[PATCH v3] bsp/aarch64: Add new Raspberry Pi 4B BSP
Joel Sherrill
joel at rtems.org
Tue Oct 4 22:03:18 UTC 2022
On Tue, Oct 4, 2022 at 4:38 PM Alan Cudmore <alan.cudmore at gmail.com> wrote:
> It builds without error and boots for me!
> I ran my RTEMS Kernel Image and tried out some task demos, whetstone,
> dhrystone, created a RAM disk, etc.
> Next will be a core Flight System (cFS) run.
> This is going to be a very useful board to have RTEMS + SMP + Libbsd on,
> especially when people can buy them again.
> Thanks!
> Alan
> RTEMS Kernel Image Booting
> *** RTEMS Info ***
> 6.0.0.cc43dc3e22b21ddf902b7748fb27f16c9aee3719
> BSP Ticks Per Second = 100
> *** End RTEMS info ***
> Populating Root file system from TAR file.
> Setting up filesystems.
> Initializing Local Commands.
> Adding Target specific commands
> Running /shell-init.
> 1: mkdir ram
> 2: mkrfs /dev/rda
> 3: mount -t rfs /dev/rda /ram
> mounted /dev/rda -> /ram
> 4: hello
> ____ ______________ ________
> / __ \/_ __/ ____/ \/ / ___/
> / /_/ / / / / __/ / /\_/ /\__ \
> / _, _/ / / / /___/ / / /___/ /
> /_/ \_| /_/ /_____/_/ /_//____/
> Hello RTEMS!
> Create your own command here!
> Starting shell....
> RTEMS Shell on /dev/console. Use 'help' to list commands.
> shell0 [/] #
Wow! I'm always impressed by how many RTEMS capabilities are
available in a basic BSP.
All it needs now is a network driver. <hint> :)
I'll merge this .
--joel
> On Tue, Oct 4, 2022 at 2:40 PM Joel Sherrill <joel at rtems.org> wrote:
>> Once Alan says it's OK, I will merge this.
>> Great work! Please make sure code, docs, tester configuration, etc gets
>> merged.
>> On Tue, Oct 4, 2022 at 1:18 PM Kinsey Moore <kinsey.moore at oarcorp.com>
>> wrote:
>>> I think all of the issues with this patch have been addressed; this
>>> looks good to me.
>>> Great work, Noor!
>>> Kinsey
>>> On Tue, Oct 4, 2022 at 11:12 AM Noor Aman <nooraman5718 at gmail.com>
>>> wrote:
>>>> hey all,
>>>> I've fixed the warning and edited the commit message to be more
>>>> specific and to be in 80 words char limit.
>>>> Thanks,
>>>> Noor
>>>> On Tue, 4 Oct 2022 at 16:08, Mohd Noor Aman <nooraman5718 at gmail.com>
>>>> wrote:
>>>>> This patch adds new Raspberry pi 4B AArch64 BSP to the RTEMS Family.
>>>>> Currently
>>>>> only LP64 ABI is supported. ILP32 is not supported. RAM starts from
>>>>> 0x80000 in
>>>>> 64Bit kernel mode and MMU from 0x0. All Raspberrypi Pi 4B models and
>>>>> Raspberry
>>>>> Pi 400 are supported. All the IRQs are similiar to the older Raspberry
>>>>> pi 2 ARM
>>>>> BSP.
>>>>> Raspberry Pi 4B has 2 types of UARTs. Only PL011 serial is supported
>>>>> currently.
>>>>> Mini-UART is not supported. Mini-UART is default UART on the board so
>>>>> it needs
>>>>> to be disabled by adding "dtoverlay=disable-bt" to the config.txt. No
>>>>> support
>>>>> for additional 4 PL011-UARTs on the board.
>>>>> The raspberrypi.h includes many of the address required for the future
>>>>> development of the RPi 4B BSP. This includes peripherals, ARM Timer,
>>>>> VideoCore
>>>>> Timer, Watchdog, Mailbox, AUX, FIQs and IRQs.
>>>>> bsps/aarch64/raspberrypi/console/console.c | 69 +++
>>>>> bsps/aarch64/raspberrypi/include/bsp.h | 76 +++
>>>>> bsps/aarch64/raspberrypi/include/bsp/irq.h | 109 ++++
>>>>> .../raspberrypi/include/bsp/raspberrypi.h | 471 ++++++++++++++++++
>>>>> bsps/aarch64/raspberrypi/include/tm27.h | 46 ++
>>>>> bsps/aarch64/raspberrypi/start/bspstart.c | 49 ++
>>>>> .../aarch64/raspberrypi/start/bspstarthooks.c | 53 ++
>>>>> bsps/aarch64/raspberrypi/start/bspstartmmu.c | 84 ++++
>>>>> spec/build/bsps/aarch64/raspberrypi/abi.yml | 21 +
>>>>> .../aarch64/raspberrypi/bspraspberrypi4.yml | 81 +++
>>>>> .../bsps/aarch64/raspberrypi/linkercmds.yml | 76 +++
>>>>> 11 files changed, 1135 insertions(+)
>>>>> create mode 100644 bsps/aarch64/raspberrypi/console/console.c
>>>>> create mode 100644 bsps/aarch64/raspberrypi/include/bsp.h
>>>>> create mode 100644 bsps/aarch64/raspberrypi/include/bsp/irq.h
>>>>> create mode 100644 bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>>> create mode 100644 bsps/aarch64/raspberrypi/include/tm27.h
>>>>> create mode 100644 bsps/aarch64/raspberrypi/start/bspstart.c
>>>>> create mode 100644 bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>>>> create mode 100644 bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>>>> create mode 100644 spec/build/bsps/aarch64/raspberrypi/abi.yml
>>>>> create mode 100644
>>>>> spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>>>> create mode 100644 spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>>>> diff --git a/bsps/aarch64/raspberrypi/console/console.c
>>>>> b/bsps/aarch64/raspberrypi/console/console.c
>>>>> new file mode 100644
>>>>> index 0000000000..73bb0036ff
>>>>> --- /dev/null
>>>>> +++ b/bsps/aarch64/raspberrypi/console/console.c
>>>>> @@ -0,0 +1,69 @@
>>>>> +/* SPDX-License-Identifier: BSD-2-Clause */
>>>>> + * @file
>>>>> + * @ingroup RTEMSBSPsAArch64Raspberrypi4
>>>>> + * @brief Console Configuration
>>>>> + * Copyright (C) 2022 Mohd Noor Aman
>>>>> + * Redistribution and use in source and binary forms, with or without
>>>>> + * modification, are permitted provided that the following conditions
>>>>> + * are met:
>>>>> + * 1. Redistributions of source code must retain the above copyright
>>>>> + * notice, this list of conditions and the following disclaimer.
>>>>> + * 2. Redistributions in binary form must reproduce the above
>>>>> copyright
>>>>> + * notice, this list of conditions and the following disclaimer in
>>>>> the
>>>>> + * documentation and/or other materials provided with the
>>>>> distribution.
