[PATCH 09/10] bsps/riscv: Always dispatch software interrupts
Wed Nov 9 16:09:19 UTC 2022
This helps to run the interrupt API validation tests.
 bsps/riscv/riscv/irq/irq.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/bsps/riscv/riscv/irq/irq.c b/bsps/riscv/riscv/irq/irq.c
index 44d0778ec7..c8b0801cc3 100644
--- a/bsps/riscv/riscv/irq/irq.c
+++ b/bsps/riscv/riscv/irq/irq.c
@@ -99,7 +99,6 @@ void _RISCV_Interrupt_dispatch(uintptr_t mcause, Per_CPU_Control *cpu_self)
       __asm__ volatile ("fence o, i" : : : "memory");
   } else if (mcause == (RISCV_INTERRUPT_SOFTWARE_MACHINE << 1)) {
-#ifdef RTEMS_SMP
      * Clear the software interrupt on this processor.  Synchronization of
      * inter-processor interrupts is done via Per_CPU_Control::message in
@@ -107,10 +106,10 @@ void _RISCV_Interrupt_dispatch(uintptr_t mcause, Per_CPU_Control *cpu_self)
     *cpu_self->cpu_per_cpu.clint_msip = 0;
+#ifdef RTEMS_SMP
     _SMP_Inter_processor_interrupt_handler(cpu_self);
-#else
-    bsp_interrupt_handler_dispatch(RISCV_INTERRUPT_VECTOR_SOFTWARE);
 #endif
+    bsp_interrupt_handler_dispatch(RISCV_INTERRUPT_VECTOR_SOFTWARE);
   } else {
     bsp_fatal(RISCV_FATAL_UNEXPECTED_INTERRUPT_EXCEPTION);
2.35.3
