[PATCH 1/2] bsps/include/libchip: Remove legacy networking header file
Tue Nov 15 14:51:44 UTC 2022
I don't see a 2/2?
This file removal is ok, looks like an oversight during the net-legacy
transition. I don't see any other header files that were copied to
rtems-net-legacy but not deleted here.
On Mon, Nov 14, 2022 at 2:50 AM Daniel Cederman <cederman at gaisler.com> wrote:
>  bsps/include/libchip/greth.h | 152 -----------------------------------
>  1 file changed, 152 deletions(-)
>  delete mode 100644 bsps/include/libchip/greth.h
> diff --git a/bsps/include/libchip/greth.h b/bsps/include/libchip/greth.h
> deleted file mode 100644
> index c6e000dbd3..0000000000
> --- a/bsps/include/libchip/greth.h
> +++ /dev/null
> @@ -1,152 +0,0 @@
> - * Gaisler Research ethernet MAC driver
> - * adapted from Opencores driver by Marko Isomaki
> - *  The license and distribution terms for this file may be
> - *  found in the file LICENSE in this distribution or at
> - *  http://www.rtems.org/license/LICENSE.
> -#ifndef _GR_ETH_
> -#define _GR_ETH_
> -/* Configuration Information */
> -typedef struct {
> -  void                 *base_address;
> -  rtems_vector_number   vector;
> -  uint32_t              txd_count;
> -  uint32_t              rxd_count;
> -} greth_configuration_t;
> -/* Ethernet configuration registers */
> -typedef struct _greth_regs {
> -   volatile uint32_t ctrl;         /* Ctrl Register */
> -   volatile uint32_t status;       /* Status Register */
> -   volatile uint32_t mac_addr_msb; /* Bit 47-32 of MAC address */
> -   volatile uint32_t mac_addr_lsb; /* Bit 31-0 of MAC address */
> -   volatile uint32_t mdio_ctrl;    /* MDIO control and status */
> -   volatile uint32_t txdesc;       /* Transmit descriptor pointer */
> -   volatile uint32_t rxdesc;       /* Receive descriptor pointer */
> -} greth_regs;
> -#define GRETH_TOTAL_BD           128
> -#define GRETH_MAXBUF_LEN         1520
> -/* Tx BD */
> -#define GRETH_TXD_ENABLE      0x0800 /* Tx BD Enable */
> -#define GRETH_TXD_WRAP        0x1000 /* Tx BD Wrap (last BD) */
> -#define GRETH_TXD_IRQ         0x2000 /* Tx BD IRQ Enable */
> -#define GRETH_TXD_MORE        0x20000 /* Tx BD More (more descs for packet) */
> -#define GRETH_TXD_IPCS        0x40000 /* Tx BD insert ip chksum */
> -#define GRETH_TXD_TCPCS       0x80000 /* Tx BD insert tcp chksum */
> -#define GRETH_TXD_UDPCS       0x100000 /* Tx BD insert udp chksum */
> -#define GRETH_TXD_UNDERRUN    0x4000 /* Tx BD Underrun Status */
> -#define GRETH_TXD_RETLIM      0x8000 /* Tx BD Retransmission Limit Status */
> -#define GRETH_TXD_LATECOL     0x10000 /* Tx BD Late Collision */
> -#define GRETH_TXD_STATS       (GRETH_TXD_UNDERRUN            | \
> -                               GRETH_TXD_RETLIM              | \
> -                               GRETH_TXD_LATECOL)
> -#define GRETH_TXD_CS          (GRETH_TXD_IPCS            | \
> -                               GRETH_TXD_TCPCS           | \
> -                               GRETH_TXD_UDPCS)
> -/* Rx BD */
> -#define GRETH_RXD_ENABLE      0x0800 /* Rx BD Enable */
> -#define GRETH_RXD_WRAP        0x1000 /* Rx BD Wrap (last BD) */
> -#define GRETH_RXD_IRQ         0x2000 /* Rx BD IRQ Enable */
> -#define GRETH_RXD_DRIBBLE     0x4000 /* Rx BD Dribble Nibble Status */
