[PATCH v2] zynqmp: Add support for the CFC-400X
Kinsey Moore kinsey.moore at oarcorp.com
Tue Nov 8 21:56:20 UTC 2022
This adds a BSP variant for the ZynqMP BSP family to support the
Innoflight CFC-400X platform. To properly support the CFC-400X, device
trees were added to the ZynqMP platform due to both the optional
management interface as well as alternate physical configuration of the
ethernet interfaces.
 bsps/aarch64/xilinx-zynqmp/console/console.c  | 163 +++++++++++++++++-
 bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c      |  51 ++++++
 bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts    | 110 ++++++++++++
 bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c  | 124 +++++++++++++
 bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts     |  94 ++++++++++
 bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c   |  97 +++++++++++
 bsps/aarch64/xilinx-zynqmp/include/bsp.h      |  15 ++
 .../aarch64/xilinx-zynqmp/start/bspstartmmu.c |   4 +
 .../aarch64/xilinx-zynqmp/bspcfc400xlp64.yml  |  21 +++
 .../aarch64/xilinx-zynqmp/bspqemuilp32.yml    |   2 +
 .../aarch64/xilinx-zynqmp/bspqemulp64.yml     |   2 +
 .../aarch64/xilinx-zynqmp/bspzu3egilp32.yml   |   2 +
 .../aarch64/xilinx-zynqmp/bspzu3eglp64.yml    |   2 +
 spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml |   1 +
 .../aarch64/xilinx-zynqmp/objfdtcfc400x.yml   |  14 ++
 .../aarch64/xilinx-zynqmp/objfdtzynqmp.yml    |  14 ++
 .../bsps/aarch64/xilinx-zynqmp/optloadoff.yml |   1 +
 .../bsps/aarch64/xilinx-zynqmp/optramori.yml  |   1 +
 spec/build/cpukit/optsmp.yml                  |   1 +
 19 files changed, 718 insertions(+), 1 deletion(-)
 create mode 100644 bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c
 create mode 100644 bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts
 create mode 100644 bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
 create mode 100644 bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts
 create mode 100644 bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
 create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/bspcfc400xlp64.yml
 create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/objfdtcfc400x.yml
 create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/objfdtzynqmp.yml
diff --git a/bsps/aarch64/xilinx-zynqmp/console/console.c b/bsps/aarch64/xilinx-zynqmp/console/console.c
index d1948f1a0c..d546db8535 100644
--- a/bsps/aarch64/xilinx-zynqmp/console/console.c
+++ b/bsps/aarch64/xilinx-zynqmp/console/console.c
@@ -9,7 +9,7 @@
- * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
+ * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
  * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
@@ -36,13 +36,165 @@
 #include <rtems/console.h>
 #include <rtems/bspIo.h>
+#include <rtems/endian.h>
+#include <rtems/rtems-fdt.h>
 #include <rtems/sysinit.h>
+#include <bsp/aarch64-mmu.h>
+#include <bsp/fdt.h>
 #include <bsp/irq.h>
 #include <dev/serial/zynq-uart.h>
 #include <bspopts.h>
+#include <libchip/ns16550.h>
+uint32_t mgmt_uart_reg_shift = 0;
+static uint8_t get_register(uintptr_t addr, uint8_t i)
+  volatile uint8_t *reg = (uint8_t *) addr;
+  i <<= mgmt_uart_reg_shift;
+  return reg [i];
+static void set_register(uintptr_t addr, uint8_t i, uint8_t val)
+  reg [i] = val;
+static ns16550_context zynqmp_mgmt_uart_context = {
+  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("Management UART 0"),
+  .get_reg = get_register,
+  .set_reg = set_register,
+  .port = 0,
+  .irq = 0,
+  .clock = 0,
+  .initial_baud = 0,
+__attribute__ ((weak)) void zynqmp_configure_management_console(rtems_termios_device_context *base)
