[PATCH v3] bsp/aarch64: Add new Raspberry Pi 4B BSP
Alan Cudmore alan.cudmore at gmail.com
Tue Oct 4 21:38:04 UTC 2022
It builds without error and boots for me!
I ran my RTEMS Kernel Image and tried out some task demos, whetstone,
dhrystone, created a RAM disk, etc.
Next will be a core Flight System (cFS) run.
This is going to be a very useful board to have RTEMS + SMP + Libbsd on,
especially when people can buy them again.
Thanks!
Alan
RTEMS Kernel Image Booting
*** RTEMS Info ***
6.0.0.cc43dc3e22b21ddf902b7748fb27f16c9aee3719
 BSP Ticks Per Second = 100
*** End RTEMS info ***
Populating Root file system from TAR file.
Setting up filesystems.
Initializing Local Commands.
Adding Target specific commands
Running /shell-init.
1: mkdir ram
2: mkrfs /dev/rda
3: mount -t rfs /dev/rda /ram
mounted /dev/rda -> /ram
4: hello
    ____  ______________  ________
   / __ \/_  __/ ____/  \/  / ___/
  / /_/ / / / / __/ / /\_/ /\__ \
 / _, _/ / / / /___/ /  / /___/ /
/_/ \_| /_/ /_____/_/  /_//____/
Hello RTEMS!
Create your own command here!
Starting shell....
RTEMS Shell on /dev/console. Use 'help' to list commands.
shell0 [/] #
On Tue, Oct 4, 2022 at 2:40 PM Joel Sherrill <joel at rtems.org> wrote:
> Once Alan says it's OK, I will merge this.
> Great work! Please make sure code, docs, tester configuration, etc gets
> merged.
> On Tue, Oct 4, 2022 at 1:18 PM Kinsey Moore <kinsey.moore at oarcorp.com>
> wrote:
>> I think all of the issues with this patch have been addressed; this looks
>> good to me.
>> Great work, Noor!
>> Kinsey
>> On Tue, Oct 4, 2022 at 11:12 AM Noor Aman <nooraman5718 at gmail.com> wrote:
>>> hey all,
>>> I've fixed the warning and edited the commit message to be more specific
>>> and to be in 80 words char limit.
>>> Thanks,
>>> Noor
>>> On Tue, 4 Oct 2022 at 16:08, Mohd Noor Aman <nooraman5718 at gmail.com>
>>> wrote:
>>>> This patch adds new Raspberry pi 4B AArch64 BSP to the RTEMS Family.
>>>> Currently
>>>> only LP64 ABI is supported. ILP32 is not supported. RAM starts from
>>>> 0x80000 in
>>>> 64Bit kernel mode and MMU from 0x0. All Raspberrypi Pi 4B models and
>>>> Raspberry
>>>> Pi 400 are supported. All the IRQs are similiar to the older Raspberry
>>>> pi 2 ARM
>>>> BSP.
>>>> Raspberry Pi 4B has 2 types of UARTs. Only PL011 serial is supported
>>>> currently.
>>>> Mini-UART is not supported. Mini-UART is default UART on the board so
>>>> it needs
>>>> to be disabled by adding "dtoverlay=disable-bt" to the config.txt. No
>>>> support
>>>> for additional 4 PL011-UARTs on the board.
>>>> The raspberrypi.h includes many of the address required for the future
>>>> development of the RPi 4B BSP. This includes peripherals, ARM Timer,
>>>> VideoCore
>>>> Timer, Watchdog, Mailbox, AUX, FIQs and IRQs.
>>>>  bsps/aarch64/raspberrypi/console/console.c    |  69 +++
>>>>  bsps/aarch64/raspberrypi/include/bsp.h        |  76 +++
>>>>  bsps/aarch64/raspberrypi/include/bsp/irq.h    | 109 ++++
>>>>  .../raspberrypi/include/bsp/raspberrypi.h     | 471 ++++++++++++++++++
>>>>  bsps/aarch64/raspberrypi/include/tm27.h       |  46 ++
>>>>  bsps/aarch64/raspberrypi/start/bspstart.c     |  49 ++
>>>>  .../aarch64/raspberrypi/start/bspstarthooks.c |  53 ++
>>>>  bsps/aarch64/raspberrypi/start/bspstartmmu.c  |  84 ++++
>>>>  spec/build/bsps/aarch64/raspberrypi/abi.yml   |  21 +
>>>>  .../aarch64/raspberrypi/bspraspberrypi4.yml   |  81 +++
>>>>  .../bsps/aarch64/raspberrypi/linkercmds.yml   |  76 +++
>>>>  11 files changed, 1135 insertions(+)
>>>>  create mode 100644 bsps/aarch64/raspberrypi/console/console.c
>>>>  create mode 100644 bsps/aarch64/raspberrypi/include/bsp.h
>>>>  create mode 100644 bsps/aarch64/raspberrypi/include/bsp/irq.h
>>>>  create mode 100644 bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>>  create mode 100644 bsps/aarch64/raspberrypi/include/tm27.h
>>>>  create mode 100644 bsps/aarch64/raspberrypi/start/bspstart.c
>>>>  create mode 100644 bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>>>  create mode 100644 bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>>>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/abi.yml
>>>>  create mode 100644
>>>> spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>>>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>>> diff --git a/bsps/aarch64/raspberrypi/console/console.c
>>>> b/bsps/aarch64/raspberrypi/console/console.c
>>>> new file mode 100644
>>>> index 0000000000..73bb0036ff
>>>> --- /dev/null
>>>> +++ b/bsps/aarch64/raspberrypi/console/console.c
>>>> @@ -0,0 +1,69 @@
>>>> +/* SPDX-License-Identifier: BSD-2-Clause */
>>>> + * @file
>>>> + * @ingroup RTEMSBSPsAArch64Raspberrypi4
>>>> + * @brief Console Configuration
>>>> + * Copyright (C) 2022 Mohd Noor Aman
>>>> + * Redistribution and use in source and binary forms, with or without
>>>> + * modification, are permitted provided that the following conditions
>>>> + * are met:
>>>> + * 1. Redistributions of source code must retain the above copyright
>>>> + *    notice, this list of conditions and the following disclaimer.
>>>> + * 2. Redistributions in binary form must reproduce the above copyright
>>>> + *    notice, this list of conditions and the following disclaimer in
>>>> the
>>>> + *    documentation and/or other materials provided with the
>>>> distribution.
>>>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>>>> "AS IS"
>>>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>>> TO, THE
>>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>>> PURPOSE
>>>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>>>> CONTRIBUTORS BE
>>>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>>>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>> BUSINESS
>>>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>> WHETHER IN
>>>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>> OTHERWISE)
>>>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>>>> OF THE
>>>> + * POSSIBILITY OF SUCH DAMAGE.
