[PATCH v3] bsp/aarch64: Add new Raspberry Pi 4B BSP
Tue Oct 4 22:06:18 UTC 2022
On Tue, Oct 4, 2022 at 5:03 PM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Oct 4, 2022 at 4:38 PM Alan Cudmore <alan.cudmore at gmail.com>
> wrote:
>> It builds without error and boots for me!
>> I ran my RTEMS Kernel Image and tried out some task demos, whetstone,
>> dhrystone, created a RAM disk, etc.
>> Next will be a core Flight System (cFS) run.
>> This is going to be a very useful board to have RTEMS + SMP + Libbsd on,
>> especially when people can buy them again.
>> Thanks!
>> Alan
>> RTEMS Kernel Image Booting
>> *** RTEMS Info ***
>> 6.0.0.cc43dc3e22b21ddf902b7748fb27f16c9aee3719
>>  BSP Ticks Per Second = 100
>> *** End RTEMS info ***
>> Populating Root file system from TAR file.
>> Setting up filesystems.
>> Initializing Local Commands.
>> Adding Target specific commands
>> Running /shell-init.
>> 1: mkdir ram
>> 2: mkrfs /dev/rda
>> 3: mount -t rfs /dev/rda /ram
>> mounted /dev/rda -> /ram
>> 4: hello
>>     ____  ______________  ________
>>    / __ \/_  __/ ____/  \/  / ___/
>>   / /_/ / / / / __/ / /\_/ /\__ \
>>  / _, _/ / / / /___/ /  / /___/ /
>> /_/ \_| /_/ /_____/_/  /_//____/
>> Hello RTEMS!
>> Create your own command here!
>> Starting shell....
>> RTEMS Shell on /dev/console. Use 'help' to list commands.
>> shell0 [/] #
> Wow! I'm always impressed by how many RTEMS capabilities are
> available in a basic BSP.
> All it needs now is a network driver. <hint> :)
> I'll merge this .
Well I couldn't stand to wait until morning to merge this. I just
pushed it. Please check that it is OK.
Are there any documentation patches?
--joel
> --joel
>> On Tue, Oct 4, 2022 at 2:40 PM Joel Sherrill <joel at rtems.org> wrote:
>>> Once Alan says it's OK, I will merge this.
>>> Great work! Please make sure code, docs, tester configuration, etc gets
>>> merged.
>>> On Tue, Oct 4, 2022 at 1:18 PM Kinsey Moore <kinsey.moore at oarcorp.com>
>>> wrote:
>>>> I think all of the issues with this patch have been addressed; this
>>>> looks good to me.
>>>> Great work, Noor!
>>>> Kinsey
>>>> On Tue, Oct 4, 2022 at 11:12 AM Noor Aman <nooraman5718 at gmail.com>
>>>> wrote:
>>>>> hey all,
>>>>> I've fixed the warning and edited the commit message to be more
>>>>> specific and to be in 80 words char limit.
>>>>> Thanks,
>>>>> Noor
>>>>> On Tue, 4 Oct 2022 at 16:08, Mohd Noor Aman <nooraman5718 at gmail.com>
>>>>> wrote:
>>>>>> This patch adds new Raspberry pi 4B AArch64 BSP to the RTEMS Family.
>>>>>> Currently
>>>>>> only LP64 ABI is supported. ILP32 is not supported. RAM starts from
>>>>>> 0x80000 in
>>>>>> 64Bit kernel mode and MMU from 0x0. All Raspberrypi Pi 4B models and
>>>>>> Raspberry
>>>>>> Pi 400 are supported. All the IRQs are similiar to the older
>>>>>> Raspberry pi 2 ARM
>>>>>> BSP.
>>>>>> Raspberry Pi 4B has 2 types of UARTs. Only PL011 serial is supported
>>>>>> currently.
>>>>>> Mini-UART is not supported. Mini-UART is default UART on the board so
>>>>>> it needs
>>>>>> to be disabled by adding "dtoverlay=disable-bt" to the config.txt. No
>>>>>> support
>>>>>> for additional 4 PL011-UARTs on the board.
>>>>>> The raspberrypi.h includes many of the address required for the future
>>>>>> development of the RPi 4B BSP. This includes peripherals, ARM Timer,
>>>>>> VideoCore
>>>>>> Timer, Watchdog, Mailbox, AUX, FIQs and IRQs.
