[PATCH v2] zynqmp: Add support for the CFC-400X
Kinsey Moore kinsey.moore at oarcorp.com
Thu Nov 10 13:55:05 UTC 2022
Hi Padmarao,
More compatibles can be added later if necessary to both the device tree in
RTEMS and the driver in RTEMS-LibBSD, but I don't see the need for either
at the moment since the ethernet portion of the device tree is intended to
be used with RTEMS-LibBSD directly. As far as the driver in 6-freebsd-12 is
concerned, all compatibles are currently equivalent and it already supports
"cdns,macb" if a BSP chooses to use that compatible. This may change when
we upgrade to the FreeBSD 13 code since the driver has gained more advanced
support for differentiating among compatibles and hardware quirks, but the
list of supported compatibles will only expand.
Kinsey
On Thu, Nov 10, 2022 at 6:50 AM <Padmarao.Begari at microchip.com> wrote:
> Hi Kinsey,
> The ethernet compatible "cdns,gem" is mentioned in the device tree,
> even I used same for PolarFire SoC BSP but later realised that common
> compatible for the candence GEM is "cdns,macb" used in U-Boot and
> Linux.
> Can we go with compatible "cdns,gem"? or will we update with
> "cdns,macb" later?
> Regards
> Padmarao
> > +               ethernet at ff0b0000 {
> > +                       compatible = "cdns,gem";
> > +                       status = "okay";
> > +                       interrupt-parent = <0x01>;
> > +                       interrupts = <0x00 0x39 0x04>;
> > +                       reg = <0x00 0xff0b0000 0x00 0x1000>;
> > +                       phy-mode = "sgmii";
> > On Tue, 2022-11-08 at 15:56 -0600, Kinsey Moore wrote:
> > This adds a BSP variant for the ZynqMP BSP family to support the
> > Innoflight CFC-400X platform. To properly support the CFC-400X,
> > device
> > trees were added to the ZynqMP platform due to both the optional
> > management interface as well as alternate physical configuration of
> > the
> > ethernet interfaces.
> >  bsps/aarch64/xilinx-zynqmp/console/console.c  | 163
> >  bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c      |  51 ++++++
> >  bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts    | 110 ++++++++++++
> >  bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c  | 124 +++++++++++++
> >  bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts     |  94 ++++++++++
> >  bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c   |  97 +++++++++++
> >  bsps/aarch64/xilinx-zynqmp/include/bsp.h      |  15 ++
> >  .../aarch64/xilinx-zynqmp/start/bspstartmmu.c |   4 +
> >  .../aarch64/xilinx-zynqmp/bspcfc400xlp64.yml  |  21 +++
> >  .../aarch64/xilinx-zynqmp/bspqemuilp32.yml    |   2 +
> >  .../aarch64/xilinx-zynqmp/bspqemulp64.yml     |   2 +
> >  .../aarch64/xilinx-zynqmp/bspzu3egilp32.yml   |   2 +
> >  .../aarch64/xilinx-zynqmp/bspzu3eglp64.yml    |   2 +
> >  spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml |   1 +
> >  .../aarch64/xilinx-zynqmp/objfdtcfc400x.yml   |  14 ++
> >  .../aarch64/xilinx-zynqmp/objfdtzynqmp.yml    |  14 ++
> >  .../bsps/aarch64/xilinx-zynqmp/optloadoff.yml |   1 +
> >  .../bsps/aarch64/xilinx-zynqmp/optramori.yml  |   1 +
> >  spec/build/cpukit/optsmp.yml                  |   1 +
> >  19 files changed, 718 insertions(+), 1 deletion(-)
> >  create mode 100644 bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c
> >  create mode 100644 bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts
> >  create mode 100644 bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
> >  create mode 100644 bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts
> >  create mode 100644 bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
> >  create mode 100644 spec/build/bsps/aarch64/xilinx-
> > diff --git a/bsps/aarch64/xilinx-zynqmp/console/console.c
