[PATCH 2/2] c-user/clock: Fix typo
Mon Nov 7 16:26:29 UTC 2022
ok to both
On Mon, Nov 7, 2022 at 3:20 AM Matthew Joyce
<matthew.joyce at embedded-brains.de> wrote:
> From: Matt Joyce <matthew.joyce at embedded-brains.de>
>  c-user/clock/directives.rst | 2 +-
>  1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/c-user/clock/directives.rst b/c-user/clock/directives.rst
> index 6e1542c..877204a 100644
> --- a/c-user/clock/directives.rst
> +++ b/c-user/clock/directives.rst
> @@ -1222,7 +1222,7 @@ system initialization using :term:`CLOCK_MONOTONIC`.
>  .. rubric:: PARAMETERS:
>  ``uptime``
> -    This parameter is the pointer to a `struct timeval
> +    This parameter is the pointer to a `struct timespec
>      <https://pubs.opengroup.org/onlinepubs/009695399/basedefs/sys/time.h.html>`_
>      object.  When the directive call is successful, the seconds and nanoseconds
>      elapsed since some time point during the system initialization and some
> 2.35.3
> devel mailing list
> devel at rtems.org
