[PATCH v2] zynqmp: Add support for the CFC-400X
Wed Nov 9 00:51:05 UTC 2022
Looks good and thank you for sorting out this approach.
Thanks
On 9/11/2022 8:56 am, Kinsey Moore wrote:
> This adds a BSP variant for the ZynqMP BSP family to support the
> Innoflight CFC-400X platform. To properly support the CFC-400X, device
> trees were added to the ZynqMP platform due to both the optional
> management interface as well as alternate physical configuration of the
> ethernet interfaces.
>   bsps/aarch64/xilinx-zynqmp/console/console.c  | 163 +++++++++++++++++-
>   bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c      |  51 ++++++
>   bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts    | 110 ++++++++++++
>   bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c  | 124 +++++++++++++
>   bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts     |  94 ++++++++++
>   bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c   |  97 +++++++++++
>   bsps/aarch64/xilinx-zynqmp/include/bsp.h      |  15 ++
>   .../aarch64/xilinx-zynqmp/start/bspstartmmu.c |   4 +
>   .../aarch64/xilinx-zynqmp/bspcfc400xlp64.yml  |  21 +++
>   .../aarch64/xilinx-zynqmp/bspqemuilp32.yml    |   2 +
>   .../aarch64/xilinx-zynqmp/bspqemulp64.yml     |   2 +
>   .../aarch64/xilinx-zynqmp/bspzu3egilp32.yml   |   2 +
>   .../aarch64/xilinx-zynqmp/bspzu3eglp64.yml    |   2 +
>   spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml |   1 +
>   .../aarch64/xilinx-zynqmp/objfdtcfc400x.yml   |  14 ++
>   .../aarch64/xilinx-zynqmp/objfdtzynqmp.yml    |  14 ++
>   .../bsps/aarch64/xilinx-zynqmp/optloadoff.yml |   1 +
>   .../bsps/aarch64/xilinx-zynqmp/optramori.yml  |   1 +
>   spec/build/cpukit/optsmp.yml                  |   1 +
>   19 files changed, 718 insertions(+), 1 deletion(-)
>   create mode 100644 bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c
>   create mode 100644 bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts
>   create mode 100644 bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
>   create mode 100644 bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts
>   create mode 100644 bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
>   create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/bspcfc400xlp64.yml
>   create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/objfdtcfc400x.yml
>   create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/objfdtzynqmp.yml
> diff --git a/bsps/aarch64/xilinx-zynqmp/console/console.c b/bsps/aarch64/xilinx-zynqmp/console/console.c
> index d1948f1a0c..d546db8535 100644
> --- a/bsps/aarch64/xilinx-zynqmp/console/console.c
> +++ b/bsps/aarch64/xilinx-zynqmp/console/console.c
> @@ -9,7 +9,7 @@
> - * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
> + * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
>    * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
>    * Redistribution and use in source and binary forms, with or without
> @@ -36,13 +36,165 @@
>   #include <rtems/console.h>
>   #include <rtems/bspIo.h>
> +#include <rtems/endian.h>
> +#include <rtems/rtems-fdt.h>
>   #include <rtems/sysinit.h>
> +#include <bsp/aarch64-mmu.h>
> +#include <bsp/fdt.h>
>   #include <bsp/irq.h>
>   #include <dev/serial/zynq-uart.h>
>   #include <bspopts.h>
> +#include <libchip/ns16550.h>
> +uint32_t mgmt_uart_reg_shift = 0;
> +static uint8_t get_register(uintptr_t addr, uint8_t i)
> +  volatile uint8_t *reg = (uint8_t *) addr;
> +  i <<= mgmt_uart_reg_shift;
> +  return reg [i];
> +static void set_register(uintptr_t addr, uint8_t i, uint8_t val)