>>>>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>> CONTRIBUTORS "AS IS"
>>>>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>>>> TO, THE
>>>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>>>> PURPOSE
>>>>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>>>>> CONTRIBUTORS BE
>>>>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>>>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
>>>>> OF
>>>>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>>> BUSINESS
>>>>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>>> WHETHER IN
>>>>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>> OTHERWISE)
>>>>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>>>> ADVISED OF THE
>>>>> + * POSSIBILITY OF SUCH DAMAGE.
>>>>> +#include <rtems/bspIo.h>
>>>>> +#include <bsp.h>
>>>>> +#include <dev/serial/arm-pl011.h>
>>>>> +#include <bsp/console-termios.h>
>>>>> +#include <bspopts.h>
>>>>> +arm_pl011_context raspberrypi_4_context = {
>>>>> + .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
>>>>> + .regs = (volatile pl011 *) BSP_RPI4_PL011_BASE,
>>>>> + .initial_baud = 115200
>>>>> +const console_device console_device_table[] = {
>>>>> + .device_file = "/dev/ttyS0",
>>>>> + .probe = console_device_probe_default,
>>>>> + .handler = &arm_pl011_fns,
>>>>> + .context = &raspberrypi_4_context.base
>>>>> +const size_t console_device_count =
>>>>> RTEMS_ARRAY_SIZE(console_device_table);
>>>>> +static void output_char( char c )
>>>>> + arm_pl011_write_polled(&raspberrypi_4_context.base, c);
>>>>> +BSP_output_char_function_type BSP_output_char = output_char;
>>>>> +BSP_polling_getchar_function_type BSP_poll_char = NULL;
>>>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp.h
>>>>> b/bsps/aarch64/raspberrypi/include/bsp.h
>>>>> index 0000000000..4fa81edd40
>>>>> --- /dev/null
>>>>> +++ b/bsps/aarch64/raspberrypi/include/bsp.h
>>>>> @@ -0,0 +1,76 @@
>>>>> + * @file
>>>>> + * @brief Core BSP definitions
>>>>> + * are met:
>>>>> copyright
>>>>> the
>>>>> distribution.
>>>>> TO, THE
>>>>> PURPOSE
>>>>> CONTRIBUTORS BE
>>>>> OF
>>>>> BUSINESS
>>>>> WHETHER IN
>>>>> OTHERWISE)
>>>>> ADVISED OF THE
>>>>> +#ifndef LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H
>>>>> +#define LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H
>>>>> + * @addtogroup RTEMSBSPsAArch64
>>>>> +#ifndef ASM
>>>>> +#include <bsp/default-initial-extension.h>
>>>>> +#include <bsp/start.h>
>>>>> +#include <rtems.h>
>>>>> +/*Raspberry pi MMU initialization */
>>>>> +BSP_START_TEXT_SECTION void raspberrypi_4_setup_mmu_and_cache(void);
>>>>> +#ifdef __cplusplus
>>>>> +extern "C" {
>>>>> +#endif /* __cplusplus */
>>>>> +#define BSP_ARM_GIC_CPUIF_BASE 0xFF842000
>>>>> +#define BSP_ARM_GIC_DIST_BASE 0xFF841000
>>>>> +#define BSP_RPI4_PL011_BASE 0xFE201000
>>>>> +#define BSP_RPI4_PL011_LENGTH 0x200
>>>>> +#ifdef __cplusplus
>>>>> +#endif /* ASM */
>>>>> +#endif /* LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H */
>>>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp/irq.h
>>>>> b/bsps/aarch64/raspberrypi/include/bsp/irq.h
>>>>> index 0000000000..effec1b040
>>>>> --- /dev/null
>>>>> +++ b/bsps/aarch64/raspberrypi/include/bsp/irq.h
>>>>> @@ -0,0 +1,109 @@
>>>>> + * @file
>>>>> + * @ingroup raspberrypi_interrupt
>>>>> + * @brief Interrupt definitions.
>>>>> + * Copyright (c) 2013 Alan Cudmore
>>>>> + * Copyright (c) 2022 Mohd Noor Aman
>>>>> + * The license and distribution terms for this file may be
>>>>> + * found in the file LICENSE in this distribution or at
>>>>> + * http://www.rtems.org/license/LICENSE
>>>>> +#ifndef LIBBSP_ARM_RASPBERRYPI_IRQ_H
>>>>> +#define LIBBSP_ARM_RASPBERRYPI_IRQ_H
>>>>> +#ifndef ASM
>>>>> +#include <rtems.h>
>>>>> +#include <rtems/irq.h>
>>>>> +#include <rtems/irq-extension.h>
>>>>> +#include <dev/irq/arm-gic-irq.h>
>>>>> +#if defined(RTEMS_SMP)
>>>>> +#include <rtems/score/processormask.h>
>>>>> +#endif
>>>>> + * @defgroup raspberrypi_interrupt Interrrupt Support
>>>>> + * @ingroup RTEMSBSPsARMRaspberryPi
>>>>> + * @brief Interrupt support.
>>>>> +#define BCM2835_INTC_TOTAL_IRQ (64 + 8)
>>>>> +#define BCM2835_IRQ_SET1_MIN 0
>>>>> +#define BCM2835_IRQ_SET2_MIN 32
>>>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M0 0
>>>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M1 1
>>>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M2 2
>>>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M3 3
>>>>> +#define BCM2835_IRQ_ID_USB 9
>>>>> +#define BCM2835_IRQ_ID_AUX 29
>>>>> +#define BCM2835_IRQ_ID_SPI_SLAVE 43
>>>>> +#define BCM2835_IRQ_ID_PWA0 45
>>>>> +#define BCM2835_IRQ_ID_PWA1 46
>>>>> +#define BCM2835_IRQ_ID_SMI 48
>>>>> +#define BCM2835_IRQ_ID_GPIO_0 49
>>>>> +#define BCM2835_IRQ_ID_GPIO_1 50
>>>>> +#define BCM2835_IRQ_ID_GPIO_2 51
>>>>> +#define BCM2835_IRQ_ID_GPIO_3 52
>>>>> +#define BCM2835_IRQ_ID_I2C 53
>>>>> +#define BCM2835_IRQ_ID_SPI 54
>>>>> +#define BCM2835_IRQ_ID_PCM 55
>>>>> +#define BCM2835_IRQ_ID_UART 57
>>>>> +#define BCM2835_IRQ_ID_SD 62
>>>>> +#define BCM2835_IRQ_ID_BASIC_BASE_ID 64
>>>>> +#define BCM2835_IRQ_ID_TIMER_0 64
>>>>> +#define BCM2835_IRQ_ID_MAILBOX_0 65
>>>>> +#define BCM2835_IRQ_ID_DOORBELL_0 66
>>>>> +#define BCM2835_IRQ_ID_DOORBELL_1 67
>>>>> +#define BCM2835_IRQ_ID_GPU0_HALTED 68
>>>>> +#define BCM2835_IRQ_ID_GPU1_HALTED 69
>>>>> +#define BCM2835_IRQ_ID_ILL_ACCESS_1 70
>>>>> +#define BCM2835_IRQ_ID_ILL_ACCESS_0 71
>>>>> +#define BSP_TIMER_VIRT_PPI 27
>>>>> +#define BSP_TIMER_PHYS_NS_PPI 30
>>>>> +#define BSP_VPL011_SPI 32
>>>>> +#define BSP_INTERRUPT_VECTOR_COUNT BCM2835_INTC_TOTAL_IRQ
>>>>> +#define BSP_INTERRUPT_VECTOR_INVALID (UINT32_MAX)
>>>>> +#define BSP_IRQ_COUNT (BCM2835_INTC_TOTAL_IRQ)
>>>>> +static inline rtems_status_code bsp_interrupt_set_affinity(
>>>>> + rtems_vector_number vector,
>>>>> + const Processor_mask *affinity
>>>>> + (void) vector;
>>>>> + (void) affinity;
>>>>> + return RTEMS_UNSATISFIED;
>>>>> +static inline rtems_status_code bsp_interrupt_get_affinity(
>>>>> + Processor_mask *affinity
>>>>> + (void) vector;
>>>>> + _Processor_mask_From_index( affinity, 0 );
>>>>> +#endif
>>>>> +#endif /* ASM */
>>>>> +#endif /* LIBBSP_ARM_RASPBERRYPI_IRQ_H */
>>>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>>> b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>>> index 0000000000..f148e8df6c
>>>>> --- /dev/null
>>>>> +++ b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>>> @@ -0,0 +1,471 @@
>>>>> + * @file
>>>>> + * @ingroup raspberrypi_4_regs
>>>>> + * @brief Register definitions.