>>>> +#include <rtems/bspIo.h>
>>>> +#include <bsp.h>
>>>> +#include <dev/serial/arm-pl011.h>
>>>> +#include <bsp/console-termios.h>
>>>> +#include <bspopts.h>
>>>> +arm_pl011_context raspberrypi_4_context = {
>>>> +  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
>>>> +  .regs = (volatile pl011 *) BSP_RPI4_PL011_BASE,
>>>> +  .initial_baud = 115200
>>>> +const console_device console_device_table[] = {
>>>> +    .device_file = "/dev/ttyS0",
>>>> +    .probe = console_device_probe_default,
>>>> +    .handler = &arm_pl011_fns,
>>>> +    .context = &raspberrypi_4_context.base
>>>> +const size_t console_device_count =
>>>> RTEMS_ARRAY_SIZE(console_device_table);
>>>> +static void output_char( char c )
>>>> +  arm_pl011_write_polled(&raspberrypi_4_context.base, c);
>>>> +BSP_output_char_function_type BSP_output_char = output_char;
>>>> +BSP_polling_getchar_function_type BSP_poll_char = NULL;
>>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp.h
>>>> b/bsps/aarch64/raspberrypi/include/bsp.h
>>>> index 0000000000..4fa81edd40
>>>> --- /dev/null
>>>> +++ b/bsps/aarch64/raspberrypi/include/bsp.h
>>>> @@ -0,0 +1,76 @@
>>>> + * @file
>>>> + * @brief Core BSP definitions
>>>> + * are met:
>>>> the
>>>> distribution.
>>>> "AS IS"
>>>> TO, THE
>>>> PURPOSE
>>>> CONTRIBUTORS BE
>>>> BUSINESS
>>>> WHETHER IN
>>>> OTHERWISE)
>>>> OF THE
>>>> +#ifndef LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H
>>>> +#define LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H
>>>> + * @addtogroup RTEMSBSPsAArch64
>>>> +#ifndef ASM
>>>> +#include <bsp/default-initial-extension.h>
>>>> +#include <bsp/start.h>
>>>> +#include <rtems.h>
>>>> +/*Raspberry pi MMU initialization */
>>>> +BSP_START_TEXT_SECTION void raspberrypi_4_setup_mmu_and_cache(void);
>>>> +#ifdef __cplusplus
>>>> +extern "C" {
>>>> +#endif /* __cplusplus */
>>>> +#define BSP_ARM_GIC_CPUIF_BASE 0xFF842000
>>>> +#define BSP_ARM_GIC_DIST_BASE 0xFF841000
>>>> +#define BSP_RPI4_PL011_BASE 0xFE201000
>>>> +#define BSP_RPI4_PL011_LENGTH 0x200
>>>> +#ifdef __cplusplus
>>>> +#endif /* ASM */
>>>> +#endif /* LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H */
>>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp/irq.h
>>>> b/bsps/aarch64/raspberrypi/include/bsp/irq.h
>>>> index 0000000000..effec1b040
>>>> --- /dev/null
>>>> +++ b/bsps/aarch64/raspberrypi/include/bsp/irq.h
>>>> @@ -0,0 +1,109 @@
>>>> + * @file
>>>> + * @ingroup raspberrypi_interrupt
>>>> + * @brief Interrupt definitions.
>>>> + * Copyright (c) 2013 Alan Cudmore
>>>> + * Copyright (c) 2022 Mohd Noor Aman
>>>> + *  The license and distribution terms for this file may be
>>>> + *  found in the file LICENSE in this distribution or at
>>>> + *  http://www.rtems.org/license/LICENSE
>>>> +#ifndef LIBBSP_ARM_RASPBERRYPI_IRQ_H
>>>> +#define LIBBSP_ARM_RASPBERRYPI_IRQ_H
>>>> +#ifndef ASM
>>>> +#include <rtems.h>
>>>> +#include <rtems/irq.h>
>>>> +#include <rtems/irq-extension.h>
>>>> +#include <dev/irq/arm-gic-irq.h>
>>>> +#if defined(RTEMS_SMP)
>>>> +#include <rtems/score/processormask.h>
>>>> +#endif
>>>> + * @defgroup raspberrypi_interrupt Interrrupt Support
>>>> + * @ingroup RTEMSBSPsARMRaspberryPi
>>>> + * @brief Interrupt support.
>>>> +#define BCM2835_INTC_TOTAL_IRQ       (64 + 8)
>>>> +#define BCM2835_IRQ_SET1_MIN         0
>>>> +#define BCM2835_IRQ_SET2_MIN         32
>>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M0  0
>>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M1  1
>>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M2  2
>>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M3  3
>>>> +#define BCM2835_IRQ_ID_USB           9
>>>> +#define BCM2835_IRQ_ID_AUX           29
>>>> +#define BCM2835_IRQ_ID_SPI_SLAVE     43
>>>> +#define BCM2835_IRQ_ID_PWA0          45
>>>> +#define BCM2835_IRQ_ID_PWA1          46
>>>> +#define BCM2835_IRQ_ID_SMI           48
>>>> +#define BCM2835_IRQ_ID_GPIO_0        49
>>>> +#define BCM2835_IRQ_ID_GPIO_1        50
>>>> +#define BCM2835_IRQ_ID_GPIO_2        51
>>>> +#define BCM2835_IRQ_ID_GPIO_3        52
>>>> +#define BCM2835_IRQ_ID_I2C           53
>>>> +#define BCM2835_IRQ_ID_SPI           54
>>>> +#define BCM2835_IRQ_ID_PCM           55
>>>> +#define BCM2835_IRQ_ID_UART          57
>>>> +#define BCM2835_IRQ_ID_SD            62
>>>> +#define BCM2835_IRQ_ID_BASIC_BASE_ID 64
>>>> +#define BCM2835_IRQ_ID_TIMER_0       64
>>>> +#define BCM2835_IRQ_ID_MAILBOX_0     65
>>>> +#define BCM2835_IRQ_ID_DOORBELL_0    66
>>>> +#define BCM2835_IRQ_ID_DOORBELL_1    67
>>>> +#define BCM2835_IRQ_ID_GPU0_HALTED   68
>>>> +#define BCM2835_IRQ_ID_GPU1_HALTED   69
>>>> +#define BCM2835_IRQ_ID_ILL_ACCESS_1  70
>>>> +#define BCM2835_IRQ_ID_ILL_ACCESS_0  71
>>>> +#define BSP_TIMER_VIRT_PPI 27
>>>> +#define BSP_TIMER_PHYS_NS_PPI 30
>>>> +#define BSP_VPL011_SPI 32
>>>> +#define BSP_INTERRUPT_VECTOR_COUNT    BCM2835_INTC_TOTAL_IRQ
>>>> +#define BSP_INTERRUPT_VECTOR_INVALID (UINT32_MAX)
>>>> +#define BSP_IRQ_COUNT               (BCM2835_INTC_TOTAL_IRQ)
>>>> +static inline rtems_status_code bsp_interrupt_set_affinity(
>>>> +  rtems_vector_number   vector,
>>>> +  const Processor_mask *affinity
>>>> +  (void) vector;
>>>> +  (void) affinity;
>>>> +  return RTEMS_UNSATISFIED;
>>>> +static inline rtems_status_code bsp_interrupt_get_affinity(
>>>> +  Processor_mask      *affinity
>>>> +  (void) vector;
>>>> +  _Processor_mask_From_index( affinity, 0 );
>>>> +#endif
>>>> +#endif /* ASM */
>>>> +#endif /* LIBBSP_ARM_RASPBERRYPI_IRQ_H */
>>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>> b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>> index 0000000000..f148e8df6c
>>>> --- /dev/null
>>>> +++ b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>> @@ -0,0 +1,471 @@
>>>> + * @file
>>>> + * @ingroup raspberrypi_4_regs
>>>> + * @brief Register definitions.