>>>>>>  bsps/aarch64/raspberrypi/console/console.c    |  69 +++
>>>>>>  bsps/aarch64/raspberrypi/include/bsp.h        |  76 +++
>>>>>>  bsps/aarch64/raspberrypi/include/bsp/irq.h    | 109 ++++
>>>>>>  .../raspberrypi/include/bsp/raspberrypi.h     | 471
>>>>>>  bsps/aarch64/raspberrypi/include/tm27.h       |  46 ++
>>>>>>  bsps/aarch64/raspberrypi/start/bspstart.c     |  49 ++
>>>>>>  .../aarch64/raspberrypi/start/bspstarthooks.c |  53 ++
>>>>>>  bsps/aarch64/raspberrypi/start/bspstartmmu.c  |  84 ++++
>>>>>>  spec/build/bsps/aarch64/raspberrypi/abi.yml   |  21 +
>>>>>>  .../aarch64/raspberrypi/bspraspberrypi4.yml   |  81 +++
>>>>>>  .../bsps/aarch64/raspberrypi/linkercmds.yml   |  76 +++
>>>>>>  11 files changed, 1135 insertions(+)
>>>>>>  create mode 100644 bsps/aarch64/raspberrypi/console/console.c
>>>>>>  create mode 100644 bsps/aarch64/raspberrypi/include/bsp.h
>>>>>>  create mode 100644 bsps/aarch64/raspberrypi/include/bsp/irq.h
>>>>>>  create mode 100644 bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>>>>  create mode 100644 bsps/aarch64/raspberrypi/include/tm27.h
>>>>>>  create mode 100644 bsps/aarch64/raspberrypi/start/bspstart.c
>>>>>>  create mode 100644 bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>>>>>  create mode 100644 bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>>>>>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/abi.yml
>>>>>>  create mode 100644
>>>>>> spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>>>>>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>>>>> diff --git a/bsps/aarch64/raspberrypi/console/console.c
>>>>>> b/bsps/aarch64/raspberrypi/console/console.c
>>>>>> new file mode 100644
>>>>>> index 0000000000..73bb0036ff
>>>>>> --- /dev/null
>>>>>> +++ b/bsps/aarch64/raspberrypi/console/console.c
>>>>>> @@ -0,0 +1,69 @@
>>>>>> +/* SPDX-License-Identifier: BSD-2-Clause */
>>>>>> + * @file
>>>>>> + * @ingroup RTEMSBSPsAArch64Raspberrypi4
>>>>>> + * @brief Console Configuration
>>>>>> + * Copyright (C) 2022 Mohd Noor Aman
>>>>>> + * Redistribution and use in source and binary forms, with or without
>>>>>> + * modification, are permitted provided that the following conditions
>>>>>> + * are met:
>>>>>> + * 1. Redistributions of source code must retain the above copyright
>>>>>> + *    notice, this list of conditions and the following disclaimer.
>>>>>> + * 2. Redistributions in binary form must reproduce the above
>>>>>> copyright
>>>>>> in the
>>>>>> + *    documentation and/or other materials provided with the
>>>>>> distribution.
>>>>>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>>> CONTRIBUTORS "AS IS"
>>>>>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>>>>> TO, THE
>>>>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>>>>>> PARTICULAR PURPOSE
>>>>>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>>>>>> CONTRIBUTORS BE
>>>>>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
>>>>>> OR
>>>>>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
>>>>>> OF
>>>>>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>>>> BUSINESS
>>>>>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>>>> WHETHER IN
>>>>>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>>> OTHERWISE)
>>>>>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>>>>> ADVISED OF THE
>>>>>> + * POSSIBILITY OF SUCH DAMAGE.
>>>>>> +#include <rtems/bspIo.h>
>>>>>> +#include <bsp.h>
>>>>>> +#include <dev/serial/arm-pl011.h>
>>>>>> +#include <bsp/console-termios.h>
>>>>>> +#include <bspopts.h>
>>>>>> +arm_pl011_context raspberrypi_4_context = {
>>>>>> +  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
>>>>>> +  .regs = (volatile pl011 *) BSP_RPI4_PL011_BASE,
>>>>>> +  .initial_baud = 115200
>>>>>> +const console_device console_device_table[] = {
>>>>>> +    .device_file = "/dev/ttyS0",
>>>>>> +    .probe = console_device_probe_default,
>>>>>> +    .handler = &arm_pl011_fns,
>>>>>> +    .context = &raspberrypi_4_context.base
>>>>>> +const size_t console_device_count =
>>>>>> RTEMS_ARRAY_SIZE(console_device_table);
>>>>>> +static void output_char( char c )
>>>>>> +  arm_pl011_write_polled(&raspberrypi_4_context.base, c);
>>>>>> +BSP_output_char_function_type BSP_output_char = output_char;
>>>>>> +BSP_polling_getchar_function_type BSP_poll_char = NULL;
>>>>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp.h
>>>>>> b/bsps/aarch64/raspberrypi/include/bsp.h
>>>>>> index 0000000000..4fa81edd40
>>>>>> --- /dev/null
>>>>>> +++ b/bsps/aarch64/raspberrypi/include/bsp.h
>>>>>> @@ -0,0 +1,76 @@
>>>>>> + * @file
>>>>>> + * @brief Core BSP definitions
>>>>>> + * are met:
>>>>>> copyright
>>>>>> in the
>>>>>> distribution.