> +  reg [i] = val;
> +static ns16550_context zynqmp_mgmt_uart_context = {
> +  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("Management UART 0"),
> +  .get_reg = get_register,
> +  .set_reg = set_register,
> +  .port = 0,
> +  .irq = 0,
> +  .clock = 0,
> +  .initial_baud = 0,
> +__attribute__ ((weak)) void zynqmp_configure_management_console(rtems_termios_device_context *base)
> +  /* This SLIP-encoded watchdog command sets timeouts to 0xFFFFFFFF seconds. */
> +  const char mgmt_watchdog_cmd[] =
> +    "\xc0\xda\x00\x00\xff\xff\xff\xff\xff\x00\xff\xff\xff\xffM#\xc0";
> +  /* Send the system watchdog configuration command */
> +  for (int i = 0; i < sizeof(mgmt_watchdog_cmd); i++) {
> +    ns16550_polled_putchar(base, mgmt_watchdog_cmd[i]);
> +static void zynqmp_management_console_init(void)
> +  /* Find the management console in the device tree */
> +  rtems_fdt_handle fdt_handle;
> +  const uint32_t *prop;
> +  uint32_t outprop[4];
> +  int proplen;
> +  int node;
> +  rtems_fdt_init_handle(&fdt_handle);
> +  rtems_fdt_register(bsp_fdt_get(), &fdt_handle);
> +  const char *alias = rtems_fdt_get_alias(&fdt_handle, "mgmtport");
> +  if (alias == NULL) {
> +    rtems_fdt_release_handle(&fdt_handle);
> +    return;
> +  node = rtems_fdt_path_offset(&fdt_handle, alias);
> +  prop = rtems_fdt_getprop(&fdt_handle, node, "clock-frequency", &proplen);
> +  if ( prop == NULL || proplen != 4 ) {
> +    zynqmp_mgmt_uart_context.port = 0;
> +    return;
> +  outprop[0] = rtems_uint32_from_big_endian((const uint8_t *) &prop[0]);
> +  zynqmp_mgmt_uart_context.clock = outprop[0];
> +  prop = rtems_fdt_getprop(&fdt_handle, node, "current-speed", &proplen);
> +    return;
> +  zynqmp_mgmt_uart_context.initial_baud = outprop[0];
> +  prop = rtems_fdt_getprop(&fdt_handle, node, "interrupts", &proplen);
> +  if ( prop == NULL || proplen != 12 ) {
> +    return;
> +  outprop[1] = rtems_uint32_from_big_endian((const uint8_t *) &prop[1]);
> +  outprop[2] = rtems_uint32_from_big_endian((const uint8_t *) &prop[2]);
> +  /* proplen is in bytes, interrupt mapping expects a length in 32-bit cells */
> +  zynqmp_mgmt_uart_context.irq = bsp_fdt_map_intr(outprop, proplen / 4);
> +  if ( zynqmp_mgmt_uart_context.irq == 0 ) {
> +    return;
> +  prop = rtems_fdt_getprop(&fdt_handle, node, "reg", &proplen);
> +  if ( prop == NULL || proplen != 16 ) {
> +    return;
> +  outprop[3] = rtems_uint32_from_big_endian((const uint8_t *) &prop[3]);
> +  zynqmp_mgmt_uart_context.port = ( ( (uint64_t) outprop[0] ) << 32 ) | outprop[1];
> +  uintptr_t uart_base = zynqmp_mgmt_uart_context.port;
> +  size_t uart_size = ( ( (uint64_t) outprop[2] ) << 32 ) | outprop[3];
> +  rtems_status_code sc = aarch64_mmu_map( uart_base,
> +                                          uart_size,
> +                                          AARCH64_MMU_DEVICE);
> +  if ( sc != RTEMS_SUCCESSFUL ) {
> +    return;
> +  prop = rtems_fdt_getprop(&fdt_handle, node, "reg-offset", &proplen);
> +    return;
> +  zynqmp_mgmt_uart_context.port += outprop[0];
> +  prop = rtems_fdt_getprop(&fdt_handle, node, "reg-shift", &proplen);
> +    return;
> +  mgmt_uart_reg_shift = outprop[0];
> +  ns16550_probe(&zynqmp_mgmt_uart_context.base);
> +  zynqmp_configure_management_console(&zynqmp_mgmt_uart_context.base);
> +RTEMS_SYSINIT_ITEM(
> +  zynqmp_management_console_init,
> +  RTEMS_SYSINIT_BSP_START,
> +  RTEMS_SYSINIT_ORDER_FIRST
>   static zynq_uart_context zynqmp_uart_instances[2] = {
>       .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 0" ),