>>>> +#ifndef LIBBSP_AARCH64_RASPBERRYPI_RASPBERRYPI_4_H
>>>> +#define LIBBSP_AARCH64_RASPBERRYPI_RASPBERRYPI_4_H
>>>> +#include <stdint.h>
>>>> +#include <bsp/utility.h>
>>>> + * @defgroup raspberrypi_reg Register Definitions
>>>> + * @brief Register Definitions
>>>> + * @name Register Macros
>>>> +#define BCM2711_REG(x)           (*(volatile uint64_t *)(x))
>>>> +#define BCM2711_BIT(n)           (1 << (n))
>>>> + * @name Peripheral Base Register Address
>>>> +#define RPI_PERIPHERAL_BASE         0xFE000000
>>>> +#define BASE_OFFSET                 0xFE000000
>>>> +#define RPI_PERIPHERAL_SIZE         0x01800000
>>>> + * @name Bus to Physical address translation
>>>> + *       Macro.
>>>> +#define BUS_TO_PHY(x)            ((x) - BASE_OFFSET)
>>>> + * @name Internal ARM Timer Registers
>>>> +#define BCM2711_CLOCK_FREQ       250000000
>>>> +#define BCM2711_TIMER_BASE       (RPI_PERIPHERAL_BASE + 0xB400)
>>>> +#define BCM2711_TIMER_LOD        (BCM2711_TIMER_BASE + 0x00)
>>>> +#define BCM2711_TIMER_VAL        (BCM2711_TIMER_BASE + 0x04)
>>>> +#define BCM2711_TIMER_CTL        (BCM2711_TIMER_BASE + 0x08)
>>>> +#define BCM2711_TIMER_CLI        (BCM2711_TIMER_BASE + 0x0C)
>>>> +#define BCM2711_TIMER_RIS        (BCM2711_TIMER_BASE + 0x10)
>>>> +#define BCM2711_TIMER_MIS        (BCM2711_TIMER_BASE + 0x14)
>>>> +#define BCM2711_TIMER_RLD        (BCM2711_TIMER_BASE + 0x18)
>>>> +#define BCM2711_TIMER_DIV        (BCM2711_TIMER_BASE + 0x1C)
>>>> +#define BCM2711_TIMER_CNT        (BCM2711_TIMER_BASE + 0x20)
>>>> +#define BCM2711_TIMER_PRESCALE    0xF9
>>>> + * @name Power Management and Watchdog  Registers
>>>> +#define BCM2711_PM_PASSWD_MAGIC  0x5a000000
>>>> +#define BCM2711_PM_BASE          (RPI_PERIPHERAL_BASE + 0x100000)
>>>> +#define BCM2711_PM_GNRIC         (BCM2711_PM_BASE + 0x00)
>>>> +#define BCM2711_PM_GNRIC_POWUP   0x00000001
>>>> +#define BCM2711_PM_GNRIC_POWOK   0x00000002
>>>> +#define BCM2711_PM_GNRIC_ISPOW   0x00000004
>>>> +#define BCM2711_PM_GNRIC_MEMREP  0x00000008
>>>> +#define BCM2711_PM_GNRIC_MRDONE  0x00000010
>>>> +#define BCM2711_PM_GNRIC_ISFUNC  0x00000020
>>>> +#define BCM2711_PM_GNRIC_RSTN    0x00000fc0
>>>> +#define BCM2711_PM_GNRIC_ENAB    0x00001000
>>>> +#define BCM2711_PM_GNRIC_CFG     0x007f0000
>>>> +#define BCM2711_PM_AUDIO         (BCM2711_PM_BASE + 0x04)
>>>> +#define BCM2711_PM_AUDIO_APSM    0x000fffff
>>>> +#define BCM2711_PM_AUDIO_CTRLEN  0x00100000
>>>> +#define BCM2711_PM_AUDIO_RSTN    0x00200000
>>>> +#define BCM2711_PM_STATUS        (BCM2711_PM_BASE + 0x18)
>>>> +#define BCM2711_PM_RSTC          (BCM2711_PM_BASE + 0x1c)
>>>> +#define BCM2711_PM_RSTC_DRCFG    0x00000003
>>>> +#define BCM2711_PM_RSTC_WRCFG    0x00000030
>>>> +#define BCM2711_PM_RSTC_WRCFG_FULL   0x00000020
>>>> +#define BCM2711_PM_RSTC_SRCFG    0x00000300
>>>> +#define BCM2711_PM_RSTC_QRCFG    0x00003000
>>>> +#define BCM2711_PM_RSTC_FRCFG    0x00030000
>>>> +#define BCM2711_PM_RSTC_HRCFG    0x00300000
>>>> +#define BCM2711_PM_RSTS          (BCM2711_PM_BASE + 0x20)
>>>> +#define BCM2711_PM_RSTS_HADDRQ   0x00000001
>>>> +#define BCM2711_PM_RSTS_HADDRF   0x00000002
>>>> +#define BCM2711_PM_RSTS_HADDRH   0x00000004
>>>> +#define BCM2711_PM_RSTS_HADWRQ   0x00000010
>>>> +#define BCM2711_PM_RSTS_HADWRF   0x0000002
>>>> +#define BCM2711_PM_RSTS_HADWRH   0x00000040
>>>> +#define BCM2711_PM_RSTS_HADSRQ   0x00000100
>>>> +#define BCM2711_PM_RSTS_HADSRF   0x00000200
>>>> +#define BCM2711_PM_RSTS_HADSRH   0x00000400
>>>> +#define BCM2711_PM_RSTS_HADPOR   0x00001000
>>>> +#define BCM2711_PM_WDOG          (BCM2711_PM_BASE + 0x24)
>>>> + * @name AUX Registers
>>>> +#define BCM2711_AUX_BASE         (RPI_PERIPHERAL_BASE + 0x215000)
>>>> +#define AUX_ENABLES              (BCM2711_AUX_BASE + 0x04)
>>>> +#define AUX_MU_IO_REG            (BCM2711_AUX_BASE + 0x40)
>>>> +#define AUX_MU_IER_REG           (BCM2711_AUX_BASE + 0x44)
>>>> +#define AUX_MU_IIR_REG           (BCM2711_AUX_BASE + 0x48)
>>>> +#define AUX_MU_LCR_REG           (BCM2711_AUX_BASE + 0x4C)
>>>> +#define AUX_MU_MCR_REG           (BCM2711_AUX_BASE + 0x50)
>>>> +#define AUX_MU_LSR_REG           (BCM2711_AUX_BASE + 0x54)
>>>> +#define AUX_MU_MSR_REG           (BCM2711_AUX_BASE + 0x58)
>>>> +#define AUX_MU_SCRATCH           (BCM2711_AUX_BASE + 0x5C)
>>>> +#define AUX_MU_CNTL_REG          (BCM2711_AUX_BASE + 0x60)
>>>> +#define AUX_MU_STAT_REG          (BCM2711_AUX_BASE + 0x64)
>>>> +#define AUX_MU_BAUD_REG          (BCM2711_AUX_BASE + 0x68)
>>>> + * @name GPU Timer Registers
>>>> + * NOTE: The GPU uses Compare registers 0 and 2 for
>>>> + *       it's own RTOS. 1 and 3 are available for use in
>>>> + *       RTEMS.