>>>>>> TO, THE
>>>>>> PARTICULAR PURPOSE
>>>>>> CONTRIBUTORS BE
>>>>>> OR
>>>>>> OF
>>>>>> BUSINESS
>>>>>> WHETHER IN
>>>>>> OTHERWISE)
>>>>>> ADVISED OF THE
>>>>>> +#ifndef LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H
>>>>>> +#define LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H
>>>>>> + * @addtogroup RTEMSBSPsAArch64
>>>>>> +#ifndef ASM
>>>>>> +#include <bsp/default-initial-extension.h>
>>>>>> +#include <bsp/start.h>
>>>>>> +#include <rtems.h>
>>>>>> +/*Raspberry pi MMU initialization */
>>>>>> +BSP_START_TEXT_SECTION void raspberrypi_4_setup_mmu_and_cache(void);
>>>>>> +#ifdef __cplusplus
>>>>>> +extern "C" {
>>>>>> +#endif /* __cplusplus */
>>>>>> +#define BSP_ARM_GIC_CPUIF_BASE 0xFF842000
>>>>>> +#define BSP_ARM_GIC_DIST_BASE 0xFF841000
>>>>>> +#define BSP_RPI4_PL011_BASE 0xFE201000
>>>>>> +#define BSP_RPI4_PL011_LENGTH 0x200
>>>>>> +#ifdef __cplusplus
>>>>>> +#endif /* ASM */
>>>>>> +#endif /* LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H */
>>>>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp/irq.h
>>>>>> b/bsps/aarch64/raspberrypi/include/bsp/irq.h
>>>>>> index 0000000000..effec1b040
>>>>>> --- /dev/null
>>>>>> +++ b/bsps/aarch64/raspberrypi/include/bsp/irq.h
>>>>>> @@ -0,0 +1,109 @@
>>>>>> + * @file
>>>>>> + * @ingroup raspberrypi_interrupt
>>>>>> + * @brief Interrupt definitions.
>>>>>> + * Copyright (c) 2013 Alan Cudmore
>>>>>> + * Copyright (c) 2022 Mohd Noor Aman
>>>>>> + *  The license and distribution terms for this file may be
>>>>>> + *  found in the file LICENSE in this distribution or at
>>>>>> + *  http://www.rtems.org/license/LICENSE
>>>>>> +#ifndef LIBBSP_ARM_RASPBERRYPI_IRQ_H
>>>>>> +#define LIBBSP_ARM_RASPBERRYPI_IRQ_H
>>>>>> +#ifndef ASM
>>>>>> +#include <rtems.h>
>>>>>> +#include <rtems/irq.h>
>>>>>> +#include <rtems/irq-extension.h>
>>>>>> +#include <dev/irq/arm-gic-irq.h>
>>>>>> +#if defined(RTEMS_SMP)
>>>>>> +#include <rtems/score/processormask.h>
>>>>>> +#endif
>>>>>> + * @defgroup raspberrypi_interrupt Interrrupt Support
>>>>>> + * @ingroup RTEMSBSPsARMRaspberryPi
>>>>>> + * @brief Interrupt support.
>>>>>> +#define BCM2835_INTC_TOTAL_IRQ       (64 + 8)
>>>>>> +#define BCM2835_IRQ_SET1_MIN         0
>>>>>> +#define BCM2835_IRQ_SET2_MIN         32
>>>>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M0  0
>>>>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M1  1
>>>>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M2  2
>>>>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M3  3
>>>>>> +#define BCM2835_IRQ_ID_USB           9
>>>>>> +#define BCM2835_IRQ_ID_AUX           29
>>>>>> +#define BCM2835_IRQ_ID_SPI_SLAVE     43
>>>>>> +#define BCM2835_IRQ_ID_PWA0          45
>>>>>> +#define BCM2835_IRQ_ID_PWA1          46
>>>>>> +#define BCM2835_IRQ_ID_SMI           48
