libtests/can01: Excessive test output
Sebastian Huber
Mon Nov 28 14:11:16 UTC 2022
Hello Prashanth,
the test program libtests/can01 produces a lot of output (more than 7000
lines). Could you please strip this down to a reasonable amount (less
than 100).
What are the test objectives? From looking at the assertions, not much
from the CAN framework is tested:
grep -r assert testsuites/libtests/can01/
testsuites/libtests/can01/init.c: rtems_test_assert(fd >= 0);
testsuites/libtests/can01/init.c: rtems_test_assert(count == msg_size);
testsuites/libtests/can01/init.c: rtems_test_assert(count > 0);
testsuites/libtests/can01/init.c: rtems_test_assert(result ==
RTEMS_SUCCESSFUL);
RTEMS_SUCCESSFUL);
testsuites/libtests/can01/init.c: rtems_test_assert(ret ==
RTEMS_SUCCESSFUL);
The test objectives should be checked by assertions. If one of them
fails, then no end of test message should be printed.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
