[PATCH rtems-libbsd v2 2/3] freebsd/cgem: Add device tree support
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Nov 9 05:10:55 UTC 2022
This reintroduces device tree support to the CGEM driver while
preserving the ability to statically define CGEM interfaces.
freebsd/sys/dev/cadence/if_cgem.c | 42 +++++++++++++++++++++----------
1 file changed, 29 insertions(+), 13 deletions(-)
diff --git a/freebsd/sys/dev/cadence/if_cgem.c b/freebsd/sys/dev/cadence/if_cgem.c
index 3eaaf6b2..047d9104 100644
--- a/freebsd/sys/dev/cadence/if_cgem.c
+++ b/freebsd/sys/dev/cadence/if_cgem.c
@@ -72,11 +72,9 @@ __FBSDID("$FreeBSD$");
#include <net/bpf.h>
#include <net/bpfdesc.h>
-#ifndef __rtems__
#include <dev/fdt/fdt_common.h>
#include <dev/ofw/ofw_bus.h>
#include <dev/ofw/ofw_bus_subr.h>
-#endif /* __rtems__ */
#include <dev/mii/mii.h>
#include <dev/mii/miivar.h>
@@ -92,6 +90,7 @@ __FBSDID("$FreeBSD$");
#pragma GCC diagnostic ignored "-Wpointer-sign"
#pragma GCC diagnostic ignored "-Wincompatible-pointer-types"
#include <rtems/bsd/bsd.h>
+#include <rtems/bsd/local/opt_platform.h>
#define IF_CGEM_NAME "cgem"
@@ -111,13 +110,14 @@ __FBSDID("$FreeBSD$");
#define CGEM_CKSUM_ASSIST (CSUM_IP | CSUM_TCP | CSUM_UDP | \
CSUM_TCP_IPV6 | CSUM_UDP_IPV6)
-#ifndef __rtems__
static struct ofw_compat_data compat_data[] = {
{ "cadence,gem", 1 },
{ "cdns,macb", 1 },
+#ifdef __rtems__
+ { "cdns,gem", 1 },
+#endif
{ NULL, 0 },
struct cgem_softc {
if_t ifp;
@@ -1947,13 +1947,20 @@ static int
cgem_probe(device_t dev)
-#ifndef __rtems__
+#ifdef __rtems__
+#ifdef FDT
+ if (bsp_fdt_get()) {
+#else
+ if (0) {
+#endif
+#endif /* __rtems__ */
if (!ofw_bus_status_okay(dev))
return (ENXIO);
if (ofw_bus_search_compatible(dev, compat_data)->ocd_data == 0)
return (ENXIO);
-#else /* __rtems__ */
+#ifdef __rtems__
struct cgem_softc *sc = device_get_softc(dev);
int val, rid = 0;
@@ -1983,24 +1990,34 @@ cgem_attach(device_t dev)
if_t ifp = NULL;
-#ifndef __rtems__
phandle_t node;
pcell_t cell;
int rid, err;
u_char eaddr[ETHER_ADDR_LEN];
sc->dev = dev;
CGEM_LOCK_INIT(sc);
-#ifndef __rtems__
+#ifdef __rtems__
+#ifdef FDT
+#else
+ if (0) {
+#endif
/* Get reference clock number and base divider from fdt. */
node = ofw_bus_get_node(dev);
sc->ref_clk_num = 0;
if (OF_getprop(node, "ref-clock-num", &cell, sizeof(cell)) > 0)
sc->ref_clk_num = fdt32_to_cpu(cell);
- sc->ref_clk_num = device_get_unit(dev);
+#ifdef __rtems__
+ /* Else for ref-clock-num OF_getprop */
+ else
+ sc->ref_clk_num = device_get_unit(dev);
+ } else {
+ sc->phy_contype = MII_CONTYPE_RGMII_ID;
/* Get memory resource. */
@@ -2228,9 +2245,8 @@ static driver_t cgem_driver = {
sizeof(struct cgem_softc),
-#ifndef __rtems__
DRIVER_MODULE(cgem, simplebus, cgem_driver, cgem_devclass, NULL, NULL);
+#ifdef __rtems__
DRIVER_MODULE(cgem, nexus, cgem_driver, cgem_devclass, NULL, NULL);
DRIVER_MODULE(miibus, cgem, miibus_driver, miibus_devclass, NULL, NULL);
2.30.2