> > b/bsps/aarch64/xilinx-zynqmp/console/console.c
> > index d1948f1a0c..d546db8535 100644
> > --- a/bsps/aarch64/xilinx-zynqmp/console/console.c
> > +++ b/bsps/aarch64/xilinx-zynqmp/console/console.c
> > @@ -9,7 +9,7 @@
> > - * Copyright (C) 2020 On-Line Applications Research Corporation
> > (OAR)
> > + * Copyright (C) 2022 On-Line Applications Research Corporation
> > (OAR)
> >   * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
> >   * Redistribution and use in source and binary forms, with or
> > without
> > @@ -36,13 +36,165 @@
> >  #include <rtems/console.h>
> >  #include <rtems/bspIo.h>
> > +#include <rtems/endian.h>
> > +#include <rtems/rtems-fdt.h>
> >  #include <rtems/sysinit.h>
> > +#include <bsp/aarch64-mmu.h>
> > +#include <bsp/fdt.h>
> >  #include <bsp/irq.h>
> >  #include <dev/serial/zynq-uart.h>
> >  #include <bspopts.h>
> > +#include <libchip/ns16550.h>
> > +uint32_t mgmt_uart_reg_shift = 0;
> > +static uint8_t get_register(uintptr_t addr, uint8_t i)
> > +  volatile uint8_t *reg = (uint8_t *) addr;
> > +  i <<= mgmt_uart_reg_shift;
> > +  return reg [i];
> > +static void set_register(uintptr_t addr, uint8_t i, uint8_t val)
> > +  reg [i] = val;
> > +static ns16550_context zynqmp_mgmt_uart_context = {
> > +  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("Management UART
> > 0"),
> > +  .get_reg = get_register,
> > +  .set_reg = set_register,
> > +  .port = 0,
> > +  .irq = 0,
> > +  .clock = 0,
> > +  .initial_baud = 0,
> > +__attribute__ ((weak)) void
> > zynqmp_configure_management_console(rtems_termios_device_context
> > *base)
> > +  /* This SLIP-encoded watchdog command sets timeouts to 0xFFFFFFFF
> > seconds. */
> > +  const char mgmt_watchdog_cmd[] =
> > +    "\xc0\xda\x00\x00\xff\xff\xff\xff\xff\x00\xff\xff\xff\xffM#\xc0"
> > +  /* Send the system watchdog configuration command */
> > +  for (int i = 0; i < sizeof(mgmt_watchdog_cmd); i++) {
> > +    ns16550_polled_putchar(base, mgmt_watchdog_cmd[i]);
> > +static void zynqmp_management_console_init(void)
> > +  /* Find the management console in the device tree */
> > +  rtems_fdt_handle fdt_handle;
> > +  const uint32_t *prop;
> > +  uint32_t outprop[4];
> > +  int proplen;
> > +  int node;
> > +  rtems_fdt_init_handle(&fdt_handle);
> > +  rtems_fdt_register(bsp_fdt_get(), &fdt_handle);
> > +  const char *alias = rtems_fdt_get_alias(&fdt_handle, "mgmtport");
> > +  if (alias == NULL) {
> > +    rtems_fdt_release_handle(&fdt_handle);
> > +    return;
> > +  node = rtems_fdt_path_offset(&fdt_handle, alias);
> > +  prop = rtems_fdt_getprop(&fdt_handle, node, "clock-frequency",
> > &proplen);
> > +  if ( prop == NULL || proplen != 4 ) {
> > +    zynqmp_mgmt_uart_context.port = 0;
> > +    return;
> > +  outprop[0] = rtems_uint32_from_big_endian((const uint8_t *)
> > &prop[0]);
> > +  zynqmp_mgmt_uart_context.clock = outprop[0];
> > +  prop = rtems_fdt_getprop(&fdt_handle, node, "current-speed",
> > &proplen);
> > +    return;
> > &prop[0]);
> > +  zynqmp_mgmt_uart_context.initial_baud = outprop[0];
> > +  prop = rtems_fdt_getprop(&fdt_handle, node, "interrupts",
> > &proplen);
> > +  if ( prop == NULL || proplen != 12 ) {
> > +    return;
> > &prop[0]);
> > +  outprop[1] = rtems_uint32_from_big_endian((const uint8_t *)
> > &prop[1]);
> > +  outprop[2] = rtems_uint32_from_big_endian((const uint8_t *)
> > &prop[2]);
> > +  /* proplen is in bytes, interrupt mapping expects a length in 32-
> > bit cells */
> > +  zynqmp_mgmt_uart_context.irq = bsp_fdt_map_intr(outprop, proplen /
> > 4);
> > +  if ( zynqmp_mgmt_uart_context.irq == 0 ) {
> > +    return;
> > +  prop = rtems_fdt_getprop(&fdt_handle, node, "reg", &proplen);
> > +  if ( prop == NULL || proplen != 16 ) {
> > +    return;
> > &prop[0]);
> > &prop[1]);
> > &prop[2]);
> > +  outprop[3] = rtems_uint32_from_big_endian((const uint8_t *)