> -#define GRETH_RXD_TOOLONG     0x8000 /* Rx BD Too Long Status */
> -#define GRETH_RXD_CRCERR      0x10000 /* Rx BD CRC Error Status */
> -#define GRETH_RXD_OVERRUN     0x20000 /* Rx BD Overrun Status */
> -#define GRETH_RXD_LENERR      0x40000 /* Rx BD Length Error */
> -#define GRETH_RXD_ID          0x40000 /* Rx BD IP Detected */
> -#define GRETH_RXD_IR          0x40000 /* Rx BD IP Chksum Error */
> -#define GRETH_RXD_UD          0x40000 /* Rx BD UDP Detected*/
> -#define GRETH_RXD_UR          0x40000 /* Rx BD UDP Chksum Error */
> -#define GRETH_RXD_TD          0x40000 /* Rx BD TCP Detected */
> -#define GRETH_RXD_TR          0x40000 /* Rx BD TCP Chksum Error */
> -#define GRETH_RXD_STATS       (GRETH_RXD_OVERRUN             | \
> -                               GRETH_RXD_DRIBBLE             | \
> -                               GRETH_RXD_TOOLONG             | \
> -                               GRETH_RXD_CRCERR)
> -/* CTRL Register */
> -#define GRETH_CTRL_TXEN         0x00000001 /* Transmit Enable */
> -#define GRETH_CTRL_RXEN         0x00000002 /* Receive Enable  */
> -#define GRETH_CTRL_TXIRQ        0x00000004 /* Transmit Enable */
> -#define GRETH_CTRL_RXIRQ        0x00000008 /* Receive Enable  */
> -#define GRETH_CTRL_FULLD        0x00000010 /* Full Duplex */
> -#define GRETH_CTRL_PRO          0x00000020 /* Promiscuous (receive all) */
> -#define GRETH_CTRL_RST          0x00000040 /* Reset MAC */
> -/* Status Register */
> -#define GRETH_STATUS_RXERR      0x00000001 /* Receive Error */
> -#define GRETH_STATUS_TXERR      0x00000002 /* Transmit Error IRQ */
> -#define GRETH_STATUS_RXIRQ      0x00000004 /* Receive Frame IRQ */
> -#define GRETH_STATUS_TXIRQ      0x00000008 /* Transmit Error IRQ */
> -#define GRETH_STATUS_RXAHBERR   0x00000010 /* Receiver AHB Error */
> -#define GRETH_STATUS_TXAHBERR   0x00000020 /* Transmitter AHB Error */
> -/* MDIO Control  */
> -#define GRETH_MDIO_WRITE        0x00000001 /* MDIO Write */
> -#define GRETH_MDIO_READ         0x00000002 /* MDIO Read */
> -#define GRETH_MDIO_LINKFAIL     0x00000004 /* MDIO Link failed */
> -#define GRETH_MDIO_BUSY         0x00000008 /* MDIO Link Busy */
> -#define GRETH_MDIO_REGADR       0x000007C0 /* Register Address */
> -#define GRETH_MDIO_PHYADR       0x0000F800 /* PHY address */
> -#define GRETH_MDIO_DATA         0xFFFF0000 /* MDIO DATA */
> -/* MII registers */
> -#define GRETH_MII_EXTADV_1000FD 0x00000200
> -#define GRETH_MII_EXTADV_1000HD 0x00000100
> -#define GRETH_MII_EXTPRT_1000FD 0x00000800
> -#define GRETH_MII_EXTPRT_1000HD 0x00000400
> -#define GRETH_MII_100T4         0x00000200
> -#define GRETH_MII_100TXFD       0x00000100
> -#define GRETH_MII_100TXHD       0x00000080
> -#define GRETH_MII_10FD          0x00000040
> -#define GRETH_MII_10HD          0x00000020
> -/* Attach routine */
> -int rtems_greth_driver_attach (
> -    struct rtems_bsdnet_ifconfig *config,
> -    greth_configuration_t *chip
> -/* PHY data */
> -struct phy_device_info
> -   int vendor;
> -   int device;
> -   int rev;
> -   int adv;
> -   int part;
> -   int extadv;
> -   int extpart;
> -#ifdef CPU_U32_FIX
> -void ipalign(struct mbuf *m);
> -#endif
> -#endif
> 2.37.2
> devel mailing list
> devel at rtems.org
