[PATCH 2/2] c-user/clock: Fix typo
Tue Nov 8 00:56:37 UTC 2022
+1
On 8/11/2022 3:26 am, Gedare Bloom wrote:
> ok to both
> On Mon, Nov 7, 2022 at 3:20 AM Matthew Joyce
> <matthew.joyce at embedded-brains.de> wrote:
>> From: Matt Joyce <matthew.joyce at embedded-brains.de>
>>  c-user/clock/directives.rst | 2 +-
>>  1 file changed, 1 insertion(+), 1 deletion(-)
>> diff --git a/c-user/clock/directives.rst b/c-user/clock/directives.rst
>> index 6e1542c..877204a 100644
>> --- a/c-user/clock/directives.rst
>> +++ b/c-user/clock/directives.rst
>> @@ -1222,7 +1222,7 @@ system initialization using :term:`CLOCK_MONOTONIC`.
>>  .. rubric:: PARAMETERS:
>>  ``uptime``
>> -    This parameter is the pointer to a `struct timeval
>> +    This parameter is the pointer to a `struct timespec
>>      <https://pubs.opengroup.org/onlinepubs/009695399/basedefs/sys/time.h.html>`_
>>      object.  When the directive call is successful, the seconds and nanoseconds
>>      elapsed since some time point during the system initialization and some
>> 2.35.3
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