> > &prop[3]);
> > +  zynqmp_mgmt_uart_context.port = ( ( (uint64_t) outprop[0] ) << 32
> > ) | outprop[1];
> > +  uintptr_t uart_base = zynqmp_mgmt_uart_context.port;
> > +  size_t uart_size = ( ( (uint64_t) outprop[2] ) << 32 ) |
> > outprop[3];
> > +  rtems_status_code sc = aarch64_mmu_map( uart_base,
> > +                                          uart_size,
> > +                                          AARCH64_MMU_DEVICE);
> > +  if ( sc != RTEMS_SUCCESSFUL ) {
> > +    return;
> > +  prop = rtems_fdt_getprop(&fdt_handle, node, "reg-offset",
> > &proplen);
> > +    return;
> > &prop[0]);
> > +  zynqmp_mgmt_uart_context.port += outprop[0];
> > +  prop = rtems_fdt_getprop(&fdt_handle, node, "reg-shift",
> > &proplen);
> > +    return;
> > &prop[0]);
> > +  mgmt_uart_reg_shift = outprop[0];
> > +  ns16550_probe(&zynqmp_mgmt_uart_context.base);
> > +  zynqmp_configure_management_console(&zynqmp_mgmt_uart_context.base
> > +RTEMS_SYSINIT_ITEM(
> > +  zynqmp_management_console_init,
> > +  RTEMS_SYSINIT_BSP_START,
> > +  RTEMS_SYSINIT_ORDER_FIRST
> >  static zynq_uart_context zynqmp_uart_instances[2] = {
> >      .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 0"
> > @@ -81,6 +233,15 @@ rtems_status_code console_initialize(
> > +  if ( zynqmp_mgmt_uart_context.port != 0 ) {
> > +    rtems_termios_device_install(
> > +      "/dev/ttyMGMT0",
> > +      &ns16550_handler_polled,
> > +      NULL,
> > +      &zynqmp_mgmt_uart_context.base
> >    return RTEMS_SUCCESSFUL;
> > diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c
> > b/bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c
> > new file mode 100644
> > index 0000000000..0748639256
> > --- /dev/null
> > +++ b/bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c
> > @@ -0,0 +1,51 @@
> > +/* SPDX-License-Identifier: BSD-2-Clause */
> > + * @file
> > + * @ingroup RTEMSBSPsAArch64XilinxZynqMP
> > + * @brief This source file contains the implementatin of
> > bsp_fdt_get().
> > (OAR)
> > + * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
> > + * Redistribution and use in source and binary forms, with or
> > without
> > + * modification, are permitted provided that the following
> > conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + *    notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above
> > copyright
> > in the
> > + *    documentation and/or other materials provided with the
> > distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
> > CONTRIBUTORS "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> > TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> > PARTICULAR PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> > CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
> > OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
> > OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> > BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
> > WHETHER IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> > OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
> > ADVISED OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> > +#include <bsp.h>
> > +const void *bsp_fdt_get(void)
> > +  return zynqmp_dtb;
> > +uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells)
> > +  if (icells != 3) {
> > +    return 0;
> > +  return (intr[0] == 0 ? 32 : 16) + intr[1];
> > diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts
> > b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts
> > index 0000000000..763a668a5c
> > --- /dev/null
> > +++ b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x.dts
> > @@ -0,0 +1,110 @@
> > + * @file
> > + * @brief This file provides the CFC-400X device tree
> > (OAR)
> > without
> > conditions
> > + * are met:
> > copyright
> > in the
> > distribution.