>>>>>> +#define BCM2835_IRQ_ID_GPIO_0        49
>>>>>> +#define BCM2835_IRQ_ID_GPIO_1        50
>>>>>> +#define BCM2835_IRQ_ID_GPIO_2        51
>>>>>> +#define BCM2835_IRQ_ID_GPIO_3        52
>>>>>> +#define BCM2835_IRQ_ID_I2C           53
>>>>>> +#define BCM2835_IRQ_ID_SPI           54
>>>>>> +#define BCM2835_IRQ_ID_PCM           55
>>>>>> +#define BCM2835_IRQ_ID_UART          57
>>>>>> +#define BCM2835_IRQ_ID_SD            62
>>>>>> +#define BCM2835_IRQ_ID_BASIC_BASE_ID 64
>>>>>> +#define BCM2835_IRQ_ID_TIMER_0       64
>>>>>> +#define BCM2835_IRQ_ID_MAILBOX_0     65
>>>>>> +#define BCM2835_IRQ_ID_DOORBELL_0    66
>>>>>> +#define BCM2835_IRQ_ID_DOORBELL_1    67
>>>>>> +#define BCM2835_IRQ_ID_GPU0_HALTED   68
>>>>>> +#define BCM2835_IRQ_ID_GPU1_HALTED   69
>>>>>> +#define BCM2835_IRQ_ID_ILL_ACCESS_1  70
>>>>>> +#define BCM2835_IRQ_ID_ILL_ACCESS_0  71
>>>>>> +#define BSP_TIMER_VIRT_PPI 27
>>>>>> +#define BSP_TIMER_PHYS_NS_PPI 30
>>>>>> +#define BSP_VPL011_SPI 32
>>>>>> +#define BSP_INTERRUPT_VECTOR_COUNT    BCM2835_INTC_TOTAL_IRQ
>>>>>> +#define BSP_INTERRUPT_VECTOR_INVALID (UINT32_MAX)
>>>>>> +#define BSP_IRQ_COUNT               (BCM2835_INTC_TOTAL_IRQ)
>>>>>> +static inline rtems_status_code bsp_interrupt_set_affinity(
>>>>>> +  rtems_vector_number   vector,
>>>>>> +  const Processor_mask *affinity
>>>>>> +  (void) vector;
>>>>>> +  (void) affinity;
>>>>>> +  return RTEMS_UNSATISFIED;
>>>>>> +static inline rtems_status_code bsp_interrupt_get_affinity(
>>>>>> +  Processor_mask      *affinity
>>>>>> +  (void) vector;
>>>>>> +  _Processor_mask_From_index( affinity, 0 );
>>>>>> +#endif
>>>>>> +#endif /* ASM */
>>>>>> +#endif /* LIBBSP_ARM_RASPBERRYPI_IRQ_H */
>>>>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>>>> b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>>>> index 0000000000..f148e8df6c
>>>>>> --- /dev/null
>>>>>> +++ b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>>>> @@ -0,0 +1,471 @@
>>>>>> + * @file
>>>>>> + * @ingroup raspberrypi_4_regs
>>>>>> + * @brief Register definitions.
>>>>>> +#ifndef LIBBSP_AARCH64_RASPBERRYPI_RASPBERRYPI_4_H
>>>>>> +#define LIBBSP_AARCH64_RASPBERRYPI_RASPBERRYPI_4_H
>>>>>> +#include <stdint.h>
>>>>>> +#include <bsp/utility.h>
>>>>>> + * @defgroup raspberrypi_reg Register Definitions
>>>>>> + * @brief Register Definitions
>>>>>> + * @name Register Macros
>>>>>> +#define BCM2711_REG(x)           (*(volatile uint64_t *)(x))
>>>>>> +#define BCM2711_BIT(n)           (1 << (n))
>>>>>> + * @name Peripheral Base Register Address
>>>>>> +#define RPI_PERIPHERAL_BASE         0xFE000000
>>>>>> +#define BASE_OFFSET                 0xFE000000
>>>>>> +#define RPI_PERIPHERAL_SIZE         0x01800000
>>>>>> + * @name Bus to Physical address translation
>>>>>> + *       Macro.