+  /* This SLIP-encoded watchdog command sets timeouts to 0xFFFFFFFF seconds. */
+  const char mgmt_watchdog_cmd[] =
+    "\xc0\xda\x00\x00\xff\xff\xff\xff\xff\x00\xff\xff\xff\xffM#\xc0";
+  /* Send the system watchdog configuration command */
+  for (int i = 0; i < sizeof(mgmt_watchdog_cmd); i++) {
+    ns16550_polled_putchar(base, mgmt_watchdog_cmd[i]);
+static void zynqmp_management_console_init(void)
+  /* Find the management console in the device tree */
+  rtems_fdt_handle fdt_handle;
+  const uint32_t *prop;
+  uint32_t outprop[4];
+  int proplen;
+  int node;
+  rtems_fdt_init_handle(&fdt_handle);
+  rtems_fdt_register(bsp_fdt_get(), &fdt_handle);
+  const char *alias = rtems_fdt_get_alias(&fdt_handle, "mgmtport");
+  if (alias == NULL) {
+    rtems_fdt_release_handle(&fdt_handle);
+    return;
+  node = rtems_fdt_path_offset(&fdt_handle, alias);
+  prop = rtems_fdt_getprop(&fdt_handle, node, "clock-frequency", &proplen);
+  if ( prop == NULL || proplen != 4 ) {
+    zynqmp_mgmt_uart_context.port = 0;
+    return;
+  outprop[0] = rtems_uint32_from_big_endian((const uint8_t *) &prop[0]);
+  zynqmp_mgmt_uart_context.clock = outprop[0];
+  prop = rtems_fdt_getprop(&fdt_handle, node, "current-speed", &proplen);
+    return;
+  zynqmp_mgmt_uart_context.initial_baud = outprop[0];
+  prop = rtems_fdt_getprop(&fdt_handle, node, "interrupts", &proplen);
+  if ( prop == NULL || proplen != 12 ) {
+    return;
+  outprop[1] = rtems_uint32_from_big_endian((const uint8_t *) &prop[1]);
+  outprop[2] = rtems_uint32_from_big_endian((const uint8_t *) &prop[2]);
+  /* proplen is in bytes, interrupt mapping expects a length in 32-bit cells */
+  zynqmp_mgmt_uart_context.irq = bsp_fdt_map_intr(outprop, proplen / 4);
+  if ( zynqmp_mgmt_uart_context.irq == 0 ) {
+    return;
+  prop = rtems_fdt_getprop(&fdt_handle, node, "reg", &proplen);
+  if ( prop == NULL || proplen != 16 ) {
+    return;
+  outprop[3] = rtems_uint32_from_big_endian((const uint8_t *) &prop[3]);
+  zynqmp_mgmt_uart_context.port = ( ( (uint64_t) outprop[0] ) << 32 ) | outprop[1];
+  uintptr_t uart_base = zynqmp_mgmt_uart_context.port;
+  size_t uart_size = ( ( (uint64_t) outprop[2] ) << 32 ) | outprop[3];
+  rtems_status_code sc = aarch64_mmu_map( uart_base,
+                                          uart_size,
+                                          AARCH64_MMU_DEVICE);
+  if ( sc != RTEMS_SUCCESSFUL ) {
+    return;
+  prop = rtems_fdt_getprop(&fdt_handle, node, "reg-offset", &proplen);
+    return;
+  zynqmp_mgmt_uart_context.port += outprop[0];
+  prop = rtems_fdt_getprop(&fdt_handle, node, "reg-shift", &proplen);
+    return;
+  mgmt_uart_reg_shift = outprop[0];
+  ns16550_probe(&zynqmp_mgmt_uart_context.base);
+  zynqmp_configure_management_console(&zynqmp_mgmt_uart_context.base);
+RTEMS_SYSINIT_ITEM(
+  zynqmp_management_console_init,
+  RTEMS_SYSINIT_BSP_START,
+  RTEMS_SYSINIT_ORDER_FIRST
 static zynq_uart_context zynqmp_uart_instances[2] = {
     .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 0" ),
@@ -81,6 +233,15 @@ rtems_status_code console_initialize(
+  if ( zynqmp_mgmt_uart_context.port != 0 ) {
+    rtems_termios_device_install(
+      "/dev/ttyMGMT0",
+      &ns16550_handler_polled,
+      NULL,
+      &zynqmp_mgmt_uart_context.base
   return RTEMS_SUCCESSFUL;
diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c b/bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c
new file mode 100644
index 0000000000..0748639256
--- /dev/null
+++ b/bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c
@@ -0,0 +1,51 @@
+ * @file
+ * @ingroup RTEMSBSPsAArch64XilinxZynqMP
+ * @brief This source file contains the implementatin of bsp_fdt_get().