>>>>> +#ifndef LIBBSP_AARCH64_RASPBERRYPI_RASPBERRYPI_4_H
>>>>> +#define LIBBSP_AARCH64_RASPBERRYPI_RASPBERRYPI_4_H
>>>>> +#include <stdint.h>
>>>>> +#include <bsp/utility.h>
>>>>> + * @defgroup raspberrypi_reg Register Definitions
>>>>> + * @brief Register Definitions
>>>>> + * @name Register Macros
>>>>> +#define BCM2711_REG(x) (*(volatile uint64_t *)(x))
>>>>> +#define BCM2711_BIT(n) (1 << (n))
>>>>> + * @name Peripheral Base Register Address
>>>>> +#define RPI_PERIPHERAL_BASE 0xFE000000
>>>>> +#define BASE_OFFSET 0xFE000000
>>>>> +#define RPI_PERIPHERAL_SIZE 0x01800000
>>>>> + * @name Bus to Physical address translation
>>>>> + * Macro.
>>>>> +#define BUS_TO_PHY(x) ((x) - BASE_OFFSET)
>>>>> + * @name Internal ARM Timer Registers
>>>>> +#define BCM2711_CLOCK_FREQ 250000000
>>>>> +#define BCM2711_TIMER_BASE (RPI_PERIPHERAL_BASE + 0xB400)
>>>>> +#define BCM2711_TIMER_LOD (BCM2711_TIMER_BASE + 0x00)
>>>>> +#define BCM2711_TIMER_VAL (BCM2711_TIMER_BASE + 0x04)
>>>>> +#define BCM2711_TIMER_CTL (BCM2711_TIMER_BASE + 0x08)
>>>>> +#define BCM2711_TIMER_CLI (BCM2711_TIMER_BASE + 0x0C)
>>>>> +#define BCM2711_TIMER_RIS (BCM2711_TIMER_BASE + 0x10)
>>>>> +#define BCM2711_TIMER_MIS (BCM2711_TIMER_BASE + 0x14)
>>>>> +#define BCM2711_TIMER_RLD (BCM2711_TIMER_BASE + 0x18)
>>>>> +#define BCM2711_TIMER_DIV (BCM2711_TIMER_BASE + 0x1C)
>>>>> +#define BCM2711_TIMER_CNT (BCM2711_TIMER_BASE + 0x20)
>>>>> +#define BCM2711_TIMER_PRESCALE 0xF9
>>>>> + * @name Power Management and Watchdog Registers
>>>>> +#define BCM2711_PM_PASSWD_MAGIC 0x5a000000
>>>>> +#define BCM2711_PM_BASE (RPI_PERIPHERAL_BASE + 0x100000)
>>>>> +#define BCM2711_PM_GNRIC (BCM2711_PM_BASE + 0x00)
>>>>> +#define BCM2711_PM_GNRIC_POWUP 0x00000001
>>>>> +#define BCM2711_PM_GNRIC_POWOK 0x00000002
>>>>> +#define BCM2711_PM_GNRIC_ISPOW 0x00000004
>>>>> +#define BCM2711_PM_GNRIC_MEMREP 0x00000008
>>>>> +#define BCM2711_PM_GNRIC_MRDONE 0x00000010
>>>>> +#define BCM2711_PM_GNRIC_ISFUNC 0x00000020
>>>>> +#define BCM2711_PM_GNRIC_RSTN 0x00000fc0
>>>>> +#define BCM2711_PM_GNRIC_ENAB 0x00001000
>>>>> +#define BCM2711_PM_GNRIC_CFG 0x007f0000
>>>>> +#define BCM2711_PM_AUDIO (BCM2711_PM_BASE + 0x04)
>>>>> +#define BCM2711_PM_AUDIO_APSM 0x000fffff
>>>>> +#define BCM2711_PM_AUDIO_CTRLEN 0x00100000
>>>>> +#define BCM2711_PM_AUDIO_RSTN 0x00200000
>>>>> +#define BCM2711_PM_STATUS (BCM2711_PM_BASE + 0x18)
>>>>> +#define BCM2711_PM_RSTC (BCM2711_PM_BASE + 0x1c)
>>>>> +#define BCM2711_PM_RSTC_DRCFG 0x00000003
>>>>> +#define BCM2711_PM_RSTC_WRCFG 0x00000030
>>>>> +#define BCM2711_PM_RSTC_WRCFG_FULL 0x00000020
>>>>> +#define BCM2711_PM_RSTC_SRCFG 0x00000300
>>>>> +#define BCM2711_PM_RSTC_QRCFG 0x00003000
>>>>> +#define BCM2711_PM_RSTC_FRCFG 0x00030000
>>>>> +#define BCM2711_PM_RSTC_HRCFG 0x00300000
>>>>> +#define BCM2711_PM_RSTS (BCM2711_PM_BASE + 0x20)
>>>>> +#define BCM2711_PM_RSTS_HADDRQ 0x00000001
>>>>> +#define BCM2711_PM_RSTS_HADDRF 0x00000002
>>>>> +#define BCM2711_PM_RSTS_HADDRH 0x00000004
>>>>> +#define BCM2711_PM_RSTS_HADWRQ 0x00000010
>>>>> +#define BCM2711_PM_RSTS_HADWRF 0x0000002
>>>>> +#define BCM2711_PM_RSTS_HADWRH 0x00000040
>>>>> +#define BCM2711_PM_RSTS_HADSRQ 0x00000100
>>>>> +#define BCM2711_PM_RSTS_HADSRF 0x00000200
>>>>> +#define BCM2711_PM_RSTS_HADSRH 0x00000400
>>>>> +#define BCM2711_PM_RSTS_HADPOR 0x00001000
>>>>> +#define BCM2711_PM_WDOG (BCM2711_PM_BASE + 0x24)
>>>>> + * @name AUX Registers
>>>>> +#define BCM2711_AUX_BASE (RPI_PERIPHERAL_BASE + 0x215000)
>>>>> +#define AUX_ENABLES (BCM2711_AUX_BASE + 0x04)
>>>>> +#define AUX_MU_IO_REG (BCM2711_AUX_BASE + 0x40)
>>>>> +#define AUX_MU_IER_REG (BCM2711_AUX_BASE + 0x44)
>>>>> +#define AUX_MU_IIR_REG (BCM2711_AUX_BASE + 0x48)
>>>>> +#define AUX_MU_LCR_REG (BCM2711_AUX_BASE + 0x4C)
>>>>> +#define AUX_MU_MCR_REG (BCM2711_AUX_BASE + 0x50)
>>>>> +#define AUX_MU_LSR_REG (BCM2711_AUX_BASE + 0x54)
>>>>> +#define AUX_MU_MSR_REG (BCM2711_AUX_BASE + 0x58)
>>>>> +#define AUX_MU_SCRATCH (BCM2711_AUX_BASE + 0x5C)
>>>>> +#define AUX_MU_CNTL_REG (BCM2711_AUX_BASE + 0x60)
>>>>> +#define AUX_MU_STAT_REG (BCM2711_AUX_BASE + 0x64)
>>>>> +#define AUX_MU_BAUD_REG (BCM2711_AUX_BASE + 0x68)
>>>>> + * @name GPU Timer Registers
>>>>> + * NOTE: The GPU uses Compare registers 0 and 2 for
>>>>> + * it's own RTOS. 1 and 3 are available for use in
>>>>> + * RTEMS.
