[5 RSB PATCH 1/3] gdb: Use https for downloads
chrisj at rtems.org
chrisj at rtems.org
Mon Nov 14 00:02:01 UTC 2022
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Close #4754
source-builder/config/gdb-common-1.cfg | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/source-builder/config/gdb-common-1.cfg b/source-builder/config/gdb-common-1.cfg
index 397d44d..b9dd47f 100644
--- a/source-builder/config/gdb-common-1.cfg
+++ b/source-builder/config/gdb-common-1.cfg
@@ -173,7 +173,7 @@ URL: http://www.gnu.org/software/gdb/
# Source
-%source set gdb http://ftp.gnu.org/gnu/gdb/gdb-%{gdb_version}.tar.%{gdb_src_ext}
+%source set gdb https://ftp.gnu.org/gnu/gdb/gdb-%{gdb_version}.tar.%{gdb_src_ext}
# Disable Python on Cxc builds for now.
2.37.1
