This adds support for the CFC-400X BSP including an option to select
SGMII instead of the default RGMII PHY interface and adds a way for
ZynqMP BSPs to provide additional configuration via lwipbspopts.h.
.../aarch64/xilinx_zynqmp_lp64_cfc400x.json | 11 ++++
.../contrib/ports/xilinx/netif/xemacpsif_hw.c | 6 ++
rtemslwip/zynqmp/lwipopts.h | 2 +
rtemslwip/zynqmp_cfc400x/lwipbspopts.h | 33 ++++++++++
rtemslwip/zynqmp_cfc400x/netstart.c | 66 +++++++++++++++++++
rtemslwip/zynqmp_hardware/lwipbspopts.h | 1 +
rtemslwip/zynqmp_qemu/lwipbspopts.h | 1 +
7 files changed, 120 insertions(+)
create mode 100644 defs/bsps/aarch64/xilinx_zynqmp_lp64_cfc400x.json
create mode 100644 rtemslwip/zynqmp_cfc400x/lwipbspopts.h
create mode 100644 rtemslwip/zynqmp_cfc400x/netstart.c
create mode 100644 rtemslwip/zynqmp_hardware/lwipbspopts.h
create mode 100644 rtemslwip/zynqmp_qemu/lwipbspopts.h
diff --git a/defs/bsps/aarch64/xilinx_zynqmp_lp64_cfc400x.json b/defs/bsps/aarch64/xilinx_zynqmp_lp64_cfc400x.json
new file mode 100644
index 0000000..5fe676c
--- /dev/null
+++ b/defs/bsps/aarch64/xilinx_zynqmp_lp64_cfc400x.json
@@ -0,0 +1,11 @@
+ "includes": [
+ "xilinx_zynqmp_base"
+ "header-paths-to-import": [
+ "rtemslwip/zynqmp_cfc400x"
+ "source-paths-to-import": [
diff --git a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_hw.c b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_hw.c
index a1fdeda..f0ddf84 100644
--- a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_hw.c
+++ b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_hw.c
@@ -74,6 +74,12 @@ void init_emacps(xemacpsif_s *xemacps, struct netif *netif)
xemacpsp = &xemacps->emacps;
+#ifdef __rtems__
+#ifdef ZYNQMP_USE_SGMII
+ XEmacPs_SetOptions(xemacpsp, XEMACPS_SGMII_ENABLE_OPTION);
+#endif
+#endif
#ifdef ZYNQMP_USE_JUMBO
XEmacPs_SetOptions(xemacpsp, XEMACPS_JUMBO_ENABLE_OPTION);
#endif
diff --git a/rtemslwip/zynqmp/lwipopts.h b/rtemslwip/zynqmp/lwipopts.h
index b9fe277..feabe73 100644
--- a/rtemslwip/zynqmp/lwipopts.h
+++ b/rtemslwip/zynqmp/lwipopts.h
@@ -123,4 +123,6 @@
#define portTICK_RATE_MS ( rtems_clock_get_ticks_per_second() * 1000 )
#define vTaskDelay( x ) sys_arch_delay( x )
+#include <lwipbspopts.h>
#endif /* __LWIPOPTS_H__ */
diff --git a/rtemslwip/zynqmp_cfc400x/lwipbspopts.h b/rtemslwip/zynqmp_cfc400x/lwipbspopts.h
index 0000000..27eb6a9
--- /dev/null
+++ b/rtemslwip/zynqmp_cfc400x/lwipbspopts.h
@@ -0,0 +1,33 @@
+ * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef RTEMSLWIP_LWIPBSPOPTS_H
+#define RTEMSLWIP_LWIPBSPOPTS_H
+/* Use SGMII mode for all interfaces on the CFC-400X */
+#define ZYNQMP_USE_SGMII
+#endif /* RTEMSLWIP_LWIPBSPOPTS_H */
diff --git a/rtemslwip/zynqmp_cfc400x/netstart.c b/rtemslwip/zynqmp_cfc400x/netstart.c
index 0000000..d19b36c
--- /dev/null
+++ b/rtemslwip/zynqmp_cfc400x/netstart.c
@@ -0,0 +1,66 @@
+ * are met:
+#include <netstart.h>
+#include "netif/xadapter.h"
+#include "xparameters.h"
+#include <lwip/tcpip.h>
+int start_networking(
+ struct netif *net_interface,
+ ip_addr_t *ipaddr,
+ ip_addr_t *netmask,
+ ip_addr_t *gateway,
+ unsigned char *mac_ethernet_address
+ tcpip_init( NULL, NULL );
+ if ( !xemac_add(
+ net_interface,
+ ipaddr,
+ netmask,
+ gateway,
+ mac_ethernet_address,
+ XPAR_PSU_ETHERNET_0_BASEADDR
+ return 1;
+ netif_set_default( net_interface );
+ netif_set_up( net_interface );
+ sys_thread_new(
+ "xemacif_input_thread",
+ ( void ( * )( void * ) )xemacif_input_thread,
+ net_interface,
+ 1024,
+ DEFAULT_THREAD_PRIO
+ return 0;
diff --git a/rtemslwip/zynqmp_hardware/lwipbspopts.h b/rtemslwip/zynqmp_hardware/lwipbspopts.h
index 0000000..d35e631
--- /dev/null
+++ b/rtemslwip/zynqmp_hardware/lwipbspopts.h
@@ -0,0 +1 @@
+/* This file is a stub and intentionally left blank */
diff --git a/rtemslwip/zynqmp_qemu/lwipbspopts.h b/rtemslwip/zynqmp_qemu/lwipbspopts.h
--- /dev/null
+++ b/rtemslwip/zynqmp_qemu/lwipbspopts.h
@@ -0,0 +1 @@
2.30.2
