[PATCH rtems-lwip] wscript: Allow deeper lwIP configuration
Vijay Kumar Banerjee vijay at rtems.org
Fri Nov 11 22:32:37 UTC 2022
This is great! This makes it more adaptable with different BSPS. Also,
thanks for the documentation. :)
On Fri, Nov 11, 2022 at 3:03 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> This adds a basic configuration mechanism in config.ini to control which
> BSPs are enabled and to alter lwIP's define/macro-based configuration
> directives. Existing builds using --rtems-bsps are unaffected if
> config.ini is not used.
>  README  | 14 ++++++++++++++
>  wscript | 60 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++-
>  2 files changed, 73 insertions(+), 1 deletion(-)
> diff --git a/README b/README
> index 99800bf..a8cbc21 100644
> --- a/README
> +++ b/README
> @@ -30,3 +30,17 @@ git submodule update
>  More `waf` arguments can be found by using:
>  `./waf --help`
> +Further Build Information
> +The BSPs configured to build may be specified on the waf configure command line
> +with --rtems-bsps or they may be configured in config.ini as in RTEMS. The
> +command line option will override the BSPs configured in config.ini, but options
> +in config.ini will still be applied for enabled BSPs. Any additional
> +configuration options desired in lwipopts.h may be specified in config.ini under
> +the appropriate section as key/value pairs like so:
> +[aarch64/xilinx_zynqmp_lp64_zu3eg]
> +LWIP_IGMP=1
> +ZYNQMP_USE_SGMII=1
> diff --git a/wscript b/wscript
> index 1546a3d..f1b919e 100644
> --- a/wscript
> +++ b/wscript
> @@ -1,3 +1,5 @@
> +#!/usr/bin/env python
>  # RTEMS Project (https://www.rtems.org/)
> @@ -28,7 +30,13 @@
>  from __future__ import print_function
>  from rtems_waf import rtems
> +try:
> +    import configparser
> +except:
> +    import ConfigParser as configparser
>  import lwip
> +import os
>  import sys
>  top = '.'
> @@ -48,8 +56,58 @@ def options(opt):
>      rtems.options(opt)
> +def no_unicode(value):
> +    if sys.version_info[0] > 2:
> +        return value
> +    if isinstance(value, unicode):
> +        return str(value)
> +    return value
> +def get_config():
> +    cp = configparser.ConfigParser()
> +    filename = "config.ini"
> +    if filename not in cp.read([filename]):
> +        return None
> +    return cp
> +def get_configured_bsps(cp):
> +    if not cp:
> +        return "all"
> +    bsps = []
> +    for raw_bsp in cp.sections():
> +        bsps.append(no_unicode(raw_bsp))
> +    return ",".join(bsps)
> +def get_configured_bsp_options(cp, arch, bsp):
> +    if not cp:
> +        return {}
> +    options = {}
> +    for config_option in cp.items(os.path.join(arch, bsp)):
> +        opt_name = config_option[0].upper()
> +        options[opt_name] = config_option[1]
> +    return options
> +def bsp_configure(conf, arch_bsp):
> +    cp = get_config()
> +    arch = rtems.arch(arch_bsp)
> +    bsp = rtems.bsp(arch_bsp)
> +    config_options = get_configured_bsp_options(cp, arch, bsp)
> +    for key, val in config_options.items():
> +        flag = "-D"+key+"="+val
> +        conf.env.CFLAGS.append(flag)
> +        conf.env.CXXFLAGS.append(flag)
> +    lwip.bsp_configure(conf, arch_bsp)
>  def configure(conf):
> -    rtems.configure(conf, lwip.bsp_configure)
> +    cp = get_config()
> +    if conf.options.rtems_bsps == "all":
> +        conf.options.rtems_bsps = get_configured_bsps(cp)
> +    rtems.configure(conf, bsp_configure)
>  def build(bld):
> 2.30.2
> devel mailing list
> devel at rtems.org
