[PATCH 06/10] bsps/riscv: bsp_interrupt_is_pending()
Sebastian Huber
Wed Nov 9 16:09:16 UTC 2022
Implement this function.
bsps/riscv/riscv/irq/irq.c | 27 +++++++++++++++++++++++++--
1 file changed, 25 insertions(+), 2 deletions(-)
diff --git a/bsps/riscv/riscv/irq/irq.c b/bsps/riscv/riscv/irq/irq.c
index a48ba2346c..2e68551ae5 100644
--- a/bsps/riscv/riscv/irq/irq.c
+++ b/bsps/riscv/riscv/irq/irq.c
@@ -48,6 +48,8 @@
#include <libfdt.h>
+volatile RISCV_PLIC_regs *riscv_plic;
volatile RISCV_CLINT_regs *riscv_clint;
@@ -186,6 +188,8 @@ static void riscv_plic_init(const void *fdt)
#endif
+ riscv_plic = plic;
val = fdt_getprop(fdt, node, "riscv,ndev", &len);
if (val == NULL || len != 4) {
bsp_fatal(RISCV_FATAL_INVALID_PLIC_NDEV_IN_DEVICE_TREE);
@@ -319,8 +323,27 @@ rtems_status_code bsp_interrupt_is_pending(
bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
bsp_interrupt_assert(pending != NULL);
- *pending = false;
- return RTEMS_UNSATISFIED;
+ if (RISCV_INTERRUPT_VECTOR_IS_EXTERNAL(vector)) {
+ uint32_t interrupt_index;
+ uint32_t group;
+ uint32_t bit;
+ interrupt_index = RISCV_INTERRUPT_VECTOR_EXTERNAL_TO_INDEX(vector);
+ group = interrupt_index / 32;
+ bit = UINT32_C(1) << (interrupt_index % 32);
+ *pending = ((riscv_plic->pending[group] & bit) != 0);
+ return RTEMS_SUCCESSFUL;
+ if (vector == RISCV_INTERRUPT_VECTOR_TIMER) {
+ *pending = (read_csr(mip) & MIP_MTIP) != 0;
+ _Assert(vector == RISCV_INTERRUPT_VECTOR_SOFTWARE);
+ *pending = (read_csr(mip) & MIP_MSIP) != 0;
rtems_status_code bsp_interrupt_raise(rtems_vector_number vector)
2.35.3