>>>> +#define BCM2711_GPU_TIMER_BASE       (RPI_PERIPHERAL_BASE + 0x3000)
>>>> +#define BCM2711_GPU_TIMER_CS         (BCM2711_GPU_TIMER_BASE + 0x00)
>>>> +#define BCM2711_GPU_TIMER_CS_M0      0x00000001
>>>> +#define BCM2711_GPU_TIMER_CS_M1      0x00000002
>>>> +#define BCM2711_GPU_TIMER_CS_M2      0x00000004
>>>> +#define BCM2711_GPU_TIMER_CS_M3      0x00000008
>>>> +#define BCM2711_GPU_TIMER_CLO        (BCM2711_GPU_TIMER_BASE + 0x04)
>>>> +#define BCM2711_GPU_TIMER_CHI        (BCM2711_GPU_TIMER_BASE + 0x08)
>>>> +#define BCM2711_GPU_TIMER_C0         (BCM2711_GPU_TIMER_BASE + 0x0C)
>>>> +#define BCM2711_GPU_TIMER_C1         (BCM2711_GPU_TIMER_BASE + 0x10)
>>>> +#define BCM2711_GPU_TIMER_C2         (BCM2711_GPU_TIMER_BASE + 0x14)
>>>> +#define BCM2711_GPU_TIMER_C3         (BCM2711_GPU_TIMER_BASE + 0x18)
>>>> + * @name EMMC Registers
>>>> + * NOTE: Since the SD controller follows the SDHCI standard,
>>>> + *       the rtems-libbsd tree already provides the remaining
>>>> registers.
>>>> +#define BCM2711_EMMC_BASE           (RPI_PERIPHERAL_BASE + 0x300000)
>>>> +* @name Mailbox Registers
>>>> +#define BCM2711_MBOX_BASE          (RPI_PERIPHERAL_BASE+0xB880)
>>>> +#define BCM2711_MBOX_READ          (BCM2711_MBOX_BASE+0x00)
>>>> +#define BCM2711_MBOX_PEEK          (BCM2711_MBOX_BASE+0x10)
>>>> +#define BCM2711_MBOX_SENDER        (BCM2711_MBOX_BASE+0x14)
>>>> +#define BCM2711_MBOX_STATUS        (BCM2711_MBOX_BASE+0x18)
>>>> +#define BCM2711_MBOX_WRITE         (BCM2711_MBOX_BASE+0x20)
>>>> +#define BCM2711_MBOX_CONFIG        (BCM2711_MBOX_BASE+0x1C)
>>>> +#define BCM2711_MBOX_RESPONSE      0x80000000
>>>> +#define BCM2711_MBOX_FULL          0x80000000
>>>> +#define BCM2711_MBOX_EMPTY         0x40000000
>>>> +* @name Mailbox Channels
>>>> +/* Power Manager channel */
>>>> +#define BCM2711_MBOX_CHANNEL_PM         0
>>>> +/* Framebuffer channel */
>>>> +#define BCM2711_MBOX_CHANNEL_FB         1
>>>> + /* Virtual UART channel */
>>>> +#define BCM2711_MBOX_CHANNEL_VUART      2
>>>> + /* VCHIQ channel */
>>>> +#define BCM2711_MBOX_CHANNEL_VCHIQ      3
>>>> + /* LEDs channel */
>>>> +#define BCM2711_MBOX_CHANNEL_LED        4
>>>> + /* Button channel */
>>>> +#define BCM2711_MBOX_CHANNEL_BUTTON     5
>>>> + /* Touch screen channel */
>>>> +#define BCM2711_MBOX_CHANNEL_TOUCHS     6
>>>> +#define BCM2711_MBOX_CHANNEL_COUNT      7
>>>> +/* Property tags (ARM <-> VC) channel */
>>>> +#define BCM2711_MBOX_CHANNEL_PROP_AVC   8
>>>> + /* Property tags (VC <-> ARM) channel */
>>>> +#define BCM2711_MBOX_CHANNEL_PROP_VCA   9
>>>> + * @name Raspberry Pi 2 Interrupt Register Defines
>>>> +/* Timers interrupt control registers */
>>>> +#define BCM2711_CORE0_TIMER_IRQ_CTRL_BASE       0xFF800040
>>>> +#define BCM2711_CORE1_TIMER_IRQ_CTRL_BASE       0xFF800044
>>>> +#define BCM2711_CORE2_TIMER_IRQ_CTRL_BASE       0xFF800048
>>>> +#define BCM2711_CORE3_TIMER_IRQ_CTRL_BASE       0xFF80004C
>>>> +#define BCM2711_CORE_TIMER_IRQ_CTRL(cpuidx) \
>>>> +  (BCM2711_CORE0_TIMER_IRQ_CTRL_BASE + 0x4 * (cpuidx))
>>>> + * @name Raspberry Pi 4 ARM_LOCAL registers
>>>> +#define BCM2711_LOCAL_REGS_BASE               0x4C0000000
>>>> +#define BCM2711_LOCAL_REGS_SIZE               0x100
>>>> +#define BCM2711_LOCAL_ARM_CONTROL             (BCM2711_LOCAL_REGS_BASE
>>>> + 0x00)
>>>> +#define BCM2711_LOCAL_CORE_IRQ_CONTROL        (BCM2711_LOCAL_REGS_BASE
>>>> + 0x0c)
>>>> +#define BCM2711_LOCAL_PMU_CONTROL_SET         (BCM2711_LOCAL_REGS_BASE
>>>> + 0x10)
>>>> +#define BCM2711_LOCAL_PMU_CONTROL_CLR         (BCM2711_LOCAL_REGS_BASE
>>>> + 0x14)
>>>> +#define BCM2711_LOCAL_PERI_IRQ_ROUTE0         (BCM2711_LOCAL_REGS_BASE
>>>> + 0x24)
>>>> +#define BCM2711_LOCAL_AXI_QUIET_TIME          (BCM2711_LOCAL_REGS_BASE
>>>> + 0x30)
>>>> +#define BCM2711_LOCAL_LOCAL_TIMER_CONTROL     (BCM2711_LOCAL_REGS_BASE
>>>> + 0x34)
>>>> +#define BCM2711_LOCAL_LOCAL_TIMER_IRQ         (BCM2711_LOCAL_REGS_BASE
>>>> + 0x38)
>>>> +#define BCM2711_LOCAL_TIMER_CNTRL0            (BCM2711_LOCAL_REGS_BASE
>>>> + 0x40)
>>>> +#define BCM2711_LOCAL_TIMER_CNTRL1            (BCM2711_LOCAL_REGS_BASE
>>>> + 0x44)
>>>> +#define BCM2711_LOCAL_TIMER_CNTRL2            (BCM2711_LOCAL_REGS_BASE
>>>> + 0x48)
>>>> +#define BCM2711_LOCAL_TIMER_CNTRL3            (BCM2711_LOCAL_REGS_BASE
>>>> + 0x4c)
>>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL0          (BCM2711_LOCAL_REGS_BASE
>>>> + 0x50)
>>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL1          (BCM2711_LOCAL_REGS_BASE
>>>> + 0x54)
>>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL2          (BCM2711_LOCAL_REGS_BASE
>>>> + 0x58)
>>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL3          (BCM2711_LOCAL_REGS_BASE
>>>> + 0x5c)
>>>> +#define BCM2711_LOCAL_IRQ_SOURCE0             (BCM2711_LOCAL_REGS_BASE
>>>> + 0x60)
>>>> +#define BCM2711_LOCAL_IRQ_SOURCE1             (BCM2711_LOCAL_REGS_BASE
>>>> + 0x64)
>>>> +#define BCM2711_LOCAL_IRQ_SOURCE2             (BCM2711_LOCAL_REGS_BASE
>>>> + 0x68)
>>>> +#define BCM2711_LOCAL_IRQ_SOURCE3             (BCM2711_LOCAL_REGS_BASE
>>>> + 0x6c)
>>>> +#define BCM2711_LOCAL_FIQ_SOURCE0             (BCM2711_LOCAL_REGS_BASE
>>>> + 0x70)
>>>> +#define BCM2711_LOCAL_FIQ_SOURCE1             (BCM2711_LOCAL_REGS_BASE
>>>> + 0x74)
>>>> +#define BCM2711_LOCAL_FIQ_SOURCE2             (BCM2711_LOCAL_REGS_BASE
