bsps/riscv: interrupt number mismatch
Mon Nov 21 09:53:46 UTC 2022
On 21/11/2022 10:50, Padmarao.Begari at microchip.com wrote:
> The interrupt number(vector) mention in the device tree node is working
> when the driver is used the RISCV_INTERRUPT_VECTOR_EXTERNAL() and later
> called the RISCV_INTERRUPT_VECTOR_EXTERNAL_TO_INDEX() in the RTEMS but
> the interrupt number is decreased by 2 when registering the interrupt
> from the RTEMS-LIBBSD driver(ex: Cadence GEM). The RTEMS-LIBBSD doesn't
> call the RISCV_INTERRUPT_VECTOR_EXTERNAL() but called the RISCV_INTERRU
> PT_VECTOR_EXTERNAL_TO_INDEX() for interrupt enable.
> In "bsps/riscv/riscv/include/bsp/irq.h"
> #define RISCV_INTERRUPT_VECTOR_EXTERNAL(x) ((x) + 2)
> #define RISCV_INTERRUPT_VECTOR_IS_EXTERNAL(x) ((x) >= 2)
> #define RISCV_INTERRUPT_VECTOR_EXTERNAL_TO_INDEX(x) ((x) - 2)
> Can we create a config file for non-external interrupt vector index
> instead of '2'?
> like '2' for RISC-V GENERIC and '0' for PolarFire SoC.
To which number would you map the software and timer interrupts?
Can't this off by two problem be fixed by bsp_fdt_map_intr()?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