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+#include <bsp.h>
+const void *bsp_fdt_get(void)
+  return zynqmp_dtb;
+uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells)
+  if (icells != 3) {
+    return 0;
+  return (intr[0] == 0 ? 32 : 16) + intr[1];
diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts
index 0000000000..763a668a5c
--- /dev/null
+++ b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts
@@ -0,0 +1,110 @@
+ * @file
+ * @brief This file provides the CFC-400X device tree
+ * are met:
+/dts-v1/;
+	#address-cells = <0x02>;
+	#size-cells = <0x02>;
+	amba {
+		compatible = "simple-bus";
+		ranges;
+		interrupt-controller at f9010000 {
+			compatible = "arm,gic-400";
+			#interrupt-cells = <0x03>;
+			reg = <0x00 0xf9010000 0x00 0x10000>;
+			interrupt-controller;
+			phandle = <0x01>;
+		ethernet at ff0b0000 {
+			compatible = "cdns,gem";
+			status = "okay";
+			interrupt-parent = <0x01>;
+			interrupts = <0x00 0x39 0x04>;
+			reg = <0x00 0xff0b0000 0x00 0x1000>;
+			phy-mode = "sgmii";
+		ethernet at ff0c0000 {
+			status = "okay";
+			interrupts = <0x00 0x3b 0x04>;
+			reg = <0x00 0xff0c0000 0x00 0x1000>;
+		ethernet at ff0d0000 {
+			status = "okay";
+			interrupts = <0x00 0x3d 0x04>;
+			reg = <0x00 0xff0d0000 0x00 0x1000>;
+		ethernet at ff0e0000 {
+			status = "okay";
+			interrupts = <0x00 0x3f 0x04>;
+			reg = <0x00 0xff0e0000 0x00 0x1000>;
+		serial at 800a0000 {
+			clock-frequency = <0x189c000>;
+			compatible = "ns16550a";
+			current-speed = <0x1c200>;
+			device_type = "serial";
+			interrupts = <0x00 0x6e 0x04>;
+			reg = <0x00 0x800a0000 0x00 0x10000>;
+			reg-offset = <0x1000>;
+			reg-shift = <0x02>;
+	aliases {
+		mgmtport = "/amba/serial at 800a0000";
diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
index 0000000000..2d0078678e
--- /dev/null
+++ b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
@@ -0,0 +1,124 @@
+unsigned char zynqmp_dtb[] = {
+  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x05, 0xa3, 0x00, 0x00, 0x00, 0x38,
+  0x00, 0x00, 0x04, 0xd0, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
+  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xd3,
+  0x00, 0x00, 0x04, 0x98, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x01, 0x61, 0x6d, 0x62, 0x61, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x1b,
+  0x73, 0x69, 0x6d, 0x70, 0x6c, 0x65, 0x2d, 0x62, 0x75, 0x73, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x26, 0x00, 0x00, 0x00, 0x01,
+  0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x63, 0x6f,
+  0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x40, 0x66, 0x39, 0x30,
+  0x31, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x1b, 0x61, 0x72, 0x6d, 0x2c,
+  0x67, 0x69, 0x63, 0x2d, 0x34, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x2d,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
+  0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0xf9, 0x01, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x57, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x65, 0x74, 0x68, 0x65,
+  0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30, 0x62, 0x30, 0x30, 0x30,
+  0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09,
+  0x00, 0x00, 0x00, 0x1b, 0x63, 0x64, 0x6e, 0x73, 0x2c, 0x67, 0x65, 0x6d,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05,
+  0x00, 0x00, 0x00, 0x5f, 0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x66,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c,
+  0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x39,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
+  0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0xff, 0x0b, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x82, 0x73, 0x67, 0x6d, 0x69,
+  0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30,
+  0x63, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b, 0x63, 0x64, 0x6e, 0x73,
+  0x2c, 0x67, 0x65, 0x6d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x5f, 0x6f, 0x6b, 0x61, 0x79,
+  0x00, 0x00, 0x00, 0x66, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x3b, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00,
+  0xff, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x82,
+  0x73, 0x67, 0x6d, 0x69, 0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x01, 0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74,
+  0x40, 0x66, 0x66, 0x30, 0x64, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b,
+  0x63, 0x64, 0x6e, 0x73, 0x2c, 0x67, 0x65, 0x6d, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x5f,