> @@ -81,6 +233,15 @@ rtems_status_code console_initialize(
> +  if ( zynqmp_mgmt_uart_context.port != 0 ) {
> +    rtems_termios_device_install(
> +      "/dev/ttyMGMT0",
> +      &ns16550_handler_polled,
> +      NULL,
> +      &zynqmp_mgmt_uart_context.base
>     return RTEMS_SUCCESSFUL;
> diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c b/bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c
> new file mode 100644
> index 0000000000..0748639256
> --- /dev/null
> +++ b/bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c
> @@ -0,0 +1,51 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup RTEMSBSPsAArch64XilinxZynqMP
> + * @brief This source file contains the implementatin of bsp_fdt_get().
> + * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#include <bsp.h>
> +const void *bsp_fdt_get(void)
> +  return zynqmp_dtb;
> +uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells)
> +  if (icells != 3) {
> +    return 0;
> +  return (intr[0] == 0 ? 32 : 16) + intr[1];
> diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts
> index 0000000000..763a668a5c
> --- /dev/null
> +++ b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts
> @@ -0,0 +1,110 @@
> + * @file
> + * @brief This file provides the CFC-400X device tree
> + * are met:
> +/dts-v1/;
> +	#address-cells = <0x02>;
> +	#size-cells = <0x02>;
> +	amba {
> +		compatible = "simple-bus";
> +		ranges;
> +		interrupt-controller at f9010000 {
> +			compatible = "arm,gic-400";
> +			#interrupt-cells = <0x03>;
> +			reg = <0x00 0xf9010000 0x00 0x10000>;
> +			interrupt-controller;
> +			phandle = <0x01>;
> +		ethernet at ff0b0000 {
> +			compatible = "cdns,gem";
> +			status = "okay";
> +			interrupt-parent = <0x01>;
> +			interrupts = <0x00 0x39 0x04>;
> +			reg = <0x00 0xff0b0000 0x00 0x1000>;
> +			phy-mode = "sgmii";
> +		ethernet at ff0c0000 {
> +			status = "okay";
> +			interrupts = <0x00 0x3b 0x04>;
> +			reg = <0x00 0xff0c0000 0x00 0x1000>;
> +		ethernet at ff0d0000 {
> +			status = "okay";
> +			interrupts = <0x00 0x3d 0x04>;
> +			reg = <0x00 0xff0d0000 0x00 0x1000>;
> +		ethernet at ff0e0000 {
> +			status = "okay";
> +			interrupts = <0x00 0x3f 0x04>;
> +			reg = <0x00 0xff0e0000 0x00 0x1000>;
> +		serial at 800a0000 {
> +			clock-frequency = <0x189c000>;
> +			compatible = "ns16550a";
> +			current-speed = <0x1c200>;
> +			device_type = "serial";
> +			interrupts = <0x00 0x6e 0x04>;
> +			reg = <0x00 0x800a0000 0x00 0x10000>;
> +			reg-offset = <0x1000>;
> +			reg-shift = <0x02>;
> +	aliases {
> +		mgmtport = "/amba/serial at 800a0000";
> diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
> index 0000000000..2d0078678e
> --- /dev/null
> +++ b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
> @@ -0,0 +1,124 @@
> +unsigned char zynqmp_dtb[] = {
> +  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x05, 0xa3, 0x00, 0x00, 0x00, 0x38,
> +  0x00, 0x00, 0x04, 0xd0, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
> +  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xd3,
> +  0x00, 0x00, 0x04, 0x98, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x01, 0x61, 0x6d, 0x62, 0x61, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x1b,
> +  0x73, 0x69, 0x6d, 0x70, 0x6c, 0x65, 0x2d, 0x62, 0x75, 0x73, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x26, 0x00, 0x00, 0x00, 0x01,
> +  0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x63, 0x6f,
> +  0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x40, 0x66, 0x39, 0x30,
> +  0x31, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x1b, 0x61, 0x72, 0x6d, 0x2c,