>>>>> +#define BCM2711_GPU_TIMER_BASE (RPI_PERIPHERAL_BASE + 0x3000)
>>>>> +#define BCM2711_GPU_TIMER_CS (BCM2711_GPU_TIMER_BASE + 0x00)
>>>>> +#define BCM2711_GPU_TIMER_CS_M0 0x00000001
>>>>> +#define BCM2711_GPU_TIMER_CS_M1 0x00000002
>>>>> +#define BCM2711_GPU_TIMER_CS_M2 0x00000004
>>>>> +#define BCM2711_GPU_TIMER_CS_M3 0x00000008
>>>>> +#define BCM2711_GPU_TIMER_CLO (BCM2711_GPU_TIMER_BASE + 0x04)
>>>>> +#define BCM2711_GPU_TIMER_CHI (BCM2711_GPU_TIMER_BASE + 0x08)
>>>>> +#define BCM2711_GPU_TIMER_C0 (BCM2711_GPU_TIMER_BASE + 0x0C)
>>>>> +#define BCM2711_GPU_TIMER_C1 (BCM2711_GPU_TIMER_BASE + 0x10)
>>>>> +#define BCM2711_GPU_TIMER_C2 (BCM2711_GPU_TIMER_BASE + 0x14)
>>>>> +#define BCM2711_GPU_TIMER_C3 (BCM2711_GPU_TIMER_BASE + 0x18)
>>>>> + * @name EMMC Registers
>>>>> + * NOTE: Since the SD controller follows the SDHCI standard,
>>>>> + * the rtems-libbsd tree already provides the remaining
>>>>> registers.
>>>>> +#define BCM2711_EMMC_BASE (RPI_PERIPHERAL_BASE + 0x300000)
>>>>> +* @name Mailbox Registers
>>>>> +#define BCM2711_MBOX_BASE (RPI_PERIPHERAL_BASE+0xB880)
>>>>> +#define BCM2711_MBOX_READ (BCM2711_MBOX_BASE+0x00)
>>>>> +#define BCM2711_MBOX_PEEK (BCM2711_MBOX_BASE+0x10)
>>>>> +#define BCM2711_MBOX_SENDER (BCM2711_MBOX_BASE+0x14)
>>>>> +#define BCM2711_MBOX_STATUS (BCM2711_MBOX_BASE+0x18)
>>>>> +#define BCM2711_MBOX_WRITE (BCM2711_MBOX_BASE+0x20)
>>>>> +#define BCM2711_MBOX_CONFIG (BCM2711_MBOX_BASE+0x1C)
>>>>> +#define BCM2711_MBOX_RESPONSE 0x80000000
>>>>> +#define BCM2711_MBOX_FULL 0x80000000
>>>>> +#define BCM2711_MBOX_EMPTY 0x40000000
>>>>> +* @name Mailbox Channels
>>>>> +/* Power Manager channel */
>>>>> +#define BCM2711_MBOX_CHANNEL_PM 0
>>>>> +/* Framebuffer channel */
>>>>> +#define BCM2711_MBOX_CHANNEL_FB 1
>>>>> + /* Virtual UART channel */
>>>>> +#define BCM2711_MBOX_CHANNEL_VUART 2
>>>>> + /* VCHIQ channel */
>>>>> +#define BCM2711_MBOX_CHANNEL_VCHIQ 3
>>>>> + /* LEDs channel */
>>>>> +#define BCM2711_MBOX_CHANNEL_LED 4
>>>>> + /* Button channel */
>>>>> +#define BCM2711_MBOX_CHANNEL_BUTTON 5
>>>>> + /* Touch screen channel */
>>>>> +#define BCM2711_MBOX_CHANNEL_TOUCHS 6
>>>>> +#define BCM2711_MBOX_CHANNEL_COUNT 7
>>>>> +/* Property tags (ARM <-> VC) channel */
>>>>> +#define BCM2711_MBOX_CHANNEL_PROP_AVC 8
>>>>> + /* Property tags (VC <-> ARM) channel */
>>>>> +#define BCM2711_MBOX_CHANNEL_PROP_VCA 9
>>>>> + * @name Raspberry Pi 2 Interrupt Register Defines
>>>>> +/* Timers interrupt control registers */
>>>>> +#define BCM2711_CORE0_TIMER_IRQ_CTRL_BASE 0xFF800040
>>>>> +#define BCM2711_CORE1_TIMER_IRQ_CTRL_BASE 0xFF800044
>>>>> +#define BCM2711_CORE2_TIMER_IRQ_CTRL_BASE 0xFF800048
>>>>> +#define BCM2711_CORE3_TIMER_IRQ_CTRL_BASE 0xFF80004C
>>>>> +#define BCM2711_CORE_TIMER_IRQ_CTRL(cpuidx) \
>>>>> + (BCM2711_CORE0_TIMER_IRQ_CTRL_BASE + 0x4 * (cpuidx))
>>>>> + * @name Raspberry Pi 4 ARM_LOCAL registers
>>>>> +#define BCM2711_LOCAL_REGS_BASE 0x4C0000000
>>>>> +#define BCM2711_LOCAL_REGS_SIZE 0x100
>>>>> +#define BCM2711_LOCAL_ARM_CONTROL
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x00)
>>>>> +#define BCM2711_LOCAL_CORE_IRQ_CONTROL
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x0c)
>>>>> +#define BCM2711_LOCAL_PMU_CONTROL_SET
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x10)
>>>>> +#define BCM2711_LOCAL_PMU_CONTROL_CLR
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x14)
>>>>> +#define BCM2711_LOCAL_PERI_IRQ_ROUTE0
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x24)
>>>>> +#define BCM2711_LOCAL_AXI_QUIET_TIME
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x30)
>>>>> +#define BCM2711_LOCAL_LOCAL_TIMER_CONTROL
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x34)
>>>>> +#define BCM2711_LOCAL_LOCAL_TIMER_IRQ
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x38)
>>>>> +#define BCM2711_LOCAL_TIMER_CNTRL0
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x40)
>>>>> +#define BCM2711_LOCAL_TIMER_CNTRL1
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x44)
>>>>> +#define BCM2711_LOCAL_TIMER_CNTRL2
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x48)
>>>>> +#define BCM2711_LOCAL_TIMER_CNTRL3
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x4c)
>>>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL0
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x50)
>>>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL1
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x54)
>>>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL2
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x58)
>>>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL3
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x5c)
>>>>> +#define BCM2711_LOCAL_IRQ_SOURCE0
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x60)
>>>>> +#define BCM2711_LOCAL_IRQ_SOURCE1
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x64)
>>>>> +#define BCM2711_LOCAL_IRQ_SOURCE2
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x68)
>>>>> +#define BCM2711_LOCAL_IRQ_SOURCE3
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x6c)
>>>>> +#define BCM2711_LOCAL_FIQ_SOURCE0