>>>>>> +#define BUS_TO_PHY(x)            ((x) - BASE_OFFSET)
>>>>>> + * @name Internal ARM Timer Registers
>>>>>> +#define BCM2711_CLOCK_FREQ       250000000
>>>>>> +#define BCM2711_TIMER_BASE       (RPI_PERIPHERAL_BASE + 0xB400)
>>>>>> +#define BCM2711_TIMER_LOD        (BCM2711_TIMER_BASE + 0x00)
>>>>>> +#define BCM2711_TIMER_VAL        (BCM2711_TIMER_BASE + 0x04)
>>>>>> +#define BCM2711_TIMER_CTL        (BCM2711_TIMER_BASE + 0x08)
>>>>>> +#define BCM2711_TIMER_CLI        (BCM2711_TIMER_BASE + 0x0C)
>>>>>> +#define BCM2711_TIMER_RIS        (BCM2711_TIMER_BASE + 0x10)
>>>>>> +#define BCM2711_TIMER_MIS        (BCM2711_TIMER_BASE + 0x14)
>>>>>> +#define BCM2711_TIMER_RLD        (BCM2711_TIMER_BASE + 0x18)
>>>>>> +#define BCM2711_TIMER_DIV        (BCM2711_TIMER_BASE + 0x1C)
>>>>>> +#define BCM2711_TIMER_CNT        (BCM2711_TIMER_BASE + 0x20)
>>>>>> +#define BCM2711_TIMER_PRESCALE    0xF9
>>>>>> + * @name Power Management and Watchdog  Registers
>>>>>> +#define BCM2711_PM_PASSWD_MAGIC  0x5a000000
>>>>>> +#define BCM2711_PM_BASE          (RPI_PERIPHERAL_BASE + 0x100000)
>>>>>> +#define BCM2711_PM_GNRIC         (BCM2711_PM_BASE + 0x00)
>>>>>> +#define BCM2711_PM_GNRIC_POWUP   0x00000001
>>>>>> +#define BCM2711_PM_GNRIC_POWOK   0x00000002
>>>>>> +#define BCM2711_PM_GNRIC_ISPOW   0x00000004
>>>>>> +#define BCM2711_PM_GNRIC_MEMREP  0x00000008
>>>>>> +#define BCM2711_PM_GNRIC_MRDONE  0x00000010
>>>>>> +#define BCM2711_PM_GNRIC_ISFUNC  0x00000020
>>>>>> +#define BCM2711_PM_GNRIC_RSTN    0x00000fc0
>>>>>> +#define BCM2711_PM_GNRIC_ENAB    0x00001000
>>>>>> +#define BCM2711_PM_GNRIC_CFG     0x007f0000
>>>>>> +#define BCM2711_PM_AUDIO         (BCM2711_PM_BASE + 0x04)
>>>>>> +#define BCM2711_PM_AUDIO_APSM    0x000fffff
>>>>>> +#define BCM2711_PM_AUDIO_CTRLEN  0x00100000
>>>>>> +#define BCM2711_PM_AUDIO_RSTN    0x00200000
>>>>>> +#define BCM2711_PM_STATUS        (BCM2711_PM_BASE + 0x18)
>>>>>> +#define BCM2711_PM_RSTC          (BCM2711_PM_BASE + 0x1c)
>>>>>> +#define BCM2711_PM_RSTC_DRCFG    0x00000003
>>>>>> +#define BCM2711_PM_RSTC_WRCFG    0x00000030
>>>>>> +#define BCM2711_PM_RSTC_WRCFG_FULL   0x00000020
>>>>>> +#define BCM2711_PM_RSTC_SRCFG    0x00000300
>>>>>> +#define BCM2711_PM_RSTC_QRCFG    0x00003000
>>>>>> +#define BCM2711_PM_RSTC_FRCFG    0x00030000
>>>>>> +#define BCM2711_PM_RSTC_HRCFG    0x00300000
>>>>>> +#define BCM2711_PM_RSTS          (BCM2711_PM_BASE + 0x20)
>>>>>> +#define BCM2711_PM_RSTS_HADDRQ   0x00000001
>>>>>> +#define BCM2711_PM_RSTS_HADDRF   0x00000002
>>>>>> +#define BCM2711_PM_RSTS_HADDRH   0x00000004
>>>>>> +#define BCM2711_PM_RSTS_HADWRQ   0x00000010
>>>>>> +#define BCM2711_PM_RSTS_HADWRF   0x0000002
>>>>>> +#define BCM2711_PM_RSTS_HADWRH   0x00000040
>>>>>> +#define BCM2711_PM_RSTS_HADSRQ   0x00000100
>>>>>> +#define BCM2711_PM_RSTS_HADSRF   0x00000200
>>>>>> +#define BCM2711_PM_RSTS_HADSRH   0x00000400
>>>>>> +#define BCM2711_PM_RSTS_HADPOR   0x00001000
>>>>>> +#define BCM2711_PM_WDOG          (BCM2711_PM_BASE + 0x24)
>>>>>> + * @name AUX Registers
>>>>>> +#define BCM2711_AUX_BASE         (RPI_PERIPHERAL_BASE + 0x215000)
>>>>>> +#define AUX_ENABLES              (BCM2711_AUX_BASE + 0x04)
>>>>>> +#define AUX_MU_IO_REG            (BCM2711_AUX_BASE + 0x40)
>>>>>> +#define AUX_MU_IER_REG           (BCM2711_AUX_BASE + 0x44)
>>>>>> +#define AUX_MU_IIR_REG           (BCM2711_AUX_BASE + 0x48)
>>>>>> +#define AUX_MU_LCR_REG           (BCM2711_AUX_BASE + 0x4C)
>>>>>> +#define AUX_MU_MCR_REG           (BCM2711_AUX_BASE + 0x50)
>>>>>> +#define AUX_MU_LSR_REG           (BCM2711_AUX_BASE + 0x54)
>>>>>> +#define AUX_MU_MSR_REG           (BCM2711_AUX_BASE + 0x58)
>>>>>> +#define AUX_MU_SCRATCH           (BCM2711_AUX_BASE + 0x5C)
>>>>>> +#define AUX_MU_CNTL_REG          (BCM2711_AUX_BASE + 0x60)
>>>>>> +#define AUX_MU_STAT_REG          (BCM2711_AUX_BASE + 0x64)
>>>>>> +#define AUX_MU_BAUD_REG          (BCM2711_AUX_BASE + 0x68)
>>>>>> + * @name GPU Timer Registers
>>>>>> + * NOTE: The GPU uses Compare registers 0 and 2 for
>>>>>> + *       it's own RTOS. 1 and 3 are available for use in
>>>>>> + *       RTEMS.