> > TO, THE
> > PARTICULAR PURPOSE
> > CONTRIBUTORS BE
> > OR
> > OF
> > BUSINESS
> > WHETHER IN
> > OTHERWISE)
> > ADVISED OF THE
> > +/dts-v1/;
> > +       #address-cells = <0x02>;
> > +       #size-cells = <0x02>;
> > +       amba {
> > +               compatible = "simple-bus";
> > +               ranges;
> > +               interrupt-controller at f9010000 {
> > +                       compatible = "arm,gic-400";
> > +                       #interrupt-cells = <0x03>;
> > +                       reg = <0x00 0xf9010000 0x00 0x10000>;
> > +                       interrupt-controller;
> > +                       phandle = <0x01>;
> > +                       status = "okay";
> > +               ethernet at ff0c0000 {
> > +                       status = "okay";
> > +                       interrupts = <0x00 0x3b 0x04>;
> > +                       reg = <0x00 0xff0c0000 0x00 0x1000>;
> > +               ethernet at ff0d0000 {
> > +                       status = "okay";
> > +                       interrupts = <0x00 0x3d 0x04>;
> > +                       reg = <0x00 0xff0d0000 0x00 0x1000>;
> > +               ethernet at ff0e0000 {
> > +                       status = "okay";
> > +                       interrupts = <0x00 0x3f 0x04>;
> > +                       reg = <0x00 0xff0e0000 0x00 0x1000>;
> > +               serial at 800a0000 {
> > +                       clock-frequency = <0x189c000>;
> > +                       compatible = "ns16550a";
> > +                       current-speed = <0x1c200>;
> > +                       device_type = "serial";
> > +                       interrupts = <0x00 0x6e 0x04>;
> > +                       reg = <0x00 0x800a0000 0x00 0x10000>;
> > +                       reg-offset = <0x1000>;
> > +                       reg-shift = <0x02>;
> > +       aliases {
> > +               mgmtport = "/amba/serial at 800a0000";
> > diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
> > b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
> > index 0000000000..2d0078678e
> > --- /dev/null
> > +++ b/bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
> > @@ -0,0 +1,124 @@
> > +unsigned char zynqmp_dtb[] = {
> > +  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x05, 0xa3, 0x00, 0x00, 0x00,
> > 0x38,
> > +  0x00, 0x00, 0x04, 0xd0, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00,
> > 0x11,
> > +  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> > 0xd3,
> > +  0x00, 0x00, 0x04, 0x98, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> > 0x00,
> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> > 0x01,
> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00,
> > 0x04,
> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00,
> > 0x03,
> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00,
> > 0x02,
> > +  0x00, 0x00, 0x00, 0x01, 0x61, 0x6d, 0x62, 0x61, 0x00, 0x00, 0x00,
> > 0x00,
> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00,
> > 0x1b,
> > +  0x73, 0x69, 0x6d, 0x70, 0x6c, 0x65, 0x2d, 0x62, 0x75, 0x73, 0x00,
> > 0x00,
> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00,
> > 0x00,
> > +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00,
> > 0x04,
> > +  0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00,
> > 0x03,
> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x26, 0x00, 0x00, 0x00,
> > 0x01,
> > +  0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x63,
> > 0x6f,
> > +  0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x40, 0x66, 0x39,
> > 0x30,
> > +  0x31, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> > 0x03,
> > +  0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x1b, 0x61, 0x72, 0x6d,
> > 0x2c,
> > +  0x67, 0x69, 0x63, 0x2d, 0x34, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
> > 0x03,
> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> > 0x02,
> > 0x2d,
> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00,
> > 0x10,
> > +  0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0xf9, 0x01, 0x00,
> > 0x00,
> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
> > 0x03,
> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00,