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x70)
>>>>> +#define BCM2711_LOCAL_FIQ_SOURCE1
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x74)
>>>>> +#define BCM2711_LOCAL_FIQ_SOURCE2
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x78)
>>>>> +#define BCM2711_LOCAL_FIQ_SOURCE3
>>>>> (BCM2711_LOCAL_REGS_BASE + 0x7c)
>>>>> + * @name Raspberry Pi 4 Mailbox registers
>>>>> +#define BCM2711_MAILBOX_00_WRITE_SET_BASE 0x4C000080
>>>>> +#define BCM2711_MAILBOX_01_WRITE_SET_BASE 0x4C000084
>>>>> +#define BCM2711_MAILBOX_02_WRITE_SET_BASE 0x4C000088
>>>>> +#define BCM2711_MAILBOX_03_WRITE_SET_BASE 0x4C00008C
>>>>> +#define BCM2711_MAILBOX_04_WRITE_SET_BASE 0x4C000090
>>>>> +#define BCM2711_MAILBOX_05_WRITE_SET_BASE 0x4C000094
>>>>> +#define BCM2711_MAILBOX_06_WRITE_SET_BASE 0x4C000098
>>>>> +#define BCM2711_MAILBOX_07_WRITE_SET_BASE 0x4C00009C
>>>>> +#define BCM2711_MAILBOX_08_WRITE_SET_BASE 0x4C0000A0
>>>>> +#define BCM2711_MAILBOX_09_WRITE_SET_BASE 0x4C0000A4
>>>>> +#define BCM2711_MAILBOX_10_WRITE_SET_BASE 0x4C0000A8
>>>>> +#define BCM2711_MAILBOX_11_WRITE_SET_BASE 0x4C0000AC
>>>>> +#define BCM2711_MAILBOX_12_WRITE_SET_BASE 0x4C0000B0
>>>>> +#define BCM2711_MAILBOX_13_WRITE_SET_BASE 0x4C0000B4
>>>>> +#define BCM2711_MAILBOX_14_WRITE_SET_BASE 0x4C0000B8
>>>>> +#define BCM2711_MAILBOX_15_WRITE_SET_BASE 0x4C0000BC
>>>>> +#define BCM2711_MAILBOX_00_READ_CLEAR_BASE 0x4C0000C0
>>>>> +#define BCM2711_MAILBOX_01_READ_CLEAR_BASE 0x4C0000C4
>>>>> +#define BCM2711_MAILBOX_02_READ_CLEAR_BASE 0x4C0000C8
>>>>> +#define BCM2711_MAILBOX_03_READ_CLEAR_BASE 0x4C0000CC
>>>>> +#define BCM2711_MAILBOX_04_READ_CLEAR_BASE 0x4C0000D0
>>>>> +#define BCM2711_MAILBOX_05_READ_CLEAR_BASE 0x4C0000D4
>>>>> +#define BCM2711_MAILBOX_06_READ_CLEAR_BASE 0x4C0000D8
>>>>> +#define BCM2711_MAILBOX_07_READ_CLEAR_BASE 0x4C0000DC
>>>>> +#define BCM2711_MAILBOX_08_READ_CLEAR_BASE 0x4C0000E0
>>>>> +#define BCM2711_MAILBOX_09_READ_CLEAR_BASE 0x4C0000E4
>>>>> +#define BCM2711_MAILBOX_10_READ_CLEAR_BASE 0x4C0000E8
>>>>> +#define BCM2711_MAILBOX_11_READ_CLEAR_BASE 0x4C0000EC
>>>>> +#define BCM2711_MAILBOX_12_READ_CLEAR_BASE 0x4C0000F0
>>>>> +#define BCM2711_MAILBOX_13_READ_CLEAR_BASE 0x4C0000F4
>>>>> +#define BCM2711_MAILBOX_14_READ_CLEAR_BASE 0x4C0000F8
>>>>> +#define BCM2711_MAILBOX_15_READ_CLEAR_BASE 0x4C0000FC
>>>>> + * @name Raspberry Pi 4 ARM_C FIQ and IRQ registers
>>>>> +#define BCM2711_ARMC_REGS_BASE (RPI_PERIPHERAL_BASE +
>>>>> 0xB200)
>>>>> +#define BCM2711_ARMC_REGS_SIZE 0x200
>>>>> +#define BCM2711_ARMC_IRQ0_PENDING0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x00)
>>>>> +#define BCM2711_ARMC_IRQ0_PENDING1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x04)
>>>>> +#define BCM2711_ARMC_IRQ0_PENDING2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x08)
>>>>> +#define BCM2711_ARMC_IRQ0_SET_EN_0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x10)
>>>>> +#define BCM2711_ARMC_IRQ0_SET_EN_1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x14)
>>>>> +#define BCM2711_ARMC_IRQ0_SET_EN_2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x18)
>>>>> +#define BCM2711_ARMC_IRQ0_CLR_EN_0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x20)
>>>>> +#define BCM2711_ARMC_IRQ0_CLR_EN_1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x24)
>>>>> +#define BCM2711_ARMC_IRQ0_CLR_EN_2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x28)
>>>>> +#define BCM2711_ARMC_IRQ_STATUS0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x30)
>>>>> +#define BCM2711_ARMC_IRQ_STATUS1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x34)
>>>>> +#define BCM2711_ARMC_IRQ_STATUS2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x38)
>>>>> +#define BCM2711_ARMC_IRQ1_PENDING0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x40)
>>>>> +#define BCM2711_ARMC_IRQ1_PENDING1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x44)
>>>>> +#define BCM2711_ARMC_IRQ1_PENDING2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x48)
>>>>> +#define BCM2711_ARMC_IRQ1_SET_EN_0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x50)
>>>>> +#define BCM2711_ARMC_IRQ1_SET_EN_1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x54)
>>>>> +#define BCM2711_ARMC_IRQ1_SET_EN_2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x58)
>>>>> +#define BCM2711_ARMC_IRQ1_CLR_EN_0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x60)
>>>>> +#define BCM2711_ARMC_IRQ1_CLR_EN_1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x64)
>>>>> +#define BCM2711_ARMC_IRQ1_CLR_EN_2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x68)
>>>>> +#define BCM2711_ARMC_IRQ2_PENDING0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x80)
>>>>> +#define BCM2711_ARMC_IRQ2_PENDING1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x84)
>>>>> +#define BCM2711_ARMC_IRQ2_PENDING2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x88)
>>>>> +#define BCM2711_ARMC_IRQ2_SET_EN_0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x90)
>>>>> +#define BCM2711_ARMC_IRQ2_SET_EN_1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x94)
>>>>> +#define BCM2711_ARMC_IRQ2_SET_EN_2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x98)
