[5 RSB PATCH 2/3] bare/gcc: Remove gcc-4.8.2 because newlib references the unsupported CVS
chrisj at rtems.org chrisj at rtems.org
Mon Nov 14 00:02:02 UTC 2022
Updates #4715
 bare/config/devel/gcc-4.8.2-newlib-cvs-1.cfg | 47 --------------------
 bare/config/gnu-tools-4.8.2.bset             | 25 -----------
 2 files changed, 72 deletions(-)
 delete mode 100644 bare/config/devel/gcc-4.8.2-newlib-cvs-1.cfg
 delete mode 100644 bare/config/gnu-tools-4.8.2.bset
diff --git a/bare/config/devel/gcc-4.8.2-newlib-cvs-1.cfg b/bare/config/devel/gcc-4.8.2-newlib-cvs-1.cfg
deleted file mode 100644
index 7312673..0000000
--- a/bare/config/devel/gcc-4.8.2-newlib-cvs-1.cfg
+++ /dev/null
@@ -1,47 +0,0 @@
-# GCC 4.8.2., Newlib CVS
-%include %{_configdir}/bare-config.cfg
-%include %{_configdir}/checks.cfg
-%include %{_configdir}/base.cfg
-%include %{_configdir}/versions.cfg
-%define gcc_version    4.8.2
-%define newlib_version 1-Nov-2013
-%define mpfr_version   3.0.1
-%define mpc_version    0.8.2
-%define gmp_version    5.0.5
-# Project custom message
-%define gcc_version_message RSB-%{_sbgit_id})-%{release},gcc-%{gcc_version}/newlib-%{newlib_version}
-%define with_threads 0
-%define with_plugin  0
-%ifn %{defined with_iconv}
-%define with_iconv 1
-%endif
-# Incompatible with Texinfo 5
-%if %{__makeinfo_ver} >= 5.0
- %error Incomaptible version of makeinfo found!
-%endif
-# Newlib is from CVS.
-%source set newlib cvs://pserver:anoncvs@sourceware.org/cvs/src?module=newlib?src-prefix=src?date=%{newlib_version}?reset
-# Joel's stack_t patch.
-%patch add newlib -p0 %{bare_newlib_patches}/newlib-sys-signal-20130532.diff
-# The gcc/newlib build instructions. We use 4.8 Release 1.
-%include %{_configdir}/gcc-4.8-1.cfg
diff --git a/bare/config/gnu-tools-4.8.2.bset b/bare/config/gnu-tools-4.8.2.bset
index 9a75c35..0000000
--- a/bare/config/gnu-tools-4.8.2.bset
+++ /dev/null
@@ -1,25 +0,0 @@
-# GNU Tools Set
-%define release 1
-package: gnu-tools-%{_target}-%{_host}-%{release}
-%define gcc_version_message SB-%{release},gcc-%{gcc_version}/newlib-%{newlib_version}
-# Enable G++
-%define enable_cxx 1
-# Tool configuration.
-devel/expat-2.1.0-1
-devel/binutils-2.23.2-1
-devel/gcc-4.8.2-newlib-cvs-1
-devel/gdb-7.7-1
2.37.1
