Apple's Ventura OS issue with RSB.
Sun Nov 6 21:42:34 UTC 2022
On 7/11/2022 5:38 am, Karel Gardas wrote:
> Side note before answering : the email was motivated by the fact that I provided
> few patches to RSB to make that working well on Monterey running on M1. This was
> just few weeks ago so I know, this was running well. Last week I've updated to
> Ventura and things felt apart. Hence the report here.
> On 11/6/22 16:09, Joel Sherrill wrote:
>> Is the cross gcc compiled with the native compiler provided by Apple?
> Yes, it is.
>> The alternative would likely be you installing something special.
> No, I keep OS as clean as possible and as stock as possible to be as close as
> possible to customer configuration.
>> I wonder if using gcc to compile it would work. But there's not a real solution.
> Indeed, I'll see if I can do anything about that as that would also be usable
> for...
>> Seems like an issue which needs reporting to gcc.
> indeed, the report here is probably minimal thing I should do.
Sebastian has pushed updates to the tools to the RSB. Did you happen to pick up
those?