+  0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x66, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x77,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3d, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x3e,
+  0x00, 0x00, 0x00, 0x00, 0xff, 0x0d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x06,
+  0x00, 0x00, 0x00, 0x82, 0x73, 0x67, 0x6d, 0x69, 0x69, 0x00, 0x00, 0x00,
+  0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30, 0x65, 0x30, 0x30, 0x30,
+  0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f,
+  0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0xff, 0x0e, 0x00, 0x00,
+  0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40, 0x38, 0x30, 0x30, 0x61, 0x30,
+  0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x8b, 0x01, 0x89, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b, 0x6e, 0x73, 0x31, 0x36,
+  0x35, 0x35, 0x30, 0x61, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x9b, 0x00, 0x01, 0xc2, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0xa9,
+  0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x6e, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x00, 0x80, 0x0a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x61, 0x6c, 0x69, 0x61, 0x73, 0x65, 0x73, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x16, 0x00, 0x00, 0x00, 0xca, 0x2f, 0x61, 0x6d, 0x62,
+  0x61, 0x2f, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40, 0x38, 0x30, 0x30,
+  0x61, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x09, 0x23, 0x61, 0x64, 0x64,
+  0x72, 0x65, 0x73, 0x73, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23,
+  0x73, 0x69, 0x7a, 0x65, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x63,
+  0x6f, 0x6d, 0x70, 0x61, 0x74, 0x69, 0x62, 0x6c, 0x65, 0x00, 0x72, 0x61,
+  0x6e, 0x67, 0x65, 0x73, 0x00, 0x23, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72,
+  0x75, 0x70, 0x74, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x72, 0x65,
+  0x67, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d,
+  0x63, 0x6f, 0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x70,
+  0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65, 0x00, 0x73, 0x74, 0x61, 0x74, 0x75,
+  0x73, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d,
+  0x70, 0x61, 0x72, 0x65, 0x6e, 0x74, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72,
+  0x72, 0x75, 0x70, 0x74, 0x73, 0x00, 0x70, 0x68, 0x79, 0x2d, 0x6d, 0x6f,
+  0x64, 0x65, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x66, 0x72, 0x65,
+  0x71, 0x75, 0x65, 0x6e, 0x63, 0x79, 0x00, 0x63, 0x75, 0x72, 0x72, 0x65,
+  0x6e, 0x74, 0x2d, 0x73, 0x70, 0x65, 0x65, 0x64, 0x00, 0x64, 0x65, 0x76,
+  0x69, 0x63, 0x65, 0x5f, 0x74, 0x79, 0x70, 0x65, 0x00, 0x72, 0x65, 0x67,
+  0x2d, 0x6f, 0x66, 0x66, 0x73, 0x65, 0x74, 0x00, 0x72, 0x65, 0x67, 0x2d,
+  0x73, 0x68, 0x69, 0x66, 0x74, 0x00, 0x6d, 0x67, 0x6d, 0x74, 0x70, 0x6f,
+  0x72, 0x74, 0x00
+unsigned int zynqmp_dtb_len = 1443;
diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts
index 0000000000..65c7dcbba8
--- /dev/null
+++ b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts
@@ -0,0 +1,94 @@
+ * @file
+ * @brief This file provides the base ZynqMP device tree
+ * are met:
+/dts-v1/;
+	amba {
+		ranges;
+			phandle = <0x01>;
+			status = "okay";
+			status = "okay";
+			status = "okay";
+			status = "okay";
diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
index 0000000000..955bc5f154
--- /dev/null
+++ b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
@@ -0,0 +1,97 @@
+  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x04, 0x5f, 0x00, 0x00, 0x00, 0x38,
+  0x00, 0x00, 0x03, 0xd4, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
+  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8b,
+  0x00, 0x00, 0x03, 0x9c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+  0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
+  0x64, 0x65, 0x00
+unsigned int zynqmp_dtb_len = 1119;
diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp.h b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
index d937a313f2..bb7df94fd1 100644
--- a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
+++ b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
@@ -51,6 +51,7 @@
 #include <bsp/start.h>
+#include <rtems/termiostypes.h>
 #ifdef __cplusplus
 extern "C" {
@@ -62,6 +63,10 @@ extern "C" {
 #define BSP_RESET_SMC
 #define BSP_CPU_ON_USES_SMC
+#define BSP_FDT_IS_SUPPORTED
+extern unsigned int zynqmp_dtb_len;
+extern unsigned char zynqmp_dtb[];
  * @brief Zynq UltraScale+ MPSoC specific set up of the MMU.