>>>> + 0x78)
>>>> +#define BCM2711_LOCAL_FIQ_SOURCE3             (BCM2711_LOCAL_REGS_BASE
>>>> + 0x7c)
>>>> + * @name Raspberry Pi 4 Mailbox registers
>>>> +#define BCM2711_MAILBOX_00_WRITE_SET_BASE               0x4C000080
>>>> +#define BCM2711_MAILBOX_01_WRITE_SET_BASE               0x4C000084
>>>> +#define BCM2711_MAILBOX_02_WRITE_SET_BASE               0x4C000088
>>>> +#define BCM2711_MAILBOX_03_WRITE_SET_BASE               0x4C00008C
>>>> +#define BCM2711_MAILBOX_04_WRITE_SET_BASE               0x4C000090
>>>> +#define BCM2711_MAILBOX_05_WRITE_SET_BASE               0x4C000094
>>>> +#define BCM2711_MAILBOX_06_WRITE_SET_BASE               0x4C000098
>>>> +#define BCM2711_MAILBOX_07_WRITE_SET_BASE               0x4C00009C
>>>> +#define BCM2711_MAILBOX_08_WRITE_SET_BASE               0x4C0000A0
>>>> +#define BCM2711_MAILBOX_09_WRITE_SET_BASE               0x4C0000A4
>>>> +#define BCM2711_MAILBOX_10_WRITE_SET_BASE               0x4C0000A8
>>>> +#define BCM2711_MAILBOX_11_WRITE_SET_BASE               0x4C0000AC
>>>> +#define BCM2711_MAILBOX_12_WRITE_SET_BASE               0x4C0000B0
>>>> +#define BCM2711_MAILBOX_13_WRITE_SET_BASE               0x4C0000B4
>>>> +#define BCM2711_MAILBOX_14_WRITE_SET_BASE               0x4C0000B8
>>>> +#define BCM2711_MAILBOX_15_WRITE_SET_BASE               0x4C0000BC
>>>> +#define BCM2711_MAILBOX_00_READ_CLEAR_BASE              0x4C0000C0
>>>> +#define BCM2711_MAILBOX_01_READ_CLEAR_BASE              0x4C0000C4
>>>> +#define BCM2711_MAILBOX_02_READ_CLEAR_BASE              0x4C0000C8
>>>> +#define BCM2711_MAILBOX_03_READ_CLEAR_BASE              0x4C0000CC
>>>> +#define BCM2711_MAILBOX_04_READ_CLEAR_BASE              0x4C0000D0
>>>> +#define BCM2711_MAILBOX_05_READ_CLEAR_BASE              0x4C0000D4
>>>> +#define BCM2711_MAILBOX_06_READ_CLEAR_BASE              0x4C0000D8
>>>> +#define BCM2711_MAILBOX_07_READ_CLEAR_BASE              0x4C0000DC
>>>> +#define BCM2711_MAILBOX_08_READ_CLEAR_BASE              0x4C0000E0
>>>> +#define BCM2711_MAILBOX_09_READ_CLEAR_BASE              0x4C0000E4
>>>> +#define BCM2711_MAILBOX_10_READ_CLEAR_BASE              0x4C0000E8
>>>> +#define BCM2711_MAILBOX_11_READ_CLEAR_BASE              0x4C0000EC
>>>> +#define BCM2711_MAILBOX_12_READ_CLEAR_BASE              0x4C0000F0
>>>> +#define BCM2711_MAILBOX_13_READ_CLEAR_BASE              0x4C0000F4
>>>> +#define BCM2711_MAILBOX_14_READ_CLEAR_BASE              0x4C0000F8
>>>> +#define BCM2711_MAILBOX_15_READ_CLEAR_BASE              0x4C0000FC
>>>> + * @name Raspberry Pi 4 ARM_C FIQ and IRQ registers
>>>> +#define BCM2711_ARMC_REGS_BASE                 (RPI_PERIPHERAL_BASE +
>>>> 0xB200)
>>>> +#define BCM2711_ARMC_REGS_SIZE                 0x200
>>>> +#define BCM2711_ARMC_IRQ0_PENDING0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x00)
>>>> +#define BCM2711_ARMC_IRQ0_PENDING1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x04)
>>>> +#define BCM2711_ARMC_IRQ0_PENDING2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x08)
>>>> +#define BCM2711_ARMC_IRQ0_SET_EN_0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x10)
>>>> +#define BCM2711_ARMC_IRQ0_SET_EN_1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x14)
>>>> +#define BCM2711_ARMC_IRQ0_SET_EN_2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x18)
>>>> +#define BCM2711_ARMC_IRQ0_CLR_EN_0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x20)
>>>> +#define BCM2711_ARMC_IRQ0_CLR_EN_1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x24)
>>>> +#define BCM2711_ARMC_IRQ0_CLR_EN_2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x28)
>>>> +#define BCM2711_ARMC_IRQ_STATUS0               (BCM2711_ARMC_REGS_BASE
>>>> + 0x30)
>>>> +#define BCM2711_ARMC_IRQ_STATUS1               (BCM2711_ARMC_REGS_BASE
>>>> + 0x34)
>>>> +#define BCM2711_ARMC_IRQ_STATUS2               (BCM2711_ARMC_REGS_BASE
>>>> + 0x38)
>>>> +#define BCM2711_ARMC_IRQ1_PENDING0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x40)
>>>> +#define BCM2711_ARMC_IRQ1_PENDING1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x44)
>>>> +#define BCM2711_ARMC_IRQ1_PENDING2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x48)
>>>> +#define BCM2711_ARMC_IRQ1_SET_EN_0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x50)
>>>> +#define BCM2711_ARMC_IRQ1_SET_EN_1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x54)
>>>> +#define BCM2711_ARMC_IRQ1_SET_EN_2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x58)
>>>> +#define BCM2711_ARMC_IRQ1_CLR_EN_0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x60)
>>>> +#define BCM2711_ARMC_IRQ1_CLR_EN_1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x64)
>>>> +#define BCM2711_ARMC_IRQ1_CLR_EN_2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x68)
>>>> +#define BCM2711_ARMC_IRQ2_PENDING0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x80)
>>>> +#define BCM2711_ARMC_IRQ2_PENDING1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x84)
>>>> +#define BCM2711_ARMC_IRQ2_PENDING2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x88)
>>>> +#define BCM2711_ARMC_IRQ2_SET_EN_0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x90)
>>>> +#define BCM2711_ARMC_IRQ2_SET_EN_1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x94)
