[PATCH] riscv: Simplify _CPU_ISR_Set_level()
Sebastian Huber
Tue Nov 8 13:24:05 UTC 2022
Where CPU_ENABLE_ROBUST_THREAD_DISPATCH == TRUE, the only supported interrupt
level allowed to set is 0 (interrupts enabled). This constraint is enforced by
the API level functions which return an error status for other interrupt
levels.
.../score/cpu/riscv/include/rtems/score/cpu.h | 28 +++++++++----------
1 file changed, 13 insertions(+), 15 deletions(-)
diff --git a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
index 88f7e7960c..f74ce99684 100644
--- a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
@@ -193,21 +193,19 @@ static inline bool _CPU_ISR_Is_enabled( unsigned long level )
static inline void _CPU_ISR_Set_level( uint32_t level )
- if ( ( level & CPU_MODES_INTERRUPT_MASK) == 0 ) {
- __asm__ volatile (
- ".option push\n"
- ".option arch, +zicsr\n"
- "csrrs zero, mstatus, " RTEMS_XSTRING( RISCV_MSTATUS_MIE ) "\n"
- ".option pop"
- } else {
- ".option push\n"
- "csrrc zero, mstatus, " RTEMS_XSTRING( RISCV_MSTATUS_MIE ) "\n"
- ".option pop"
+ * Where CPU_ENABLE_ROBUST_THREAD_DISPATCH == TRUE, the only supported
+ * interrupt level allowed to set is 0 (interrupts enabled). This constraint
+ * is enforced by the API level functions which return an error status for
+ * other interrupt levels.
+ (void) level;
+ __asm__ volatile (
+ ".option push\n"
+ ".option arch, +zicsr\n"
+ "csrrs zero, mstatus, " RTEMS_XSTRING( RISCV_MSTATUS_MIE ) "\n"
+ ".option pop"
uint32_t _CPU_ISR_Get_level( void );
2.35.3
