[PATCH 05/10] bsps/riscv: bsp_interrupt_get_attributes()
Sebastian Huber
Wed Nov 9 16:09:15 UTC 2022
Implement this function.
bsps/riscv/riscv/irq/irq.c | 15 +++++++++++++++
1 file changed, 15 insertions(+)
diff --git a/bsps/riscv/riscv/irq/irq.c b/bsps/riscv/riscv/irq/irq.c
index 238cb7f62a..a48ba2346c 100644
--- a/bsps/riscv/riscv/irq/irq.c
+++ b/bsps/riscv/riscv/irq/irq.c
@@ -294,6 +294,21 @@ rtems_status_code bsp_interrupt_get_attributes(
rtems_interrupt_attributes *attributes
+ attributes->is_maskable = true;
+ attributes->can_enable = true;
+ attributes->maybe_enable = true;
+ attributes->can_disable = true;
+ attributes->maybe_disable = true;
+ attributes->can_raise = (vector == RISCV_INTERRUPT_VECTOR_SOFTWARE);
+ attributes->can_raise_on = attributes->can_raise;
+ attributes->cleared_by_acknowledge = true;
+ attributes->can_get_affinity = RISCV_INTERRUPT_VECTOR_IS_EXTERNAL(vector);
+ attributes->can_set_affinity = attributes->can_get_affinity;
+ if (vector == RISCV_INTERRUPT_VECTOR_SOFTWARE) {
+ attributes->trigger_signal = RTEMS_INTERRUPT_NO_SIGNAL;
return RTEMS_SUCCESSFUL;
2.35.3