> +  0x67, 0x69, 0x63, 0x2d, 0x34, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x2d,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
> +  0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0xf9, 0x01, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x57, 0x00, 0x00, 0x00, 0x01,
> +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x65, 0x74, 0x68, 0x65,
> +  0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30, 0x62, 0x30, 0x30, 0x30,
> +  0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09,
> +  0x00, 0x00, 0x00, 0x1b, 0x63, 0x64, 0x6e, 0x73, 0x2c, 0x67, 0x65, 0x6d,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05,
> +  0x00, 0x00, 0x00, 0x5f, 0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x66,
> +  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c,
> +  0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x39,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
> +  0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0xff, 0x0b, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x82, 0x73, 0x67, 0x6d, 0x69,
> +  0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
> +  0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30,
> +  0x63, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b, 0x63, 0x64, 0x6e, 0x73,
> +  0x2c, 0x67, 0x65, 0x6d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x5f, 0x6f, 0x6b, 0x61, 0x79,
> +  0x00, 0x00, 0x00, 0x66, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x3b, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00,
> +  0xff, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x82,
> +  0x73, 0x67, 0x6d, 0x69, 0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x01, 0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74,
> +  0x40, 0x66, 0x66, 0x30, 0x64, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b,
> +  0x63, 0x64, 0x6e, 0x73, 0x2c, 0x67, 0x65, 0x6d, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x5f,
> +  0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x66, 0x00, 0x00, 0x00, 0x01,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x77,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3d, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x3e,
> +  0x00, 0x00, 0x00, 0x00, 0xff, 0x0d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x06,
> +  0x00, 0x00, 0x00, 0x82, 0x73, 0x67, 0x6d, 0x69, 0x69, 0x00, 0x00, 0x00,
> +  0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30, 0x65, 0x30, 0x30, 0x30,
> +  0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f,
> +  0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0xff, 0x0e, 0x00, 0x00,
> +  0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40, 0x38, 0x30, 0x30, 0x61, 0x30,
> +  0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x00, 0x8b, 0x01, 0x89, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b, 0x6e, 0x73, 0x31, 0x36,
> +  0x35, 0x35, 0x30, 0x61, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x9b, 0x00, 0x01, 0xc2, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0xa9,
> +  0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x6e, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x00, 0x00, 0x80, 0x0a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
> +  0x61, 0x6c, 0x69, 0x61, 0x73, 0x65, 0x73, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x16, 0x00, 0x00, 0x00, 0xca, 0x2f, 0x61, 0x6d, 0x62,
> +  0x61, 0x2f, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40, 0x38, 0x30, 0x30,
> +  0x61, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x09, 0x23, 0x61, 0x64, 0x64,
