[PATCH] cpukit/include/dev/can: Disabled debug prints in CAN Framework
Prashanth S
fishesprashanth at gmail.com
Tue Nov 29 03:46:13 UTC 2022
cpukit/include/dev/can/can.h | 2 +-
testsuites/libtests/can01/init.c | 14 ++++++++------
2 files changed, 9 insertions(+), 7 deletions(-)
diff --git a/cpukit/include/dev/can/can.h b/cpukit/include/dev/can/can.h
index 9e55395039..27afd00088 100644
--- a/cpukit/include/dev/can/can.h
+++ b/cpukit/include/dev/can/can.h
@@ -53,7 +53,7 @@
printf(str, ##__VA_ARGS__); \
} while (false);
-#define CAN_DEBUG(str, ...) DEBUG(str, ##__VA_ARGS__)
+#define CAN_DEBUG(str, ...) //DEBUG(str, ##__VA_ARGS__)
#define CAN_DEBUG_BUF(str, ...) CAN_DEBUG(str, ##__VA_ARGS__)
#define CAN_DEBUG_ISR(str, ...) CAN_DEBUG(str, ##__VA_ARGS__)
#define CAN_DEBUG_LOCK(str, ...) CAN_DEBUG(str, ##__VA_ARGS__)
diff --git a/testsuites/libtests/can01/init.c b/testsuites/libtests/can01/init.c
index 0675fe606f..c19d45602e 100644
--- a/testsuites/libtests/can01/init.c
+++ b/testsuites/libtests/can01/init.c
@@ -97,8 +97,10 @@ static void test_task(rtems_task_argument data)
rtems_test_assert(fd >= 0);
+ printf("test_task %u\n", task_num);
for (int i = 0; i < NUM_TEST_MSGS; i++) {
- printf("test_task %u\n", task_num);
+ CAN_DEBUG("test_task %u\n", task_num);
msg.id = task_num;
//FIXME: Implement Test cases for other flags also.
@@ -111,18 +113,18 @@ static void test_task(rtems_task_argument data)
msg_size = ((char *)&msg.data[msg.len] - (char *)&msg);
- printf("calling write task = %u\n", task_num);
+ CAN_DEBUG("calling write task = %u\n", task_num);
count = write(fd, &msg, sizeof(msg));
rtems_test_assert(count == msg_size);
- printf("task = %u write count = %u\n", task_num, count);
+ CAN_DEBUG("task = %u write count = %u\n", task_num, count);
- printf("calling read task = %u\n", task_num);
+ CAN_DEBUG("calling read task = %u\n", task_num);
count = read(fd, &msg, sizeof(msg));
rtems_test_assert(count > 0);
- printf("task = %u read count = %u\n", task_num, count);
+ CAN_DEBUG("task = %u read count = %u\n", task_num, count);
- printf("received message\n");
+ CAN_DEBUG("received message\n");
can_print_msg(&msg);
sleep(1);
2.25.1