> > 0x03,
> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x57, 0x00, 0x00, 0x00,
> > 0x01,
> > +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x65, 0x74, 0x68,
> > 0x65,
> > +  0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30, 0x62, 0x30, 0x30,
> > 0x30,
> > +  0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00,
> > 0x09,
> > +  0x00, 0x00, 0x00, 0x1b, 0x63, 0x64, 0x6e, 0x73, 0x2c, 0x67, 0x65,
> > 0x6d,
> > 0x05,
> > +  0x00, 0x00, 0x00, 0x5f, 0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00,
> > 0x00,
> > 0x66,
> > +  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00,
> > 0x0c,
> > +  0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> > 0x39,
> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00,
> > 0x10,
> > +  0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0xff, 0x0b, 0x00,
> > 0x00,
> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00,
> > 0x03,
> > +  0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x82, 0x73, 0x67, 0x6d,
> > 0x69,
> > +  0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00,
> > 0x01,
> > +  0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66,
> > 0x30,
> > +  0x63, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> > 0x03,
> > +  0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b, 0x63, 0x64, 0x6e,
> > 0x73,
> > +  0x2c, 0x67, 0x65, 0x6d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> > 0x03,
> > +  0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x5f, 0x6f, 0x6b, 0x61,
> > 0x79,
> > 0x04,
> > +  0x00, 0x00, 0x00, 0x66, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00,
> > 0x03,
> > +  0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00,
> > 0x00,
> > +  0x00, 0x00, 0x00, 0x3b, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00,
> > 0x03,
> > +  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00,
> > 0x00,
> > +  0xff, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10,
> > 0x00,
> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00,
> > 0x82,
> > +  0x73, 0x67, 0x6d, 0x69, 0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> > 0x02,
> > +  0x00, 0x00, 0x00, 0x01, 0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65,
> > 0x74,
> > +  0x40, 0x66, 0x66, 0x30, 0x64, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00,
> > 0x00,
> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00,
> > 0x1b,
> > +  0x63, 0x64, 0x6e, 0x73, 0x2c, 0x67, 0x65, 0x6d, 0x00, 0x00, 0x00,
> > 0x00,
> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00,
> > 0x5f,
> > +  0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> > 0x03,
> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x66, 0x00, 0x00, 0x00,
> > 0x01,
> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00,
> > 0x77,
> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3d, 0x00, 0x00, 0x00,
> > 0x04,
> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00,
> > 0x3e,
> > +  0x00, 0x00, 0x00, 0x00, 0xff, 0x0d, 0x00, 0x00, 0x00, 0x00, 0x00,
> > 0x00,
> > +  0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00,
> > 0x06,
> > +  0x00, 0x00, 0x00, 0x82, 0x73, 0x67, 0x6d, 0x69, 0x69, 0x00, 0x00,
> > 0x00,
> > 0x65,
> > +  0x72, 0x6e, 0x65, 0x74, 0x40, 0x66, 0x66, 0x30, 0x65, 0x30, 0x30,
> > 0x30,
> > 0x09,
> > 0x6d,
> > 0x05,
> > 0x00,
> > 0x66,
> > 0x0c,
> > 0x3f,
> > 0x10,
> > +  0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0xff, 0x0e, 0x00,
> > 0x00,
> > 0x03,
> > 0x69,
> > 0x01,
> > +  0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40, 0x38, 0x30, 0x30, 0x61,
> > 0x30,
> > +  0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00,
> > 0x04,
> > +  0x00, 0x00, 0x00, 0x8b, 0x01, 0x89, 0xc0, 0x00, 0x00, 0x00, 0x00,
> > 0x03,
> > +  0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x1b, 0x6e, 0x73, 0x31,
> > 0x36,
> > +  0x35, 0x35, 0x30, 0x61, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> > 0x03,
> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x9b, 0x00, 0x01, 0xc2,
> > 0x00,
> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00,
> > 0xa9,