> +  0x72, 0x65, 0x73, 0x73, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23,
> +  0x73, 0x69, 0x7a, 0x65, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x63,
> +  0x6f, 0x6d, 0x70, 0x61, 0x74, 0x69, 0x62, 0x6c, 0x65, 0x00, 0x72, 0x61,
> +  0x6e, 0x67, 0x65, 0x73, 0x00, 0x23, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72,
> +  0x75, 0x70, 0x74, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x72, 0x65,
> +  0x67, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d,
> +  0x63, 0x6f, 0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x70,
> +  0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65, 0x00, 0x73, 0x74, 0x61, 0x74, 0x75,
> +  0x73, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d,
> +  0x70, 0x61, 0x72, 0x65, 0x6e, 0x74, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72,
> +  0x72, 0x75, 0x70, 0x74, 0x73, 0x00, 0x70, 0x68, 0x79, 0x2d, 0x6d, 0x6f,
> +  0x64, 0x65, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x66, 0x72, 0x65,
> +  0x71, 0x75, 0x65, 0x6e, 0x63, 0x79, 0x00, 0x63, 0x75, 0x72, 0x72, 0x65,
> +  0x6e, 0x74, 0x2d, 0x73, 0x70, 0x65, 0x65, 0x64, 0x00, 0x64, 0x65, 0x76,
> +  0x69, 0x63, 0x65, 0x5f, 0x74, 0x79, 0x70, 0x65, 0x00, 0x72, 0x65, 0x67,
> +  0x2d, 0x6f, 0x66, 0x66, 0x73, 0x65, 0x74, 0x00, 0x72, 0x65, 0x67, 0x2d,
> +  0x73, 0x68, 0x69, 0x66, 0x74, 0x00, 0x6d, 0x67, 0x6d, 0x74, 0x70, 0x6f,
> +  0x72, 0x74, 0x00
> +unsigned int zynqmp_dtb_len = 1443;
> diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts
> index 0000000000..65c7dcbba8
> --- /dev/null
> +++ b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts
> @@ -0,0 +1,94 @@
> + * @file
> + * @brief This file provides the base ZynqMP device tree
> + * are met:
> +/dts-v1/;
> +	amba {
> +		ranges;
> +			phandle = <0x01>;
> +			status = "okay";
> +			status = "okay";
> +			status = "okay";
> +			status = "okay";
> diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
> index 0000000000..955bc5f154
> --- /dev/null
> +++ b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
> @@ -0,0 +1,97 @@
> +  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x04, 0x5f, 0x00, 0x00, 0x00, 0x38,
> +  0x00, 0x00, 0x03, 0xd4, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
> +  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8b,
> +  0x00, 0x00, 0x03, 0x9c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> +  0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
> +  0x64, 0x65, 0x00
> +unsigned int zynqmp_dtb_len = 1119;
> diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp.h b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> index d937a313f2..bb7df94fd1 100644
> --- a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> +++ b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> @@ -51,6 +51,7 @@
>   #include <bsp/start.h>
>   #include <rtems.h>
> +#include <rtems/termiostypes.h>
>   #ifdef __cplusplus
>   extern "C" {
> @@ -62,6 +63,10 @@ extern "C" {
>   #define BSP_RESET_SMC
>   #define BSP_CPU_ON_USES_SMC
> +#define BSP_FDT_IS_SUPPORTED
> +extern unsigned int zynqmp_dtb_len;
> +extern unsigned char zynqmp_dtb[];
>    * @brief Zynq UltraScale+ MPSoC specific set up of the MMU.
> @@ -83,6 +88,16 @@ uint32_t zynqmp_clock_i2c0(void);
>   uint32_t zynqmp_clock_i2c1(void);
> + * @brief Zynq UltraScale+ MPSoC specific set up of a management console.
> + * Some systems may have a management interface which needs special
> + * initialization. Provide in the application to override the defaults in the
> + * BSP. This will only be called if the interface is found in the device tree.
