[PATCH 1/2] bsps/include/libchip: Remove legacy networking header file
Daniel Cederman
cederman at gaisler.com
Mon Nov 14 09:49:59 UTC 2022
bsps/include/libchip/greth.h | 152 -----------------------------------
1 file changed, 152 deletions(-)
delete mode 100644 bsps/include/libchip/greth.h
diff --git a/bsps/include/libchip/greth.h b/bsps/include/libchip/greth.h
deleted file mode 100644
index c6e000dbd3..0000000000
--- a/bsps/include/libchip/greth.h
+++ /dev/null
@@ -1,152 +0,0 @@
- * Gaisler Research ethernet MAC driver
- * adapted from Opencores driver by Marko Isomaki
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifndef _GR_ETH_
-#define _GR_ETH_
-/* Configuration Information */
-typedef struct {
- void *base_address;
- rtems_vector_number vector;
- uint32_t txd_count;
- uint32_t rxd_count;
-} greth_configuration_t;
-/* Ethernet configuration registers */
-typedef struct _greth_regs {
- volatile uint32_t ctrl; /* Ctrl Register */
- volatile uint32_t status; /* Status Register */
- volatile uint32_t mac_addr_msb; /* Bit 47-32 of MAC address */
- volatile uint32_t mac_addr_lsb; /* Bit 31-0 of MAC address */
- volatile uint32_t mdio_ctrl; /* MDIO control and status */
- volatile uint32_t txdesc; /* Transmit descriptor pointer */
- volatile uint32_t rxdesc; /* Receive descriptor pointer */
-} greth_regs;
-#define GRETH_TOTAL_BD 128
-#define GRETH_MAXBUF_LEN 1520
-/* Tx BD */
-#define GRETH_TXD_ENABLE 0x0800 /* Tx BD Enable */
-#define GRETH_TXD_WRAP 0x1000 /* Tx BD Wrap (last BD) */
-#define GRETH_TXD_IRQ 0x2000 /* Tx BD IRQ Enable */
-#define GRETH_TXD_MORE 0x20000 /* Tx BD More (more descs for packet) */
-#define GRETH_TXD_IPCS 0x40000 /* Tx BD insert ip chksum */
-#define GRETH_TXD_TCPCS 0x80000 /* Tx BD insert tcp chksum */
-#define GRETH_TXD_UDPCS 0x100000 /* Tx BD insert udp chksum */
-#define GRETH_TXD_UNDERRUN 0x4000 /* Tx BD Underrun Status */
-#define GRETH_TXD_RETLIM 0x8000 /* Tx BD Retransmission Limit Status */
-#define GRETH_TXD_LATECOL 0x10000 /* Tx BD Late Collision */
-#define GRETH_TXD_STATS (GRETH_TXD_UNDERRUN | \
- GRETH_TXD_RETLIM | \
- GRETH_TXD_LATECOL)
-#define GRETH_TXD_CS (GRETH_TXD_IPCS | \
- GRETH_TXD_TCPCS | \
- GRETH_TXD_UDPCS)
-/* Rx BD */
-#define GRETH_RXD_ENABLE 0x0800 /* Rx BD Enable */
-#define GRETH_RXD_WRAP 0x1000 /* Rx BD Wrap (last BD) */
-#define GRETH_RXD_IRQ 0x2000 /* Rx BD IRQ Enable */
-#define GRETH_RXD_DRIBBLE 0x4000 /* Rx BD Dribble Nibble Status */
-#define GRETH_RXD_TOOLONG 0x8000 /* Rx BD Too Long Status */
-#define GRETH_RXD_CRCERR 0x10000 /* Rx BD CRC Error Status */
-#define GRETH_RXD_OVERRUN 0x20000 /* Rx BD Overrun Status */
-#define GRETH_RXD_LENERR 0x40000 /* Rx BD Length Error */
-#define GRETH_RXD_ID 0x40000 /* Rx BD IP Detected */
-#define GRETH_RXD_IR 0x40000 /* Rx BD IP Chksum Error */
-#define GRETH_RXD_UD 0x40000 /* Rx BD UDP Detected*/
-#define GRETH_RXD_UR 0x40000 /* Rx BD UDP Chksum Error */
-#define GRETH_RXD_TD 0x40000 /* Rx BD TCP Detected */
-#define GRETH_RXD_TR 0x40000 /* Rx BD TCP Chksum Error */
-#define GRETH_RXD_STATS (GRETH_RXD_OVERRUN | \
- GRETH_RXD_DRIBBLE | \
- GRETH_RXD_TOOLONG | \
- GRETH_RXD_CRCERR)
-/* CTRL Register */
-#define GRETH_CTRL_TXEN 0x00000001 /* Transmit Enable */
-#define GRETH_CTRL_RXEN 0x00000002 /* Receive Enable */
-#define GRETH_CTRL_TXIRQ 0x00000004 /* Transmit Enable */
-#define GRETH_CTRL_RXIRQ 0x00000008 /* Receive Enable */
-#define GRETH_CTRL_FULLD 0x00000010 /* Full Duplex */
-#define GRETH_CTRL_PRO 0x00000020 /* Promiscuous (receive all) */
-#define GRETH_CTRL_RST 0x00000040 /* Reset MAC */
-/* Status Register */
-#define GRETH_STATUS_RXERR 0x00000001 /* Receive Error */
-#define GRETH_STATUS_TXERR 0x00000002 /* Transmit Error IRQ */
-#define GRETH_STATUS_RXIRQ 0x00000004 /* Receive Frame IRQ */
-#define GRETH_STATUS_TXIRQ 0x00000008 /* Transmit Error IRQ */
-#define GRETH_STATUS_RXAHBERR 0x00000010 /* Receiver AHB Error */
-#define GRETH_STATUS_TXAHBERR 0x00000020 /* Transmitter AHB Error */
-/* MDIO Control */
-#define GRETH_MDIO_WRITE 0x00000001 /* MDIO Write */
-#define GRETH_MDIO_READ 0x00000002 /* MDIO Read */
-#define GRETH_MDIO_LINKFAIL 0x00000004 /* MDIO Link failed */
-#define GRETH_MDIO_BUSY 0x00000008 /* MDIO Link Busy */
-#define GRETH_MDIO_REGADR 0x000007C0 /* Register Address */
-#define GRETH_MDIO_PHYADR 0x0000F800 /* PHY address */
-#define GRETH_MDIO_DATA 0xFFFF0000 /* MDIO DATA */
-/* MII registers */
-#define GRETH_MII_EXTADV_1000FD 0x00000200
-#define GRETH_MII_EXTADV_1000HD 0x00000100
-#define GRETH_MII_EXTPRT_1000FD 0x00000800
-#define GRETH_MII_EXTPRT_1000HD 0x00000400
-#define GRETH_MII_100T4 0x00000200
-#define GRETH_MII_100TXFD 0x00000100
-#define GRETH_MII_100TXHD 0x00000080
-#define GRETH_MII_10FD 0x00000040
-#define GRETH_MII_10HD 0x00000020
-/* Attach routine */
-int rtems_greth_driver_attach (
- struct rtems_bsdnet_ifconfig *config,
- greth_configuration_t *chip
-/* PHY data */
-struct phy_device_info
- int vendor;
- int device;
- int rev;
- int adv;
- int part;
- int extadv;
- int extpart;
-#ifdef CPU_U32_FIX
-void ipalign(struct mbuf *m);
-#endif
-#endif
2.37.2