> > +  0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x00, 0x00, 0x00, 0x00, 0x00,
> > 0x03,
> > 0x01,
> > 0x77,
> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x6e, 0x00, 0x00, 0x00,
> > 0x04,
> > 0x3e,
> > +  0x00, 0x00, 0x00, 0x00, 0x80, 0x0a, 0x00, 0x00, 0x00, 0x00, 0x00,
> > 0x00,
> > +  0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00,
> > 0x04,
> > +  0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00,
> > 0x03,
> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00,
> > 0x02,
> > +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00,
> > 0x01,
> > +  0x61, 0x6c, 0x69, 0x61, 0x73, 0x65, 0x73, 0x00, 0x00, 0x00, 0x00,
> > 0x03,
> > +  0x00, 0x00, 0x00, 0x16, 0x00, 0x00, 0x00, 0xca, 0x2f, 0x61, 0x6d,
> > 0x62,
> > +  0x61, 0x2f, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40, 0x38, 0x30,
> > 0x30,
> > +  0x61, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> > 0x02,
> > +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x09, 0x23, 0x61, 0x64,
> > 0x64,
> > +  0x72, 0x65, 0x73, 0x73, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00,
> > 0x23,
> > +  0x73, 0x69, 0x7a, 0x65, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00,
> > 0x63,
> > +  0x6f, 0x6d, 0x70, 0x61, 0x74, 0x69, 0x62, 0x6c, 0x65, 0x00, 0x72,
> > 0x61,
> > +  0x6e, 0x67, 0x65, 0x73, 0x00, 0x23, 0x69, 0x6e, 0x74, 0x65, 0x72,
> > 0x72,
> > +  0x75, 0x70, 0x74, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x72,
> > 0x65,
> > +  0x67, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74,
> > 0x2d,
> > +  0x63, 0x6f, 0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00,
> > 0x70,
> > +  0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65, 0x00, 0x73, 0x74, 0x61, 0x74,
> > 0x75,
> > +  0x73, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74,
> > 0x2d,
> > +  0x70, 0x61, 0x72, 0x65, 0x6e, 0x74, 0x00, 0x69, 0x6e, 0x74, 0x65,
> > 0x72,
> > +  0x72, 0x75, 0x70, 0x74, 0x73, 0x00, 0x70, 0x68, 0x79, 0x2d, 0x6d,
> > 0x6f,
> > +  0x64, 0x65, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x66, 0x72,
> > 0x65,
> > +  0x71, 0x75, 0x65, 0x6e, 0x63, 0x79, 0x00, 0x63, 0x75, 0x72, 0x72,
> > 0x65,
> > +  0x6e, 0x74, 0x2d, 0x73, 0x70, 0x65, 0x65, 0x64, 0x00, 0x64, 0x65,
> > 0x76,
> > +  0x69, 0x63, 0x65, 0x5f, 0x74, 0x79, 0x70, 0x65, 0x00, 0x72, 0x65,
> > 0x67,
> > +  0x2d, 0x6f, 0x66, 0x66, 0x73, 0x65, 0x74, 0x00, 0x72, 0x65, 0x67,
> > 0x2d,
> > +  0x73, 0x68, 0x69, 0x66, 0x74, 0x00, 0x6d, 0x67, 0x6d, 0x74, 0x70,
> > 0x6f,
> > +  0x72, 0x74, 0x00
> > +unsigned int zynqmp_dtb_len = 1443;
> > diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts
> > b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts
> > index 0000000000..65c7dcbba8
> > --- /dev/null
> > +++ b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp.dts
> > @@ -0,0 +1,94 @@
> > + * @file
> > + * @brief This file provides the base ZynqMP device tree
> > (OAR)
> > without
> > conditions
> > + * are met:
> > copyright
> > in the
> > distribution.
> > TO, THE
> > PARTICULAR PURPOSE
> > CONTRIBUTORS BE
> > OR
> > OF
> > BUSINESS
> > WHETHER IN
> > OTHERWISE)
> > ADVISED OF THE
> > +/dts-v1/;
> > +       amba {
> > +               ranges;
> > +                       phandle = <0x01>;
> > +                       status = "okay";
> > +                       status = "okay";
> > +                       status = "okay";
> > +                       status = "okay";
> > diff --git a/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
> > b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
> > index 0000000000..955bc5f154
> > --- /dev/null
> > +++ b/bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
> > @@ -0,0 +1,97 @@
> > +  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x04, 0x5f, 0x00, 0x00, 0x00,
> > 0x38,
> > +  0x00, 0x00, 0x03, 0xd4, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00,
> > 0x11,
> > 0x8b,
> > +  0x00, 0x00, 0x03, 0x9c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> > 0x00,
> > 0x01,
> > 0x04,
> > 0x03,
> > 0x02,
> > 0x00,
> > 0x1b,
> > 0x00,
> > 0x00,
> > 0x04,
> > 0x03,
> > 0x01,
> > 0x6f,
> > 0x30,
> > 0x03,
> > 0x2c,
> > 0x03,