>>>> +#define BCM2711_ARMC_IRQ2_SET_EN_2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x98)
>>>> +#define BCM2711_ARMC_IRQ2_CLR_EN_0             (BCM2711_ARMC_REGS_BASE
>>>> + 0xA0)
>>>> +#define BCM2711_ARMC_IRQ2_CLR_EN_1             (BCM2711_ARMC_REGS_BASE
>>>> + 0xA4)
>>>> +#define BCM2711_ARMC_IRQ2_CLR_EN_2             (BCM2711_ARMC_REGS_BASE
>>>> + 0xA8)
>>>> +#define BCM2711_ARMC_IRQ3_PENDING0             (BCM2711_ARMC_REGS_BASE
>>>> + 0xC0)
>>>> +#define BCM2711_ARMC_IRQ3_PENDING1             (BCM2711_ARMC_REGS_BASE
>>>> + 0xC4)
>>>> +#define BCM2711_ARMC_IRQ3_PENDING2             (BCM2711_ARMC_REGS_BASE
>>>> + 0xC8)
>>>> +#define BCM2711_ARMC_IRQ3_SET_EN_0             (BCM2711_ARMC_REGS_BASE
>>>> + 0xD0)
>>>> +#define BCM2711_ARMC_IRQ3_SET_EN_1             (BCM2711_ARMC_REGS_BASE
>>>> + 0xD4)
>>>> +#define BCM2711_ARMC_IRQ3_SET_EN_2             (BCM2711_ARMC_REGS_BASE
>>>> + 0xD8)
>>>> +#define BCM2711_ARMC_IRQ3_CLR_EN_0             (BCM2711_ARMC_REGS_BASE
>>>> + 0xE0)
>>>> +#define BCM2711_ARMC_IRQ3_CLR_EN_1             (BCM2711_ARMC_REGS_BASE
>>>> + 0xE4)
>>>> +#define BCM2711_ARMC_IRQ3_CLR_EN_2             (BCM2711_ARMC_REGS_BASE
>>>> + 0xE8)
>>>> +#define BCM2711_ARMC_FIQ0_PENDING0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x100)
>>>> +#define BCM2711_ARMC_FIQ0_PENDING1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x104)
>>>> +#define BCM2711_ARMC_FIQ0_PENDING2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x108)
>>>> +#define BCM2711_ARMC_FIQ0_SET_EN_0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x110)
>>>> +#define BCM2711_ARMC_FIQ0_SET_EN_1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x114)
>>>> +#define BCM2711_ARMC_FIQ0_SET_EN_2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x118)
>>>> +#define BCM2711_ARMC_FIQ0_CLR_EN_0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x120)
>>>> +#define BCM2711_ARMC_FIQ0_CLR_EN_1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x124)
>>>> +#define BCM2711_ARMC_FIQ0_CLR_EN_2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x128)
>>>> +#define BCM2711_ARMC_FIQ1_PENDING0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x140)
>>>> +#define BCM2711_ARMC_FIQ1_PENDING1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x144)
>>>> +#define BCM2711_ARMC_FIQ1_PENDING2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x148)
>>>> +#define BCM2711_ARMC_FIQ1_SET_EN_0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x150)
>>>> +#define BCM2711_ARMC_FIQ1_SET_EN_1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x154)
>>>> +#define BCM2711_ARMC_FIQ1_SET_EN_2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x158)
>>>> +#define BCM2711_ARMC_FIQ1_CLR_EN_0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x160)
>>>> +#define BCM2711_ARMC_FIQ1_CLR_EN_1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x164)
>>>> +#define BCM2711_ARMC_FIQ1_CLR_EN_2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x168)
>>>> +#define BCM2711_ARMC_FIQ2_PENDING0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x180)
>>>> +#define BCM2711_ARMC_FIQ2_PENDING1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x184)
>>>> +#define BCM2711_ARMC_FIQ2_PENDING2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x188)
>>>> +#define BCM2711_ARMC_FIQ2_SET_EN_0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x190)
>>>> +#define BCM2711_ARMC_FIQ2_SET_EN_1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x194)
>>>> +#define BCM2711_ARMC_FIQ2_SET_EN_2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x198)
>>>> +#define BCM2711_ARMC_FIQ2_CLR_EN_0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x1A0)
>>>> +#define BCM2711_ARMC_FIQ2_CLR_EN_1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x1A4)
>>>> +#define BCM2711_ARMC_FIQ2_CLR_EN_2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x1A8)
>>>> +#define BCM2711_ARMC_FIQ3_PENDING0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x1C0)
>>>> +#define BCM2711_ARMC_FIQ3_PENDING1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x1C4)
>>>> +#define BCM2711_ARMC_FIQ3_PENDING2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x1C8)
>>>> +#define BCM2711_ARMC_FIQ3_SET_EN_0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x1D0)
>>>> +#define BCM2711_ARMC_FIQ3_SET_EN_1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x1D4)
>>>> +#define BCM2711_ARMC_FIQ3_SET_EN_2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x1D8)
>>>> +#define BCM2711_ARMC_FIQ3_CLR_EN_0             (BCM2711_ARMC_REGS_BASE
>>>> + 0x1E0)
>>>> +#define BCM2711_ARMC_FIQ3_CLR_EN_1             (BCM2711_ARMC_REGS_BASE
>>>> + 0x1E4)
>>>> +#define BCM2711_ARMC_FIQ3_CLR_EN_2             (BCM2711_ARMC_REGS_BASE
>>>> + 0x1E8)
>>>> +#define BCM2711_ARMC_SWIRQ_SET                 (BCM2711_ARMC_REGS_BASE
>>>> + 0x1F0)
>>>> +#define BCM2711_ARMC_SWIRQ_CLEAR               (BCM2711_ARMC_REGS_BASE
>>>> + 0x1F4)
>>>> +#endif /* LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H */
>>>> diff --git a/bsps/aarch64/raspberrypi/include/tm27.h
>>>> b/bsps/aarch64/raspberrypi/include/tm27.h
>>>> index 0000000000..653f88ed01
>>>> --- /dev/null
>>>> +++ b/bsps/aarch64/raspberrypi/include/tm27.h
>>>> @@ -0,0 +1,46 @@
>>>> + * @file
>>>> + * @brief BSP tm27 header
>>>> + * are met:
>>>> the
>>>> distribution.