> +void zynqmp_configure_management_console(rtems_termios_device_context *base);
>   #ifdef __cplusplus
>   #endif /* __cplusplus */
> diff --git a/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c b/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
> index 33ca1eafab..e727f9b1de 100644
> --- a/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
> +++ b/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
> @@ -50,6 +50,10 @@ zynqmp_mmu_config_table[] = {
>       .begin = 0xfd000000U,
>       .end = 0xffc00000U,
>       .flags = AARCH64_MMU_DEVICE
> +    .begin = 0x80000000U,
> +    .end = 0x80100000U,
> +    .flags = 0
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspcfc400xlp64.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/bspcfc400xlp64.yml
> index 0000000000..1687ced857
> --- /dev/null
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspcfc400xlp64.yml
> @@ -0,0 +1,21 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +arch: aarch64
> +bsp: xilinx_zynqmp_lp64_cfc400x
> +build-type: bsp
> +cflags: []
> +copyrights:
> +- Copyright (C) 2022 On-Line Applications Research (OAR)
> +cppflags: []
> +enabled-by: true
> +family: xilinx-zynqmp
> +includes: []
> +install: []
> +links:
> +- role: build-dependency
> +  uid: grp_zu3eg
> +  uid: linkcmds_lp64
> +  uid: objfdtcfc400x
> +source: []
> +type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml
> index 6e0eafc871..18968cd43d 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml
> @@ -17,5 +17,7 @@ links:
>     uid: tstqemu
>     uid: linkcmds_ilp32
> +  uid: objfdtzynqmp
>   source: []
>   type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml
> index 0d047e263c..86177d7fcd 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml
>     uid: tstqemu
>     uid: linkcmds_lp64
> +  uid: objfdtzynqmp
>   source: []
>   type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3egilp32.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3egilp32.yml
> index dd7d39fb94..cd0bb2b854 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3egilp32.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3egilp32.yml
> @@ -15,5 +15,7 @@ links:
>     uid: grp_zu3eg
>     uid: linkcmds_ilp32
> +  uid: objfdtzynqmp
>   source: []
>   type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3eglp64.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3eglp64.yml
> index 073e91175b..19211dae15 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3eglp64.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3eglp64.yml
>     uid: grp_zu3eg
>     uid: linkcmds_lp64
> +  uid: objfdtzynqmp
>   source: []
>   type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
> index 4147613fc9..1a3b754d92 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
> @@ -21,6 +21,7 @@ source:
>   - bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
>   - bsps/aarch64/shared/mmu/vmsav8-64.c
>   - bsps/aarch64/xilinx-zynqmp/console/console.c
> +- bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c
>   - bsps/aarch64/xilinx-zynqmp/start/bspstart.c
>   - bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
>   - bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtcfc400x.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtcfc400x.yml
> index 0000000000..53d93803cb
> --- /dev/null
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtcfc400x.yml
> @@ -0,0 +1,14 @@
> +build-type: objects
> +cflags: []
> +copyrights:
> +cppflags: []
> +cxxflags: []
> +enabled-by: true
> +includes: []
> +install: []
> +links: []
> +source:
> +- bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
> +type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtzynqmp.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtzynqmp.yml
> index 0000000000..271bb82976
> --- /dev/null
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtzynqmp.yml
> @@ -0,0 +1,14 @@
> +cflags: []
> +copyrights:
> +cppflags: []
> +cxxflags: []
> +enabled-by: true
> +includes: []
> +install: []
> +links: []
> +source:
> +- bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
> +type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
> index 0bdc2d61df..976a4aeb0e 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
> @@ -11,6 +11,7 @@ default: 32768
>   default-by-variant:
>   - value: 0x0
>     variants:
> +  - aarch64/xilinx_zynqmp_lp64_cfc400x
>     - aarch64/xilinx_zynqmp_lp64_zu3eg
>     - aarch64/xilinx_zynqmp_ilp32_zu3eg
>   description: |
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
> index c17febe288..427f14c7c8 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
> @@ -11,6 +11,7 @@ default: 0x40018000
>   default-by-variant:
>   - value: 0x10000000
>     variants:
>   description: |
> diff --git a/spec/build/cpukit/optsmp.yml b/spec/build/cpukit/optsmp.yml
> index b218364194..db404efe21 100644
> --- a/spec/build/cpukit/optsmp.yml
> +++ b/spec/build/cpukit/optsmp.yml
> @@ -13,6 +13,7 @@ description: |
>   enabled-by:
>   - aarch64/xilinx_zynqmp_ilp32_qemu
> +- aarch64/xilinx_zynqmp_lp64_cfc400x
>   - aarch64/xilinx_zynqmp_lp64_qemu
>   - arm/altcycv_devkit
