[PATCH rtems-libbsd v2 3/3] freebsd/cgem: Add SGMII support
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Nov 9 05:10:56 UTC 2022
This adds support to the CGEM driver for selection of SGMII PHY
interfaces specified via device tree parameters.
freebsd/sys/dev/cadence/if_cgem.c | 10 ++++++++++
1 file changed, 10 insertions(+)
diff --git a/freebsd/sys/dev/cadence/if_cgem.c b/freebsd/sys/dev/cadence/if_cgem.c
index 047d9104..689c3611 100644
--- a/freebsd/sys/dev/cadence/if_cgem.c
+++ b/freebsd/sys/dev/cadence/if_cgem.c
@@ -134,6 +134,7 @@ struct cgem_softc {
#ifdef __rtems__
uint32_t net_cfg_shadow;
int neednullqs;
+ int phy_contype;
#endif /* __rtems__ */
int ref_clk_num;
#ifndef __rtems__
@@ -1296,6 +1297,14 @@ cgem_config(struct cgem_softc *sc)
CGEM_NET_CFG_FULL_DUPLEX |
CGEM_NET_CFG_SPEED100;
+#ifdef __rtems__
+ /* Check connection type, enable SGMII bits if necessary. */
+ if ( sc->phy_contype == MII_CONTYPE_SGMII ) {
+ net_cfg |= CGEM_NET_CFG_SGMII_EN;
+ net_cfg |= CGEM_NET_CFG_PCS_SEL;
+#endif
/* Enable receive checksum offloading? */
if ((if_getcapenable(ifp) & IFCAP_RXCSUM) != 0)
net_cfg |= CGEM_NET_CFG_RX_CHKSUM_OFFLD_EN;
@@ -2014,6 +2023,7 @@ cgem_attach(device_t dev)
/* Else for ref-clock-num OF_getprop */
else
sc->ref_clk_num = device_get_unit(dev);
+ sc->phy_contype = mii_fdt_get_contype(node);
} else {
sc->phy_contype = MII_CONTYPE_RGMII_ID;
2.30.2