>>>>> +#define BCM2711_ARMC_IRQ2_CLR_EN_0
>>>>> (BCM2711_ARMC_REGS_BASE + 0xA0)
>>>>> +#define BCM2711_ARMC_IRQ2_CLR_EN_1
>>>>> (BCM2711_ARMC_REGS_BASE + 0xA4)
>>>>> +#define BCM2711_ARMC_IRQ2_CLR_EN_2
>>>>> (BCM2711_ARMC_REGS_BASE + 0xA8)
>>>>> +#define BCM2711_ARMC_IRQ3_PENDING0
>>>>> (BCM2711_ARMC_REGS_BASE + 0xC0)
>>>>> +#define BCM2711_ARMC_IRQ3_PENDING1
>>>>> (BCM2711_ARMC_REGS_BASE + 0xC4)
>>>>> +#define BCM2711_ARMC_IRQ3_PENDING2
>>>>> (BCM2711_ARMC_REGS_BASE + 0xC8)
>>>>> +#define BCM2711_ARMC_IRQ3_SET_EN_0
>>>>> (BCM2711_ARMC_REGS_BASE + 0xD0)
>>>>> +#define BCM2711_ARMC_IRQ3_SET_EN_1
>>>>> (BCM2711_ARMC_REGS_BASE + 0xD4)
>>>>> +#define BCM2711_ARMC_IRQ3_SET_EN_2
>>>>> (BCM2711_ARMC_REGS_BASE + 0xD8)
>>>>> +#define BCM2711_ARMC_IRQ3_CLR_EN_0
>>>>> (BCM2711_ARMC_REGS_BASE + 0xE0)
>>>>> +#define BCM2711_ARMC_IRQ3_CLR_EN_1
>>>>> (BCM2711_ARMC_REGS_BASE + 0xE4)
>>>>> +#define BCM2711_ARMC_IRQ3_CLR_EN_2
>>>>> (BCM2711_ARMC_REGS_BASE + 0xE8)
>>>>> +#define BCM2711_ARMC_FIQ0_PENDING0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x100)
>>>>> +#define BCM2711_ARMC_FIQ0_PENDING1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x104)
>>>>> +#define BCM2711_ARMC_FIQ0_PENDING2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x108)
>>>>> +#define BCM2711_ARMC_FIQ0_SET_EN_0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x110)
>>>>> +#define BCM2711_ARMC_FIQ0_SET_EN_1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x114)
>>>>> +#define BCM2711_ARMC_FIQ0_SET_EN_2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x118)
>>>>> +#define BCM2711_ARMC_FIQ0_CLR_EN_0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x120)
>>>>> +#define BCM2711_ARMC_FIQ0_CLR_EN_1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x124)
>>>>> +#define BCM2711_ARMC_FIQ0_CLR_EN_2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x128)
>>>>> +#define BCM2711_ARMC_FIQ1_PENDING0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x140)
>>>>> +#define BCM2711_ARMC_FIQ1_PENDING1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x144)
>>>>> +#define BCM2711_ARMC_FIQ1_PENDING2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x148)
>>>>> +#define BCM2711_ARMC_FIQ1_SET_EN_0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x150)
>>>>> +#define BCM2711_ARMC_FIQ1_SET_EN_1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x154)
>>>>> +#define BCM2711_ARMC_FIQ1_SET_EN_2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x158)
>>>>> +#define BCM2711_ARMC_FIQ1_CLR_EN_0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x160)
>>>>> +#define BCM2711_ARMC_FIQ1_CLR_EN_1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x164)
>>>>> +#define BCM2711_ARMC_FIQ1_CLR_EN_2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x168)
>>>>> +#define BCM2711_ARMC_FIQ2_PENDING0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x180)
>>>>> +#define BCM2711_ARMC_FIQ2_PENDING1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x184)
>>>>> +#define BCM2711_ARMC_FIQ2_PENDING2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x188)
>>>>> +#define BCM2711_ARMC_FIQ2_SET_EN_0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x190)
>>>>> +#define BCM2711_ARMC_FIQ2_SET_EN_1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x194)
>>>>> +#define BCM2711_ARMC_FIQ2_SET_EN_2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x198)
>>>>> +#define BCM2711_ARMC_FIQ2_CLR_EN_0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x1A0)
>>>>> +#define BCM2711_ARMC_FIQ2_CLR_EN_1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x1A4)
>>>>> +#define BCM2711_ARMC_FIQ2_CLR_EN_2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x1A8)
>>>>> +#define BCM2711_ARMC_FIQ3_PENDING0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x1C0)
>>>>> +#define BCM2711_ARMC_FIQ3_PENDING1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x1C4)
>>>>> +#define BCM2711_ARMC_FIQ3_PENDING2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x1C8)
>>>>> +#define BCM2711_ARMC_FIQ3_SET_EN_0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x1D0)
>>>>> +#define BCM2711_ARMC_FIQ3_SET_EN_1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x1D4)
>>>>> +#define BCM2711_ARMC_FIQ3_SET_EN_2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x1D8)
>>>>> +#define BCM2711_ARMC_FIQ3_CLR_EN_0
>>>>> (BCM2711_ARMC_REGS_BASE + 0x1E0)
>>>>> +#define BCM2711_ARMC_FIQ3_CLR_EN_1
>>>>> (BCM2711_ARMC_REGS_BASE + 0x1E4)
>>>>> +#define BCM2711_ARMC_FIQ3_CLR_EN_2
>>>>> (BCM2711_ARMC_REGS_BASE + 0x1E8)
>>>>> +#define BCM2711_ARMC_SWIRQ_SET
>>>>> (BCM2711_ARMC_REGS_BASE + 0x1F0)
>>>>> +#define BCM2711_ARMC_SWIRQ_CLEAR
>>>>> (BCM2711_ARMC_REGS_BASE + 0x1F4)
>>>>> +#endif /* LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H */
>>>>> diff --git a/bsps/aarch64/raspberrypi/include/tm27.h
>>>>> b/bsps/aarch64/raspberrypi/include/tm27.h
>>>>> index 0000000000..653f88ed01
>>>>> --- /dev/null
>>>>> +++ b/bsps/aarch64/raspberrypi/include/tm27.h
>>>>> @@ -0,0 +1,46 @@
>>>>> + * @file
>>>>> + * @brief BSP tm27 header
>>>>> + * are met:
>>>>> copyright
>>>>> the
>>>>> distribution.