> > 0x02,
> > 0x2d,
> > 0x10,
> > 0x00,
> > 0x03,
> > 0x03,
> > 0x01,
> > 0x65,
> > 0x30,
> > 0x09,
> > 0x6d,
> > 0x05,
> > 0x00,
> > 0x66,
> > 0x0c,
> > 0x39,
> > 0x10,
> > 0x00,
> > 0x03,
> > 0x69,
> > 0x01,
> > 0x30,
> > 0x03,
> > 0x73,
> > 0x03,
> > 0x79,
> > 0x04,
> > 0x03,
> > 0x00,
> > 0x03,
> > 0x00,
> > 0x00,
> > 0x82,
> > 0x02,
> > 0x74,
> > 0x00,
> > 0x1b,
> > 0x00,
> > 0x5f,
> > 0x03,
> > 0x01,
> > 0x77,
> > 0x04,
> > 0x3e,
> > 0x00,
> > 0x06,
> > 0x00,
> > 0x65,
> > 0x30,
> > 0x09,
> > 0x6d,
> > 0x05,
> > 0x00,
> > 0x66,
> > 0x0c,
> > 0x3f,
> > 0x10,
> > 0x00,
> > 0x03,
> > 0x69,
> > 0x02,
> > 0x64,
> > 0x23,
> > 0x63,
> > 0x61,
> > 0x72,
> > 0x65,
> > 0x2d,
> > 0x70,
> > 0x75,
> > 0x2d,
> > 0x72,
> > 0x6f,
> > +  0x64, 0x65, 0x00
> > +unsigned int zynqmp_dtb_len = 1119;
> > diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> > b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> > index d937a313f2..bb7df94fd1 100644
> > --- a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> > +++ b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> > @@ -51,6 +51,7 @@
> >  #include <bsp/start.h>
> >  #include <rtems.h>
> > +#include <rtems/termiostypes.h>
> >  #ifdef __cplusplus
> >  extern "C" {
> > @@ -62,6 +63,10 @@ extern "C" {
> >  #define BSP_RESET_SMC
> >  #define BSP_CPU_ON_USES_SMC
> > +#define BSP_FDT_IS_SUPPORTED
> > +extern unsigned int zynqmp_dtb_len;
> > +extern unsigned char zynqmp_dtb[];
> >   * @brief Zynq UltraScale+ MPSoC specific set up of the MMU.
> > @@ -83,6 +88,16 @@ uint32_t zynqmp_clock_i2c0(void);
> >  uint32_t zynqmp_clock_i2c1(void);
> > + * @brief Zynq UltraScale+ MPSoC specific set up of a management
> > console.
> > + * Some systems may have a management interface which needs special
> > + * initialization. Provide in the application to override the
> > defaults in the
> > + * BSP. This will only be called if the interface is found in the
> > device tree.
> > +void
> > *base);
> >  #ifdef __cplusplus
> >  #endif /* __cplusplus */
> > diff --git a/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
> > b/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
> > index 33ca1eafab..e727f9b1de 100644
> > --- a/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
> > +++ b/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
> > @@ -50,6 +50,10 @@ zynqmp_mmu_config_table[] = {
> >      .begin = 0xfd000000U,
> >      .end = 0xffc00000U,
> >      .flags = AARCH64_MMU_DEVICE
> > +    .begin = 0x80000000U,
> > +    .end = 0x80100000U,
> > +    .flags = 0
> > diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspcfc400xlp64.yml
> > b/spec/build/bsps/aarch64/xilinx-zynqmp/bspcfc400xlp64.yml
> > index 0000000000..1687ced857
> > --- /dev/null
> > +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspcfc400xlp64.yml
> > @@ -0,0 +1,21 @@
> > +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> > +arch: aarch64
> > +bsp: xilinx_zynqmp_lp64_cfc400x
> > +build-type: bsp
> > +cflags: []
> > +copyrights:
> > +- Copyright (C) 2022 On-Line Applications Research (OAR)
> > +cppflags: []
> > +enabled-by: true
> > +family: xilinx-zynqmp
> > +includes: []
> > +install: []
> > +links:
> > +- role: build-dependency
> > +  uid: grp_zu3eg
> > +  uid: linkcmds_lp64
> > +  uid: objfdtcfc400x
> > +source: []
> > +type: build
> > diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml
> > b/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml
> > index 6e0eafc871..18968cd43d 100644
> > --- a/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml
> > +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml
> > @@ -17,5 +17,7 @@ links:
> >    uid: tstqemu
> >    uid: linkcmds_ilp32
> > +  uid: objfdtzynqmp
> >  source: []
> >  type: build
> > diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml
> > b/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml
> > index 0d047e263c..86177d7fcd 100644
> > --- a/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml
> > +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml
> >    uid: tstqemu
> >    uid: linkcmds_lp64
> > +  uid: objfdtzynqmp
> >  source: []
