bsps/riscv: interrupt number mismatch
Padmarao.Begari at microchip.com Padmarao.Begari at microchip.com
Mon Nov 21 10:17:59 UTC 2022
Hi Sebastian,
> On Mon, 2022-11-21 at 10:53 +0100, Sebastian Huber wrote:
> On 21/11/2022 10:50, Padmarao.Begari at microchip.com wrote:
> > The interrupt number(vector) mention in the device tree node is
> > working
> > when the driver is used the RISCV_INTERRUPT_VECTOR_EXTERNAL() and
> > later
> > called the RISCV_INTERRUPT_VECTOR_EXTERNAL_TO_INDEX() in the RTEMS
> > but
> > the interrupt number is decreased by 2 when registering the
> > interrupt
> > from the RTEMS-LIBBSD driver(ex: Cadence GEM). The RTEMS-LIBBSD
> > doesn't
> > call the RISCV_INTERRUPT_VECTOR_EXTERNAL() but called the
> > RISCV_INTERRU
> > PT_VECTOR_EXTERNAL_TO_INDEX() for interrupt enable.
> > In "bsps/riscv/riscv/include/bsp/irq.h"
> > #define RISCV_INTERRUPT_VECTOR_EXTERNAL(x) ((x) + 2)
> > #define RISCV_INTERRUPT_VECTOR_IS_EXTERNAL(x) ((x) >= 2)
> > #define RISCV_INTERRUPT_VECTOR_EXTERNAL_TO_INDEX(x) ((x) - 2)
> > Can we create a config file for non-external interrupt vector index
> > instead of '2'?
> > like '2' for RISC-V GENERIC and '0' for PolarFire SoC.
> To which number would you map the software and timer interrupts?
The Software and Timer interrupts(numbers 0 & 1) are mapped by
the Machine cause register (mcause) and enabled by the CLINT but not by
the PLIC.
> Can't this off by two problem be fixed by bsp_fdt_map_intr()?
will check this option.
Regards
Padmarao
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
> Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
