[PATCH] cpukit/include/dev/can: Disabled debug prints in CAN Framework
Sebastian Huber
Tue Nov 29 06:54:40 UTC 2022
On 29/11/2022 05:57, Gedare Bloom wrote:
>> @@ -111,18 +113,18 @@ static void test_task(rtems_task_argument data)
>> msg_size = ((char *)&msg.data[msg.len] - (char *)&msg);
>> - printf("calling write task = %u\n", task_num);
>> + CAN_DEBUG("calling write task = %u\n", task_num);
> The general philosophy in our test suite is to only print something if
> there's a failure. So just remove these debug statements that are
> leftover from your development approach.
Another approach could be to use the RTEMS Test Framework in which the
test verbosity is controlled by a configuration option.
>> count = write(fd, &msg, sizeof(msg));
>> rtems_test_assert(count == msg_size);
>> - printf("task = %u write count = %u\n", task_num, count);
>> + CAN_DEBUG("task = %u write count = %u\n", task_num, count);
>> - printf("calling read task = %u\n", task_num);
>> + CAN_DEBUG("calling read task = %u\n", task_num);
>> count = read(fd, &msg, sizeof(msg));
>> rtems_test_assert(count > 0);
> Since you send the messages, you know their sizes. You should be able
> to assert the exact amount received?
Yes, and you probably know also the expected content of the message.
This should be also checked. If there are ordering guarantees, then each
message should have a unique content and the ordering should be checked
as well.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