> >  type: build
> > diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3egilp32.yml
> > b/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3egilp32.yml
> > index dd7d39fb94..cd0bb2b854 100644
> > --- a/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3egilp32.yml
> > +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3egilp32.yml
> > @@ -15,5 +15,7 @@ links:
> >    uid: grp_zu3eg
> >    uid: linkcmds_ilp32
> > +  uid: objfdtzynqmp
> >  source: []
> >  type: build
> > diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3eglp64.yml
> > b/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3eglp64.yml
> > index 073e91175b..19211dae15 100644
> > --- a/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3eglp64.yml
> > +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3eglp64.yml
> >    uid: grp_zu3eg
> >    uid: linkcmds_lp64
> > +  uid: objfdtzynqmp
> >  source: []
> >  type: build
> > diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
> > b/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
> > index 4147613fc9..1a3b754d92 100644
> > --- a/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
> > +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
> > @@ -21,6 +21,7 @@ source:
> >  - bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
> >  - bsps/aarch64/shared/mmu/vmsav8-64.c
> >  - bsps/aarch64/xilinx-zynqmp/console/console.c
> > +- bsps/aarch64/xilinx-zynqmp/fdt/bsp_fdt.c
> >  - bsps/aarch64/xilinx-zynqmp/start/bspstart.c
> >  - bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
> >  - bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
> > diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtcfc400x.yml
> > b/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtcfc400x.yml
> > index 0000000000..53d93803cb
> > --- /dev/null
> > +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtcfc400x.yml
> > @@ -0,0 +1,14 @@
> > +build-type: objects
> > +cflags: []
> > +copyrights:
> > +cppflags: []
> > +cxxflags: []
> > +enabled-by: true
> > +includes: []
> > +install: []
> > +links: []
> > +source:
> > +- bsps/aarch64/xilinx-zynqmp/fdt/cfc400x_dtb.c
> > +type: build
> > diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtzynqmp.yml
> > b/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtzynqmp.yml
> > index 0000000000..271bb82976
> > --- /dev/null
> > +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/objfdtzynqmp.yml
> > @@ -0,0 +1,14 @@
> > +cflags: []
> > +copyrights:
> > +cppflags: []
> > +cxxflags: []
> > +enabled-by: true
> > +includes: []
> > +install: []
> > +links: []
> > +source:
> > +- bsps/aarch64/xilinx-zynqmp/fdt/zynqmp_dtb.c
> > +type: build
> > diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
> > b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
> > index 0bdc2d61df..976a4aeb0e 100644
> > --- a/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
> > +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
> > @@ -11,6 +11,7 @@ default: 32768
> >  default-by-variant:
> >  - value: 0x0
> >    variants:
> > +  - aarch64/xilinx_zynqmp_lp64_cfc400x
> >    - aarch64/xilinx_zynqmp_lp64_zu3eg
> >    - aarch64/xilinx_zynqmp_ilp32_zu3eg
> >  description: |
> > diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
> > b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
> > index c17febe288..427f14c7c8 100644
> > --- a/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
> > +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
> > @@ -11,6 +11,7 @@ default: 0x40018000
> >  default-by-variant:
> >  - value: 0x10000000
> >    variants:
> >  description: |
> > diff --git a/spec/build/cpukit/optsmp.yml
> > b/spec/build/cpukit/optsmp.yml
> > index b218364194..db404efe21 100644
> > --- a/spec/build/cpukit/optsmp.yml
> > +++ b/spec/build/cpukit/optsmp.yml
> > @@ -13,6 +13,7 @@ description: |
> >  enabled-by:
> >  - aarch64/xilinx_zynqmp_ilp32_qemu
> > +- aarch64/xilinx_zynqmp_lp64_cfc400x
> >  - aarch64/xilinx_zynqmp_lp64_qemu
> >  - arm/altcycv_devkit
> > 2.30.2
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221110/4bcb5ab4/attachment-0001.htm>