>>>> "AS IS"
>>>> TO, THE
>>>> PURPOSE
>>>> CONTRIBUTORS BE
>>>> BUSINESS
>>>> WHETHER IN
>>>> OTHERWISE)
>>>> OF THE
>>>> +#ifndef _RTEMS_TMTEST27
>>>> +#error "This is an RTEMS internal file you must not include directly."
>>>> +#endif
>>>> +#ifndef __tm27_h
>>>> +#define __tm27_h
>>>> +#include <dev/irq/arm-gic-tm27.h>
>>>> +#endif /* __tm27_h */
>>>> \ No newline at end of file
>>>> diff --git a/bsps/aarch64/raspberrypi/start/bspstart.c
>>>> b/bsps/aarch64/raspberrypi/start/bspstart.c
>>>> index 0000000000..56f52a2231
>>>> --- /dev/null
>>>> +++ b/bsps/aarch64/raspberrypi/start/bspstart.c
>>>> @@ -0,0 +1,49 @@
>>>> + * @file
>>>> + * @brief BSP Startup
>>>> + * are met:
>>>> the
>>>> distribution.
>>>> "AS IS"
>>>> TO, THE
>>>> PURPOSE
>>>> CONTRIBUTORS BE
>>>> BUSINESS
>>>> WHETHER IN
>>>> OTHERWISE)
>>>> OF THE
>>>> +#include <bsp.h>
>>>> +#include <bsp/bootcard.h>
>>>> +#include <bsp/irq-generic.h>
>>>> +#include <bsp/linker-symbols.h>
>>>> +void bsp_start( void )
>>>> +  bsp_interrupt_initialize();
>>>> +  rtems_cache_coherent_add_area(
>>>> +    bsp_section_nocacheheap_begin,
>>>> +    (uintptr_t) bsp_section_nocacheheap_size
>>>> diff --git a/bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>>> b/bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>>> index 0000000000..fe0fe77c09
>>>> --- /dev/null
>>>> +++ b/bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>>> @@ -0,0 +1,53 @@
>>>> + * @file
>>>> + * @brief BSP Startup Hooks
>>>> + * are met:
>>>> the
>>>> distribution.
>>>> "AS IS"
>>>> TO, THE
>>>> PURPOSE
>>>> CONTRIBUTORS BE
>>>> BUSINESS
>>>> WHETHER IN
>>>> OTHERWISE)
>>>> OF THE
>>>> +#include <bsp.h>
>>>> +#include <rtems/score/cpu.h>
>>>> +BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
>>>> +  /* Do nothing */
>>>> +BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
>>>> +  AArch64_start_set_vector_base();
>>>> +  bsp_start_copy_sections();
>>>> +  raspberrypi_4_setup_mmu_and_cache();
>>>> +  bsp_start_clear_bss();
>>>> diff --git a/bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>>> b/bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>>> index 0000000000..ab12020a2a
>>>> --- /dev/null
>>>> +++ b/bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>>> @@ -0,0 +1,84 @@
>>>> + * @file
>>>> + * @brief This source file contains the default MMU tables and setup.
>>>> + * are met:
>>>> the
>>>> distribution.
>>>> "AS IS"
>>>> TO, THE
>>>> PURPOSE
>>>> CONTRIBUTORS BE
>>>> BUSINESS
>>>> WHETHER IN
>>>> OTHERWISE)
>>>> OF THE
>>>> +#include <bsp.h>
>>>> +#include <bsp/aarch64-mmu.h>
>>>> +#include <bsp/raspberrypi.h>
>>>> +#include <libcpu/mmu-vmsav8-64.h>
>>>> +BSP_START_DATA_SECTION static const aarch64_mmu_config_entry
>>>> +raspberrypi_4_mmu_config_table[] = {
>>>> +  AARCH64_MMU_DEFAULT_SECTIONS,
>>>> +  { /* RPI peripheral address */
>>>> +    .begin = (unsigned)RPI_PERIPHERAL_BASE,
>>>> +    .end = (unsigned)RPI_PERIPHERAL_BASE +
>>>> (unsigned)RPI_PERIPHERAL_SIZE,
>>>> +    .flags = AARCH64_MMU_DEVICE
>>>> +  { /* RPI ARM local registers */
>>>> +    .begin = (unsigned)BCM2711_LOCAL_REGS_BASE,
>>>> +    .end = (unsigned)BCM2711_LOCAL_REGS_BASE +
>>>> (unsigned)BCM2711_LOCAL_REGS_SIZE,
>>>> +  { /* RPI GIC Interface address */
>>>> +    .begin = 0xFF800000U,
>>>> +    .end = 0xFFA00000U,
>>>> + * Make weak and let the user override.