>>>>>> +#define BCM2711_GPU_TIMER_BASE       (RPI_PERIPHERAL_BASE + 0x3000)
>>>>>> +#define BCM2711_GPU_TIMER_CS         (BCM2711_GPU_TIMER_BASE + 0x00)
>>>>>> +#define BCM2711_GPU_TIMER_CS_M0      0x00000001
>>>>>> +#define BCM2711_GPU_TIMER_CS_M1      0x00000002
>>>>>> +#define BCM2711_GPU_TIMER_CS_M2      0x00000004
>>>>>> +#define BCM2711_GPU_TIMER_CS_M3      0x00000008
>>>>>> +#define BCM2711_GPU_TIMER_CLO        (BCM2711_GPU_TIMER_BASE + 0x04)
>>>>>> +#define BCM2711_GPU_TIMER_CHI        (BCM2711_GPU_TIMER_BASE + 0x08)
>>>>>> +#define BCM2711_GPU_TIMER_C0         (BCM2711_GPU_TIMER_BASE + 0x0C)
>>>>>> +#define BCM2711_GPU_TIMER_C1         (BCM2711_GPU_TIMER_BASE + 0x10)
>>>>>> +#define BCM2711_GPU_TIMER_C2         (BCM2711_GPU_TIMER_BASE + 0x14)
>>>>>> +#define BCM2711_GPU_TIMER_C3         (BCM2711_GPU_TIMER_BASE + 0x18)
>>>>>> + * @name EMMC Registers
>>>>>> + * NOTE: Since the SD controller follows the SDHCI standard,
>>>>>> + *       the rtems-libbsd tree already provides the remaining
>>>>>> registers.
>>>>>> +#define BCM2711_EMMC_BASE           (RPI_PERIPHERAL_BASE + 0x300000)
>>>>>> +* @name Mailbox Registers
>>>>>> +#define BCM2711_MBOX_BASE          (RPI_PERIPHERAL_BASE+0xB880)
>>>>>> +#define BCM2711_MBOX_READ          (BCM2711_MBOX_BASE+0x00)
>>>>>> +#define BCM2711_MBOX_PEEK          (BCM2711_MBOX_BASE+0x10)
>>>>>> +#define BCM2711_MBOX_SENDER        (BCM2711_MBOX_BASE+0x14)
>>>>>> +#define BCM2711_MBOX_STATUS        (BCM2711_MBOX_BASE+0x18)
>>>>>> +#define BCM2711_MBOX_WRITE         (BCM2711_MBOX_BASE+0x20)
>>>>>> +#define BCM2711_MBOX_CONFIG        (BCM2711_MBOX_BASE+0x1C)
>>>>>> +#define BCM2711_MBOX_RESPONSE      0x80000000
>>>>>> +#define BCM2711_MBOX_FULL          0x80000000
>>>>>> +#define BCM2711_MBOX_EMPTY         0x40000000
>>>>>> +* @name Mailbox Channels
>>>>>> +/* Power Manager channel */
>>>>>> +#define BCM2711_MBOX_CHANNEL_PM         0
>>>>>> +/* Framebuffer channel */
>>>>>> +#define BCM2711_MBOX_CHANNEL_FB         1
>>>>>> + /* Virtual UART channel */
>>>>>> +#define BCM2711_MBOX_CHANNEL_VUART      2
>>>>>> + /* VCHIQ channel */
>>>>>> +#define BCM2711_MBOX_CHANNEL_VCHIQ      3
>>>>>> + /* LEDs channel */
>>>>>> +#define BCM2711_MBOX_CHANNEL_LED        4
>>>>>> + /* Button channel */
>>>>>> +#define BCM2711_MBOX_CHANNEL_BUTTON     5
>>>>>> + /* Touch screen channel */
>>>>>> +#define BCM2711_MBOX_CHANNEL_TOUCHS     6
>>>>>> +#define BCM2711_MBOX_CHANNEL_COUNT      7
>>>>>> +/* Property tags (ARM <-> VC) channel */
>>>>>> +#define BCM2711_MBOX_CHANNEL_PROP_AVC   8
>>>>>> + /* Property tags (VC <-> ARM) channel */
>>>>>> +#define BCM2711_MBOX_CHANNEL_PROP_VCA   9
>>>>>> + * @name Raspberry Pi 2 Interrupt Register Defines
>>>>>> +/* Timers interrupt control registers */
>>>>>> +#define BCM2711_CORE0_TIMER_IRQ_CTRL_BASE       0xFF800040
>>>>>> +#define BCM2711_CORE1_TIMER_IRQ_CTRL_BASE       0xFF800044
>>>>>> +#define BCM2711_CORE2_TIMER_IRQ_CTRL_BASE       0xFF800048