@@ -83,6 +88,16 @@ uint32_t zynqmp_clock_i2c0(void);
 uint32_t zynqmp_clock_i2c1(void);
+ * @brief Zynq UltraScale+ MPSoC specific set up of a management console.
+ * Some systems may have a management interface which needs special
+ * initialization. Provide in the application to override the defaults in the
+ * BSP. This will only be called if the interface is found in the device tree.
+void zynqmp_configure_management_console(rtems_termios_device_context *base);
 #ifdef __cplusplus
 #endif /* __cplusplus */
diff --git a/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c b/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
index 33ca1eafab..e727f9b1de 100644
--- a/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
+++ b/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
@@ -50,6 +50,10 @@ zynqmp_mmu_config_table[] = {
     .begin = 0xfd000000U,
     .end = 0xffc00000U,
     .flags = AARCH64_MMU_DEVICE
+    .begin = 0x80000000U,
+    .end = 0x80100000U,
+    .flags = 0
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspcfc400xlp64.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/bspcfc400xlp64.yml
index 0000000000..1687ced857
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspcfc400xlp64.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+arch: aarch64
+bsp: xilinx_zynqmp_lp64_cfc400x
+build-type: bsp
+cflags: []
+copyrights:
+- Copyright (C) 2022 On-Line Applications Research (OAR)
+cppflags: []
+enabled-by: true
+family: xilinx-zynqmp
+includes: []
+install: []
+links:
+- role: build-dependency
+  uid: grp_zu3eg
+  uid: linkcmds_lp64
+  uid: objfdtcfc400x
+source: []
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml
index 6e0eafc871..18968cd43d 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml
@@ -17,5 +17,7 @@ links:
   uid: tstqemu
   uid: linkcmds_ilp32
+  uid: objfdtzynqmp
 source: []
 type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml
index 0d047e263c..86177d7fcd 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml
   uid: tstqemu
   uid: linkcmds_lp64
+  uid: objfdtzynqmp
 source: []
 type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3egilp32.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3egilp32.yml
index dd7d39fb94..cd0bb2b854 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3egilp32.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3egilp32.yml
@@ -15,5 +15,7 @@ links:
   uid: grp_zu3eg
   uid: linkcmds_ilp32
+  uid: objfdtzynqmp
 source: []
 type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3eglp64.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3eglp64.yml
index 073e91175b..19211dae15 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3eglp64.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3eglp64.yml
   uid: grp_zu3eg
   uid: linkcmds_lp64
+  uid: objfdtzynqmp
 source: []
 type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
index 4147613fc9..1a3b754d92 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
@@ -21,6 +21,7 @@ source:
 - bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
 - bsps/aarch64/shared/mmu/vmsav8-64.c
 - bsps/aarch64/xilinx-zynqmp/console/console.c
+- bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c
 - bsps/aarch64/xilinx-zynqmp/start/bspstart.c
 - bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
 - bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtcfc400x.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtcfc400x.yml
index 0000000000..53d93803cb
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtcfc400x.yml
@@ -0,0 +1,14 @@
+build-type: objects
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+install: []
+links: []
+source:
+- bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtzynqmp.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtzynqmp.yml
index 0000000000..271bb82976
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtzynqmp.yml
@@ -0,0 +1,14 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+install: []
+links: []
+source:
+- bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
index 0bdc2d61df..976a4aeb0e 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
@@ -11,6 +11,7 @@ default: 32768
 default-by-variant:
 - value: 0x0
   variants:
+  - aarch64/xilinx_zynqmp_lp64_cfc400x
   - aarch64/xilinx_zynqmp_lp64_zu3eg
   - aarch64/xilinx_zynqmp_ilp32_zu3eg
 description: |
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
index c17febe288..427f14c7c8 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
@@ -11,6 +11,7 @@ default: 0x40018000
 default-by-variant:
 - value: 0x10000000
   variants:
 description: |
diff --git a/spec/build/cpukit/optsmp.yml b/spec/build/cpukit/optsmp.yml
index b218364194..db404efe21 100644
--- a/spec/build/cpukit/optsmp.yml
+++ b/spec/build/cpukit/optsmp.yml
@@ -13,6 +13,7 @@ description: |
 enabled-by:
 - aarch64/xilinx_zynqmp_ilp32_qemu
+- aarch64/xilinx_zynqmp_lp64_cfc400x
 - aarch64/xilinx_zynqmp_lp64_qemu
 - arm/altcycv_devkit
2.30.2