>>>>> TO, THE
>>>>> PURPOSE
>>>>> CONTRIBUTORS BE
>>>>> OF
>>>>> BUSINESS
>>>>> WHETHER IN
>>>>> OTHERWISE)
>>>>> ADVISED OF THE
>>>>> +#ifndef _RTEMS_TMTEST27
>>>>> +#error "This is an RTEMS internal file you must not include directly."
>>>>> +#endif
>>>>> +#ifndef __tm27_h
>>>>> +#define __tm27_h
>>>>> +#include <dev/irq/arm-gic-tm27.h>
>>>>> +#endif /* __tm27_h */
>>>>> \ No newline at end of file
>>>>> diff --git a/bsps/aarch64/raspberrypi/start/bspstart.c
>>>>> b/bsps/aarch64/raspberrypi/start/bspstart.c
>>>>> index 0000000000..56f52a2231
>>>>> --- /dev/null
>>>>> +++ b/bsps/aarch64/raspberrypi/start/bspstart.c
>>>>> @@ -0,0 +1,49 @@
>>>>> + * @file
>>>>> + * @brief BSP Startup
>>>>> + * are met:
>>>>> copyright
>>>>> the
>>>>> distribution.
>>>>> TO, THE
>>>>> PURPOSE
>>>>> CONTRIBUTORS BE
>>>>> OF
>>>>> BUSINESS
>>>>> WHETHER IN
>>>>> OTHERWISE)
>>>>> ADVISED OF THE
>>>>> +#include <bsp.h>
>>>>> +#include <bsp/bootcard.h>
>>>>> +#include <bsp/irq-generic.h>
>>>>> +#include <bsp/linker-symbols.h>
>>>>> +void bsp_start( void )
>>>>> + bsp_interrupt_initialize();
>>>>> + rtems_cache_coherent_add_area(
>>>>> + bsp_section_nocacheheap_begin,
>>>>> + (uintptr_t) bsp_section_nocacheheap_size
>>>>> diff --git a/bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>>>> b/bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>>>> index 0000000000..fe0fe77c09
>>>>> --- /dev/null
>>>>> +++ b/bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>>>> @@ -0,0 +1,53 @@
>>>>> + * @file
>>>>> + * @brief BSP Startup Hooks
>>>>> + * are met:
>>>>> copyright
>>>>> the
>>>>> distribution.
>>>>> TO, THE
>>>>> PURPOSE
>>>>> CONTRIBUTORS BE
>>>>> OF
>>>>> BUSINESS
>>>>> WHETHER IN
>>>>> OTHERWISE)
>>>>> ADVISED OF THE
>>>>> +#include <bsp.h>
>>>>> +#include <rtems/score/cpu.h>
>>>>> +BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
>>>>> + /* Do nothing */
>>>>> +BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
>>>>> + AArch64_start_set_vector_base();
>>>>> + bsp_start_copy_sections();
>>>>> + raspberrypi_4_setup_mmu_and_cache();
>>>>> + bsp_start_clear_bss();
>>>>> diff --git a/bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>>>> b/bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>>>> index 0000000000..ab12020a2a
>>>>> --- /dev/null
>>>>> +++ b/bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>>>> @@ -0,0 +1,84 @@
>>>>> + * @file
>>>>> + * @brief This source file contains the default MMU tables and setup.
>>>>> + * are met:
>>>>> copyright
>>>>> the
>>>>> distribution.
>>>>> TO, THE
>>>>> PURPOSE
>>>>> CONTRIBUTORS BE
>>>>> OF
>>>>> BUSINESS
>>>>> WHETHER IN
>>>>> OTHERWISE)
>>>>> ADVISED OF THE
>>>>> +#include <bsp.h>
>>>>> +#include <bsp/aarch64-mmu.h>
>>>>> +#include <bsp/raspberrypi.h>
>>>>> +#include <libcpu/mmu-vmsav8-64.h>
>>>>> +BSP_START_DATA_SECTION static const aarch64_mmu_config_entry
>>>>> +raspberrypi_4_mmu_config_table[] = {
>>>>> + AARCH64_MMU_DEFAULT_SECTIONS,
>>>>> + { /* RPI peripheral address */
>>>>> + .begin = (unsigned)RPI_PERIPHERAL_BASE,
>>>>> + .end = (unsigned)RPI_PERIPHERAL_BASE +
>>>>> (unsigned)RPI_PERIPHERAL_SIZE,
>>>>> + .flags = AARCH64_MMU_DEVICE
>>>>> + { /* RPI ARM local registers */
>>>>> + .begin = (unsigned)BCM2711_LOCAL_REGS_BASE,
>>>>> + .end = (unsigned)BCM2711_LOCAL_REGS_BASE +
>>>>> (unsigned)BCM2711_LOCAL_REGS_SIZE,
>>>>> + { /* RPI GIC Interface address */
>>>>> + .begin = 0xFF800000U,
>>>>> + .end = 0xFFA00000U,
>>>>> + * Make weak and let the user override.