>>>>>> +#define BCM2711_CORE3_TIMER_IRQ_CTRL_BASE       0xFF80004C
>>>>>> +#define BCM2711_CORE_TIMER_IRQ_CTRL(cpuidx) \
>>>>>> +  (BCM2711_CORE0_TIMER_IRQ_CTRL_BASE + 0x4 * (cpuidx))
>>>>>> + * @name Raspberry Pi 4 ARM_LOCAL registers
>>>>>> +#define BCM2711_LOCAL_REGS_BASE               0x4C0000000
>>>>>> +#define BCM2711_LOCAL_REGS_SIZE               0x100
>>>>>> +#define BCM2711_LOCAL_ARM_CONTROL
>>>>>>  (BCM2711_LOCAL_REGS_BASE + 0x00)
>>>>>> +#define BCM2711_LOCAL_CORE_IRQ_CONTROL
>>>>>> (BCM2711_LOCAL_REGS_BASE + 0x0c)
>>>>>> +#define BCM2711_LOCAL_PMU_CONTROL_SET
>>>>>>  (BCM2711_LOCAL_REGS_BASE + 0x10)
>>>>>> +#define BCM2711_LOCAL_PMU_CONTROL_CLR
>>>>>>  (BCM2711_LOCAL_REGS_BASE + 0x14)
>>>>>> +#define BCM2711_LOCAL_PERI_IRQ_ROUTE0
>>>>>>  (BCM2711_LOCAL_REGS_BASE + 0x24)
>>>>>> +#define BCM2711_LOCAL_AXI_QUIET_TIME
>>>>>> (BCM2711_LOCAL_REGS_BASE + 0x30)
>>>>>> +#define BCM2711_LOCAL_LOCAL_TIMER_CONTROL
>>>>>>  (BCM2711_LOCAL_REGS_BASE + 0x34)
>>>>>> +#define BCM2711_LOCAL_LOCAL_TIMER_IRQ
>>>>>>  (BCM2711_LOCAL_REGS_BASE + 0x38)
>>>>>> +#define BCM2711_LOCAL_TIMER_CNTRL0
>>>>>> (BCM2711_LOCAL_REGS_BASE + 0x40)
>>>>>> +#define BCM2711_LOCAL_TIMER_CNTRL1
>>>>>> (BCM2711_LOCAL_REGS_BASE + 0x44)
>>>>>> +#define BCM2711_LOCAL_TIMER_CNTRL2
>>>>>> (BCM2711_LOCAL_REGS_BASE + 0x48)
>>>>>> +#define BCM2711_LOCAL_TIMER_CNTRL3
>>>>>> (BCM2711_LOCAL_REGS_BASE + 0x4c)
>>>>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL0
>>>>>> (BCM2711_LOCAL_REGS_BASE + 0x50)
>>>>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL1
>>>>>> (BCM2711_LOCAL_REGS_BASE + 0x54)
>>>>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL2
>>>>>> (BCM2711_LOCAL_REGS_BASE + 0x58)
>>>>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL3
>>>>>> (BCM2711_LOCAL_REGS_BASE + 0x5c)
>>>>>> +#define BCM2711_LOCAL_IRQ_SOURCE0
>>>>>>  (BCM2711_LOCAL_REGS_BASE + 0x60)
>>>>>> +#define BCM2711_LOCAL_IRQ_SOURCE1
>>>>>>  (BCM2711_LOCAL_REGS_BASE + 0x64)
>>>>>> +#define BCM2711_LOCAL_IRQ_SOURCE2
>>>>>>  (BCM2711_LOCAL_REGS_BASE + 0x68)
>>>>>> +#define BCM2711_LOCAL_IRQ_SOURCE3
>>>>>>  (BCM2711_LOCAL_REGS_BASE + 0x6c)
>>>>>> +#define BCM2711_LOCAL_FIQ_SOURCE0
>>>>>>  (BCM2711_LOCAL_REGS_BASE + 0x70)
>>>>>> +#define BCM2711_LOCAL_FIQ_SOURCE1
>>>>>>  (BCM2711_LOCAL_REGS_BASE + 0x74)
>>>>>> +#define BCM2711_LOCAL_FIQ_SOURCE2
>>>>>>  (BCM2711_LOCAL_REGS_BASE + 0x78)
>>>>>> +#define BCM2711_LOCAL_FIQ_SOURCE3
>>>>>>  (BCM2711_LOCAL_REGS_BASE + 0x7c)
>>>>>> + * @name Raspberry Pi 4 Mailbox registers
>>>>>> +#define BCM2711_MAILBOX_00_WRITE_SET_BASE               0x4C000080
>>>>>> +#define BCM2711_MAILBOX_01_WRITE_SET_BASE               0x4C000084
>>>>>> +#define BCM2711_MAILBOX_02_WRITE_SET_BASE               0x4C000088
>>>>>> +#define BCM2711_MAILBOX_03_WRITE_SET_BASE               0x4C00008C
>>>>>> +#define BCM2711_MAILBOX_04_WRITE_SET_BASE               0x4C000090
>>>>>> +#define BCM2711_MAILBOX_05_WRITE_SET_BASE               0x4C000094
