[PATCH] cpukit/include/dev/can: Disabled debug prints in CAN Framework
Prashanth S
fishesprashanth at gmail.com
Tue Nov 29 13:58:23 UTC 2022
> On 29/11/2022 05:57, Gedare Bloom wrote:
> >> @@ -111,18 +113,18 @@ static void test_task(rtems_task_argument data)
> >> msg_size = ((char *)&msg.data[msg.len] - (char *)&msg);
> >> - printf("calling write task = %u\n", task_num);
> >> + CAN_DEBUG("calling write task = %u\n", task_num);
> > The general philosophy in our test suite is to only print something if
> > there's a failure. So just remove these debug statements that are
> > leftover from your development approach.
> Another approach could be to use the RTEMS Test Framework in which the
> test verbosity is controlled by a configuration option.
I will look into the RTEMS Test Framework.
> >> count = write(fd, &msg, sizeof(msg));
> >> rtems_test_assert(count == msg_size);
> >> - printf("task = %u write count = %u\n", task_num, count);
> >> + CAN_DEBUG("task = %u write count = %u\n", task_num, count);
> >> - printf("calling read task = %u\n", task_num);
> >> + CAN_DEBUG("calling read task = %u\n", task_num);
> >> count = read(fd, &msg, sizeof(msg));
> >> rtems_test_assert(count > 0);
> > Since you send the messages, you know their sizes. You should be able
> > to assert the exact amount received?
> Yes, and you probably know also the expected content of the message.
> This should be also checked. If there are ordering guarantees, then each
> message should have a unique content and the ordering should be checked
> as well.
The CAN framework has only minimal Rx support (CAN Framework sends the
latest received CAN message).
So only the read success is checked.
Regards
Prashanth S
On Tue, 29 Nov 2022 at 12:24, Sebastian Huber <
> as well.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221129/6b2dba10/attachment-0001.htm>