>>>>> +raspberrypi_4_setup_mmu_and_cache( void ) __attribute__ ((weak));
>>>>> + aarch64_mmu_setup();
>>>>> + aarch64_mmu_setup_translation_table(
>>>>> + &raspberrypi_4_mmu_config_table[ 0 ],
>>>>> + RTEMS_ARRAY_SIZE( raspberrypi_4_mmu_config_table )
>>>>> + aarch64_mmu_enable();
>>>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/abi.yml
>>>>> b/spec/build/bsps/aarch64/raspberrypi/abi.yml
>>>>> index 0000000000..5e3e0a4975
>>>>> --- /dev/null
>>>>> +++ b/spec/build/bsps/aarch64/raspberrypi/abi.yml
>>>>> @@ -0,0 +1,21 @@
>>>>> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>>>>> +actions:
>>>>> +- get-string: null
>>>>> +- split: null
>>>>> +- env-append: null
>>>>> +build-type: option
>>>>> +copyrights:
>>>>> +- Copyright (C) 2022 Mohd Noor Aman
>>>>> +default:
>>>>> +- -mcpu=cortex-a72
>>>>> +- -march=armv8-a
>>>>> +default-by-variant: []
>>>>> +includes: []
>>>>> +description: |
>>>>> + ABI flags
>>>>> +links: []
>>>>> +enabled-by: true
>>>>> +name: ABI_FLAGS
>>>>> +type: build
>>>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>>>> b/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>>>> index 0000000000..d2ff76d351
>>>>> --- /dev/null
>>>>> +++ b/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>>>> @@ -0,0 +1,81 @@
>>>>> +arch: aarch64
>>>>> +bsp: raspberrypi4b
>>>>> +build-type: bsp
>>>>> +cflags: []
>>>>> +copyrights:
>>>>> +cppflags: []
>>>>> +enabled-by: true
>>>>> +family: raspberrypi
>>>>> +includes: []
>>>>> +install:
>>>>> +- destination: ${BSP_INCLUDEDIR}
>>>>> + source:
>>>>> + - bsps/aarch64/raspberrypi/include/bsp.h
>>>>> + - bsps/aarch64/raspberrypi/include/tm27.h
>>>>> +- destination: ${BSP_INCLUDEDIR}/bsp
>>>>> + source:
>>>>> + - bsps/aarch64/raspberrypi/include/bsp/irq.h
>>>>> + - bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>>> +source:
>>>>> +- bsps/aarch64/raspberrypi/console/console.c
>>>>> +- bsps/aarch64/raspberrypi/start/bspstart.c
>>>>> +- bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>>>> +- bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>>>> +- bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
>>>>> +- bsps/aarch64/shared/cache/cache.c
>>>>> +- bsps/aarch64/shared/mmu/vmsav8-64.c
>>>>> +- bsps/shared/dev/clock/arm-generic-timer.c
>>>>> +- bsps/shared/dev/irq/arm-gicv2.c
>>>>> +- bsps/shared/dev/irq/arm-gicv2-get-attributes.c
>>>>> +- bsps/shared/dev/serial/console-termios-init.c
>>>>> +- bsps/shared/dev/serial/console-termios.c
>>>>> +- bsps/shared/dev/serial/arm-pl011.c
>>>>> +- bsps/shared/dev/getentropy/getentropy-cpucounter.c
>>>>> +- bsps/shared/dev/btimer/btimer-cpucounter.c
>>>>> +- bsps/shared/irq/irq-default-handler.c
>>>>> +- bsps/shared/irq/irq-handler-install.c
>>>>> +- bsps/shared/irq/irq-generic.c
>>>>> +- bsps/shared/irq/irq-lock.c
>>>>> +- bsps/shared/start/bspfatal-default.c
>>>>> +- bsps/shared/start/bspreset-arm-psci.c
>>>>> +- bsps/shared/start/gettargethash-default.c
>>>>> +- bsps/shared/start/sbrk.c
>>>>> +- bsps/shared/start/wkspaceinitone.c
>>>>> +- bsps/shared/start/mallocinitmulti.c
>>>>> +- bsps/shared/start/bspgetworkarea-default.c
>>>>> +links:
>>>>> +- role: build-dependency
>>>>> + uid: ../grp
>>>>> + uid: ../start
>>>>> + uid: ../optmmupages
>>>>> + uid: ../optgtusevirt
>>>>> + uid: ../optgtuseps
>>>>> + uid: abi
>>>>> + uid: ../../optcachedata
>>>>> + uid: ../../optcacheinst
>>>>> + uid: ../../opto2
>>>>> + uid: ../../bspopts
>>>>> + uid: linkercmds
>>>>> + uid: ../../obj
>>>>> + uid: ../../objirq
>>>>> +type: build
>>>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>>>> b/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>>>> index 0000000000..8598b89cba
>>>>> --- /dev/null
>>>>> +++ b/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>>>> @@ -0,0 +1,76 @@
>>>>> +build-type: config-file
>>>>> +content: |
>>>>> + /* SPDX-License-Identifier: BSD-2-Clause */
>>>>> without
>>>>> conditions
>>>>> + * are met:
>>>>> copyright
>>>>> in the
>>>>> distribution.
>>>>> LIMITED TO, THE
>>>>> PARTICULAR PURPOSE
>>>>> CONTRIBUTORS BE
>>>>> OR
>>>>> PROCUREMENT OF
>>>>> BUSINESS
>>>>> WHETHER IN
>>>>> OTHERWISE)
>>>>> ADVISED OF THE
>>>>> + MEMORY {
>>>>> + RAM_MMU : ORIGIN = 0x0, LENGTH = (0x1000 *
>>>>> ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
>>>>> + RAM : ORIGIN = 0x80000, LENGTH = 1024M
>>>>> + REGION_ALIAS ("REGION_START", RAM);
>>>>> + REGION_ALIAS ("REGION_VECTOR", RAM);
>>>>> + REGION_ALIAS ("REGION_TEXT", RAM);
>>>>> + REGION_ALIAS ("REGION_TEXT_LOAD", RAM);
>>>>> + REGION_ALIAS ("REGION_RODATA", RAM);
>>>>> + REGION_ALIAS ("REGION_RODATA_LOAD", RAM);
>>>>> + REGION_ALIAS ("REGION_DATA", RAM);
>>>>> + REGION_ALIAS ("REGION_DATA_LOAD", RAM);
>>>>> + REGION_ALIAS ("REGION_FAST_TEXT", RAM);
>>>>> + REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
>>>>> + REGION_ALIAS ("REGION_FAST_DATA", RAM);
>>>>> + REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
>>>>> + REGION_ALIAS ("REGION_BSS", RAM);
>>>>> + REGION_ALIAS ("REGION_WORK", RAM);
>>>>> + REGION_ALIAS ("REGION_STACK", RAM);
>>>>> + REGION_ALIAS ("REGION_NOCACHE", RAM);
>>>>> + REGION_ALIAS ("REGION_NOCACHE_LOAD", RAM);
>>>>> + bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ?
>>>>> bsp_stack_abt_size : 1024;
>>>>> + bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align)
>>>>> ? bsp_section_rwbarrier_align : 1M;
>>>>> + bsp_stack_exception_size = DEFINED (bsp_stack_exception_size) ?
>>>>> bsp_stack_exception_size : 1024;
>>>>> + bsp_vector_table_in_start_section = 1;
>>>>> + bsp_translation_table_base = ORIGIN (RAM_MMU);
>>>>> + bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
>>>>> + OUTPUT_FORMAT ("elf64-littleaarch64")
>>>>> + OUTPUT_ARCH (aarch64)
>>>>> + INCLUDE linkcmds.base
>>>>> +copyrights:
>>>>> +enabled-by: true
>>>>> +install-path: ${BSP_LIBDIR}
>>>>> +links: []
>>>>> +target: linkcmds
>>>>> +type: build
>>>>> 2.37.3
>>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> devel mailing list
>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221004/78c905b8/attachment-0001.htm>
