[PATCH 1/2] bsps/include/libchip: Remove legacy networking header file
Daniel Cederman cederman at gaisler.com
Tue Nov 15 16:01:20 UTC 2022
2/2 was the license change patch, but it was too big for the list, so I
had to split it up.
On 2022-11-15 15:51, Gedare Bloom wrote:
> I don't see a 2/2?
> This file removal is ok, looks like an oversight during the net-legacy
> transition. I don't see any other header files that were copied to
> rtems-net-legacy but not deleted here.
> On Mon, Nov 14, 2022 at 2:50 AM Daniel Cederman<cederman at gaisler.com>  wrote:
>>   bsps/include/libchip/greth.h | 152 -----------------------------------
>>   1 file changed, 152 deletions(-)
>>   delete mode 100644 bsps/include/libchip/greth.h
>> diff --git a/bsps/include/libchip/greth.h b/bsps/include/libchip/greth.h
>> deleted file mode 100644
>> index c6e000dbd3..0000000000
>> --- a/bsps/include/libchip/greth.h
>> +++ /dev/null
>> @@ -1,152 +0,0 @@
>> - * Gaisler Research ethernet MAC driver
>> - * adapted from Opencores driver by Marko Isomaki
>> - *  The license and distribution terms for this file may be
>> - *  found in the file LICENSE in this distribution or at
>> - *http://www.rtems.org/license/LICENSE.
>> -#ifndef _GR_ETH_
>> -#define _GR_ETH_
>> -/* Configuration Information */
>> -typedef struct {
>> -  void                 *base_address;
>> -  rtems_vector_number   vector;
>> -  uint32_t              txd_count;
>> -  uint32_t              rxd_count;
>> -} greth_configuration_t;
>> -/* Ethernet configuration registers */
>> -typedef struct _greth_regs {
>> -   volatile uint32_t ctrl;         /* Ctrl Register */
>> -   volatile uint32_t status;       /* Status Register */
>> -   volatile uint32_t mac_addr_msb; /* Bit 47-32 of MAC address */
>> -   volatile uint32_t mac_addr_lsb; /* Bit 31-0 of MAC address */
>> -   volatile uint32_t mdio_ctrl;    /* MDIO control and status */
>> -   volatile uint32_t txdesc;       /* Transmit descriptor pointer */
>> -   volatile uint32_t rxdesc;       /* Receive descriptor pointer */
>> -} greth_regs;
>> -#define GRETH_TOTAL_BD           128
>> -#define GRETH_MAXBUF_LEN         1520
>> -/* Tx BD */
>> -#define GRETH_TXD_ENABLE      0x0800 /* Tx BD Enable */
>> -#define GRETH_TXD_WRAP        0x1000 /* Tx BD Wrap (last BD) */
>> -#define GRETH_TXD_IRQ         0x2000 /* Tx BD IRQ Enable */
>> -#define GRETH_TXD_MORE        0x20000 /* Tx BD More (more descs for packet) */
>> -#define GRETH_TXD_IPCS        0x40000 /* Tx BD insert ip chksum */
>> -#define GRETH_TXD_TCPCS       0x80000 /* Tx BD insert tcp chksum */
>> -#define GRETH_TXD_UDPCS       0x100000 /* Tx BD insert udp chksum */
>> -#define GRETH_TXD_UNDERRUN    0x4000 /* Tx BD Underrun Status */
>> -#define GRETH_TXD_RETLIM      0x8000 /* Tx BD Retransmission Limit Status */
>> -#define GRETH_TXD_LATECOL     0x10000 /* Tx BD Late Collision */
>> -#define GRETH_TXD_STATS       (GRETH_TXD_UNDERRUN            | \
>> -                               GRETH_TXD_RETLIM              | \
>> -                               GRETH_TXD_LATECOL)
>> -#define GRETH_TXD_CS          (GRETH_TXD_IPCS            | \
>> -                               GRETH_TXD_TCPCS           | \
>> -                               GRETH_TXD_UDPCS)
>> -/* Rx BD */
>> -#define GRETH_RXD_ENABLE      0x0800 /* Rx BD Enable */
>> -#define GRETH_RXD_WRAP        0x1000 /* Rx BD Wrap (last BD) */
>> -#define GRETH_RXD_IRQ         0x2000 /* Rx BD IRQ Enable */
