[PATCH 10/10] bsps/riscv: Add tm27 support
Sebastian Huber
Wed Nov 9 16:09:20 UTC 2022
bsps/riscv/riscv/include/tm27.h | 137 +++++++++++++++++++++++++++++++-
1 file changed, 136 insertions(+), 1 deletion(-)
diff --git a/bsps/riscv/riscv/include/tm27.h b/bsps/riscv/riscv/include/tm27.h
index 0dfa7bf628..3e092214e5 100644
--- a/bsps/riscv/riscv/include/tm27.h
+++ b/bsps/riscv/riscv/include/tm27.h
@@ -1 +1,136 @@
-#include <rtems/tm27-default.h>
+ * @file
+ * @ingroup RTEMSBSPsRISCVGeneric
+ * @brief This header file contains the generic RISC-V tm27 support
+ * implementation.
+ * Copyright (C) 2022 embedded brains GmbH
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef _RTEMS_TMTEST27
+#error "This is an RTEMS internal file you must not include directly."
+#endif
+#ifndef __tm27_h
+#define __tm27_h
+#include <bsp/irq-generic.h>
+#include <rtems/score/assert.h>
+#include <rtems/score/riscv-utility.h>
+#include <rtems/score/percpu.h>
+#define MUST_WAIT_FOR_INTERRUPT 1
+static bool riscv_tm27_can_use_mtime;
+static rtems_interrupt_entry riscv_tm27_interrupt_entry;
+static inline void Install_tm27_vector(
+ void ( *handler )( rtems_vector_number )
+ rtems_vector_number irq;
+ bool enabled;
+ irq = RISCV_INTERRUPT_VECTOR_TIMER;
+ enabled = false;
+ rtems_interrupt_vector_is_enabled( irq, &enabled );
+ if ( enabled ) {
+ irq = RISCV_INTERRUPT_VECTOR_SOFTWARE;
+ } else {
+ riscv_tm27_can_use_mtime = true;
+ rtems_interrupt_entry_initialize(
+ &riscv_tm27_interrupt_entry,
+ (rtems_interrupt_handler) handler,
+ NULL,
+ "tm27"
+ (void) rtems_interrupt_entry_install(
+ irq,
+ RTEMS_INTERRUPT_SHARED,
+static inline void Cause_tm27_intr( void )
+ if ( riscv_tm27_can_use_mtime ) {
+ rtems_interrupt_level level;
+ Per_CPU_Control *cpu_self;
+ rtems_interrupt_local_disable( level );
+ cpu_self = _Per_CPU_Get();
+ cpu_self->cpu_per_cpu.clint_mtimecmp->val_64 = 0;
+ rtems_interrupt_local_enable( level );
+ } else {
+ (void) rtems_interrupt_raise( RISCV_INTERRUPT_VECTOR_SOFTWARE );
+static inline void Clear_tm27_intr( void )
+ cpu_self->cpu_per_cpu.clint_mtimecmp->val_64 = UINT64_MAX;
+ } else {
+ (void) rtems_interrupt_clear( RISCV_INTERRUPT_VECTOR_SOFTWARE );
+static inline void Lower_tm27_intr( void )
+ * This is an ugly hack just to for tm27. The support for nested interrupts
+ * is currently quite bad on RISC-V.
+ if ( bsp_interrupt_handler_table[ irq ] == NULL ) {
+ _Assert( riscv_tm27_can_use_mtime );
+ bsp_interrupt_handler_table[ irq ] = &riscv_tm27_interrupt_entry;
+ (void) rtems_interrupt_vector_enable( irq );
+ _ISR_Set_level( 0 );
+ (void) rtems_interrupt_raise( irq );
+#endif
2.35.3
