. This was just few weeks ago so I know, this was running
well. Last week I've updated to Ventura and things felt apart. Hence the
report here.
On 11/6/22 16:09, Joel Sherrill wrote:
> Is the cross gcc compiled with the native compiler provided by Apple?
Yes, it is.
> The alternative would likely be you installing something special.
No, I keep OS as clean as possible and as stock as possible to be as
close as possible to customer configuration.
> I wonder if using gcc to compile it would work. But there's not a real
> solution.
Indeed, I'll see if I can do anything about that as that would also be
usable for...
> Seems like an issue which needs reporting to gcc.
indeed, the report here is probably minimal thing I should do.
Thanks,
Karel