>> -#define GRETH_RXD_DRIBBLE     0x4000 /* Rx BD Dribble Nibble Status */
>> -#define GRETH_RXD_TOOLONG     0x8000 /* Rx BD Too Long Status */
>> -#define GRETH_RXD_CRCERR      0x10000 /* Rx BD CRC Error Status */
>> -#define GRETH_RXD_OVERRUN     0x20000 /* Rx BD Overrun Status */
>> -#define GRETH_RXD_LENERR      0x40000 /* Rx BD Length Error */
>> -#define GRETH_RXD_ID          0x40000 /* Rx BD IP Detected */
>> -#define GRETH_RXD_IR          0x40000 /* Rx BD IP Chksum Error */
>> -#define GRETH_RXD_UD          0x40000 /* Rx BD UDP Detected*/
>> -#define GRETH_RXD_UR          0x40000 /* Rx BD UDP Chksum Error */
>> -#define GRETH_RXD_TD          0x40000 /* Rx BD TCP Detected */
>> -#define GRETH_RXD_TR          0x40000 /* Rx BD TCP Chksum Error */
>> -#define GRETH_RXD_STATS       (GRETH_RXD_OVERRUN             | \
>> -                               GRETH_RXD_DRIBBLE             | \
>> -                               GRETH_RXD_TOOLONG             | \
>> -                               GRETH_RXD_CRCERR)
>> -/* CTRL Register */
>> -#define GRETH_CTRL_TXEN         0x00000001 /* Transmit Enable */
>> -#define GRETH_CTRL_RXEN         0x00000002 /* Receive Enable  */
>> -#define GRETH_CTRL_TXIRQ        0x00000004 /* Transmit Enable */
>> -#define GRETH_CTRL_RXIRQ        0x00000008 /* Receive Enable  */
>> -#define GRETH_CTRL_FULLD        0x00000010 /* Full Duplex */
>> -#define GRETH_CTRL_PRO          0x00000020 /* Promiscuous (receive all) */
>> -#define GRETH_CTRL_RST          0x00000040 /* Reset MAC */
>> -/* Status Register */
>> -#define GRETH_STATUS_RXERR      0x00000001 /* Receive Error */
>> -#define GRETH_STATUS_TXERR      0x00000002 /* Transmit Error IRQ */
>> -#define GRETH_STATUS_RXIRQ      0x00000004 /* Receive Frame IRQ */
>> -#define GRETH_STATUS_TXIRQ      0x00000008 /* Transmit Error IRQ */
>> -#define GRETH_STATUS_RXAHBERR   0x00000010 /* Receiver AHB Error */
>> -#define GRETH_STATUS_TXAHBERR   0x00000020 /* Transmitter AHB Error */
>> -/* MDIO Control  */
>> -#define GRETH_MDIO_WRITE        0x00000001 /* MDIO Write */
>> -#define GRETH_MDIO_READ         0x00000002 /* MDIO Read */
>> -#define GRETH_MDIO_LINKFAIL     0x00000004 /* MDIO Link failed */
>> -#define GRETH_MDIO_BUSY         0x00000008 /* MDIO Link Busy */
>> -#define GRETH_MDIO_REGADR       0x000007C0 /* Register Address */
>> -#define GRETH_MDIO_PHYADR       0x0000F800 /* PHY address */
>> -#define GRETH_MDIO_DATA         0xFFFF0000 /* MDIO DATA */
>> -/* MII registers */
>> -#define GRETH_MII_EXTADV_1000FD 0x00000200
>> -#define GRETH_MII_EXTADV_1000HD 0x00000100
>> -#define GRETH_MII_EXTPRT_1000FD 0x00000800
>> -#define GRETH_MII_EXTPRT_1000HD 0x00000400
>> -#define GRETH_MII_100T4         0x00000200
>> -#define GRETH_MII_100TXFD       0x00000100
>> -#define GRETH_MII_100TXHD       0x00000080
>> -#define GRETH_MII_10FD          0x00000040
>> -#define GRETH_MII_10HD          0x00000020
>> -/* Attach routine */
>> -int rtems_greth_driver_attach (
>> -    struct rtems_bsdnet_ifconfig *config,
>> -    greth_configuration_t *chip
>> -/* PHY data */
>> -struct phy_device_info
>> -   int vendor;
>> -   int device;
>> -   int rev;
>> -   int adv;
>> -   int part;
>> -   int extadv;
>> -   int extpart;
>> -#ifdef CPU_U32_FIX
>> -void ipalign(struct mbuf *m);
>> -#endif
>> -#endif
>> 2.37.2
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221115/90a0e79a/attachment.htm>