>>>> +raspberrypi_4_setup_mmu_and_cache( void ) __attribute__ ((weak));
>>>> +  aarch64_mmu_setup();
>>>> +  aarch64_mmu_setup_translation_table(
>>>> +    &raspberrypi_4_mmu_config_table[ 0 ],
>>>> +    RTEMS_ARRAY_SIZE( raspberrypi_4_mmu_config_table )
>>>> +  aarch64_mmu_enable();
>>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/abi.yml
>>>> b/spec/build/bsps/aarch64/raspberrypi/abi.yml
>>>> index 0000000000..5e3e0a4975
>>>> --- /dev/null
>>>> +++ b/spec/build/bsps/aarch64/raspberrypi/abi.yml
>>>> @@ -0,0 +1,21 @@
>>>> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>>>> +actions:
>>>> +- get-string: null
>>>> +- split: null
>>>> +- env-append: null
>>>> +build-type: option
>>>> +copyrights:
>>>> +- Copyright (C) 2022 Mohd Noor Aman
>>>> +default:
>>>> +- -mcpu=cortex-a72
>>>> +- -march=armv8-a
>>>> +default-by-variant: []
>>>> +includes: []
>>>> +description: |
>>>> +  ABI flags
>>>> +links: []
>>>> +enabled-by: true
>>>> +name: ABI_FLAGS
>>>> +type: build
>>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>>> b/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>>> index 0000000000..d2ff76d351
>>>> --- /dev/null
>>>> +++ b/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>>> @@ -0,0 +1,81 @@
>>>> +arch: aarch64
>>>> +bsp: raspberrypi4b
>>>> +build-type: bsp
>>>> +cflags: []
>>>> +copyrights:
>>>> +cppflags: []
>>>> +enabled-by: true
>>>> +family: raspberrypi
>>>> +includes: []
>>>> +install:
>>>> +- destination: ${BSP_INCLUDEDIR}
>>>> +  source:
>>>> +  - bsps/aarch64/raspberrypi/include/bsp.h
>>>> +  - bsps/aarch64/raspberrypi/include/tm27.h
>>>> +- destination: ${BSP_INCLUDEDIR}/bsp
>>>> +  source:
>>>> +  - bsps/aarch64/raspberrypi/include/bsp/irq.h
>>>> +  - bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>> +source:
>>>> +- bsps/aarch64/raspberrypi/console/console.c
>>>> +- bsps/aarch64/raspberrypi/start/bspstart.c
>>>> +- bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>>> +- bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>>> +- bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
>>>> +- bsps/aarch64/shared/cache/cache.c
>>>> +- bsps/aarch64/shared/mmu/vmsav8-64.c
>>>> +- bsps/shared/dev/clock/arm-generic-timer.c
>>>> +- bsps/shared/dev/irq/arm-gicv2.c
>>>> +- bsps/shared/dev/irq/arm-gicv2-get-attributes.c
>>>> +- bsps/shared/dev/serial/console-termios-init.c
>>>> +- bsps/shared/dev/serial/console-termios.c
>>>> +- bsps/shared/dev/serial/arm-pl011.c
>>>> +- bsps/shared/dev/getentropy/getentropy-cpucounter.c
>>>> +- bsps/shared/dev/btimer/btimer-cpucounter.c
>>>> +- bsps/shared/irq/irq-default-handler.c
>>>> +- bsps/shared/irq/irq-handler-install.c
>>>> +- bsps/shared/irq/irq-generic.c
>>>> +- bsps/shared/irq/irq-lock.c
>>>> +- bsps/shared/start/bspfatal-default.c
>>>> +- bsps/shared/start/bspreset-arm-psci.c
>>>> +- bsps/shared/start/gettargethash-default.c
>>>> +- bsps/shared/start/sbrk.c
>>>> +- bsps/shared/start/wkspaceinitone.c
>>>> +- bsps/shared/start/mallocinitmulti.c
>>>> +- bsps/shared/start/bspgetworkarea-default.c
>>>> +links:
>>>> +- role: build-dependency
>>>> +  uid: ../grp
>>>> +  uid: ../start
>>>> +  uid: ../optmmupages
>>>> +  uid: ../optgtusevirt
>>>> +  uid: ../optgtuseps
>>>> +  uid: abi
>>>> +  uid: ../../optcachedata
>>>> +  uid: ../../optcacheinst
>>>> +  uid: ../../opto2
>>>> +  uid: ../../bspopts
>>>> +  uid: linkercmds
>>>> +  uid: ../../obj
>>>> +  uid: ../../objirq
>>>> +type: build
>>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>>> b/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>>> index 0000000000..8598b89cba
>>>> --- /dev/null
>>>> +++ b/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>>> @@ -0,0 +1,76 @@
>>>> +build-type: config-file
>>>> +content: |
>>>> +  /* SPDX-License-Identifier: BSD-2-Clause */
>>>> +   * are met:
>>>> copyright
>>>> in the
>>>> distribution.
>>>> CONTRIBUTORS "AS IS"
>>>> TO, THE
>>>> PARTICULAR PURPOSE
>>>> CONTRIBUTORS BE
>>>> OR
>>>> OF
>>>> BUSINESS
>>>> WHETHER IN
>>>> OTHERWISE)
>>>> ADVISED OF THE
>>>> +  MEMORY {
>>>> +  RAM_MMU  : ORIGIN = 0x0, LENGTH = (0x1000 *
>>>> ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
>>>> +  RAM      : ORIGIN = 0x80000, LENGTH = 1024M
>>>> +  REGION_ALIAS ("REGION_START",          RAM);
>>>> +  REGION_ALIAS ("REGION_VECTOR",         RAM);
>>>> +  REGION_ALIAS ("REGION_TEXT",           RAM);
>>>> +  REGION_ALIAS ("REGION_TEXT_LOAD",      RAM);
>>>> +  REGION_ALIAS ("REGION_RODATA",         RAM);
>>>> +  REGION_ALIAS ("REGION_RODATA_LOAD",    RAM);
>>>> +  REGION_ALIAS ("REGION_DATA",           RAM);
>>>> +  REGION_ALIAS ("REGION_DATA_LOAD",      RAM);
>>>> +  REGION_ALIAS ("REGION_FAST_TEXT",      RAM);
>>>> +  REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
>>>> +  REGION_ALIAS ("REGION_FAST_DATA",      RAM);
>>>> +  REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
>>>> +  REGION_ALIAS ("REGION_BSS",            RAM);
>>>> +  REGION_ALIAS ("REGION_WORK",           RAM);
>>>> +  REGION_ALIAS ("REGION_STACK",          RAM);
>>>> +  REGION_ALIAS ("REGION_NOCACHE",        RAM);
>>>> +  REGION_ALIAS ("REGION_NOCACHE_LOAD",   RAM);
>>>> +  bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ?
>>>> bsp_stack_abt_size : 1024;
>>>> +  bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align)
>>>> ? bsp_section_rwbarrier_align : 1M;
>>>> +  bsp_stack_exception_size = DEFINED (bsp_stack_exception_size) ?
>>>> bsp_stack_exception_size : 1024;
>>>> +  bsp_vector_table_in_start_section = 1;
>>>> +  bsp_translation_table_base = ORIGIN (RAM_MMU);
>>>> +  bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
>>>> +  OUTPUT_FORMAT ("elf64-littleaarch64")
>>>> +  OUTPUT_ARCH (aarch64)
>>>> +  INCLUDE linkcmds.base
>>>> +copyrights:
>>>> +enabled-by: true
>>>> +install-path: ${BSP_LIBDIR}
>>>> +links: []
>>>> +target: linkcmds
>>>> +type: build
>>>> 2.37.3
>>>> _______________________________________________
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221004/a1893e4d/attachment-0001.htm>