>>>>>> +#define BCM2711_MAILBOX_06_WRITE_SET_BASE               0x4C000098
>>>>>> +#define BCM2711_MAILBOX_07_WRITE_SET_BASE               0x4C00009C
>>>>>> +#define BCM2711_MAILBOX_08_WRITE_SET_BASE               0x4C0000A0
>>>>>> +#define BCM2711_MAILBOX_09_WRITE_SET_BASE               0x4C0000A4
>>>>>> +#define BCM2711_MAILBOX_10_WRITE_SET_BASE               0x4C0000A8
>>>>>> +#define BCM2711_MAILBOX_11_WRITE_SET_BASE               0x4C0000AC
>>>>>> +#define BCM2711_MAILBOX_12_WRITE_SET_BASE               0x4C0000B0
>>>>>> +#define BCM2711_MAILBOX_13_WRITE_SET_BASE               0x4C0000B4
>>>>>> +#define BCM2711_MAILBOX_14_WRITE_SET_BASE               0x4C0000B8
>>>>>> +#define BCM2711_MAILBOX_15_WRITE_SET_BASE               0x4C0000BC
>>>>>> +#define BCM2711_MAILBOX_00_READ_CLEAR_BASE              0x4C0000C0
>>>>>> +#define BCM2711_MAILBOX_01_READ_CLEAR_BASE              0x4C0000C4
>>>>>> +#define BCM2711_MAILBOX_02_READ_CLEAR_BASE              0x4C0000C8
>>>>>> +#define BCM2711_MAILBOX_03_READ_CLEAR_BASE              0x4C0000CC
>>>>>> +#define BCM2711_MAILBOX_04_READ_CLEAR_BASE              0x4C0000D0
>>>>>> +#define BCM2711_MAILBOX_05_READ_CLEAR_BASE              0x4C0000D4
>>>>>> +#define BCM2711_MAILBOX_06_READ_CLEAR_BASE              0x4C0000D8
>>>>>> +#define BCM2711_MAILBOX_07_READ_CLEAR_BASE              0x4C0000DC
>>>>>> +#define BCM2711_MAILBOX_08_READ_CLEAR_BASE              0x4C0000E0
>>>>>> +#define BCM2711_MAILBOX_09_READ_CLEAR_BASE              0x4C0000E4
>>>>>> +#define BCM2711_MAILBOX_10_READ_CLEAR_BASE              0x4C0000E8
>>>>>> +#define BCM2711_MAILBOX_11_READ_CLEAR_BASE              0x4C0000EC
>>>>>> +#define BCM2711_MAILBOX_12_READ_CLEAR_BASE              0x4C0000F0
>>>>>> +#define BCM2711_MAILBOX_13_READ_CLEAR_BASE              0x4C0000F4
>>>>>> +#define BCM2711_MAILBOX_14_READ_CLEAR_BASE              0x4C0000F8
>>>>>> +#define BCM2711_MAILBOX_15_READ_CLEAR_BASE              0x4C0000FC
>>>>>> + * @name Raspberry Pi 4 ARM_C FIQ and IRQ registers
>>>>>> +#define BCM2711_ARMC_REGS_BASE                 (RPI_PERIPHERAL_BASE
>>>>>> + 0xB200)
>>>>>> +#define BCM2711_ARMC_REGS_SIZE                 0x200
>>>>>> +#define BCM2711_ARMC_IRQ0_PENDING0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x00)
>>>>>> +#define BCM2711_ARMC_IRQ0_PENDING1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x04)
>>>>>> +#define BCM2711_ARMC_IRQ0_PENDING2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x08)
>>>>>> +#define BCM2711_ARMC_IRQ0_SET_EN_0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x10)
>>>>>> +#define BCM2711_ARMC_IRQ0_SET_EN_1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x14)
>>>>>> +#define BCM2711_ARMC_IRQ0_SET_EN_2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x18)
>>>>>> +#define BCM2711_ARMC_IRQ0_CLR_EN_0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x20)
>>>>>> +#define BCM2711_ARMC_IRQ0_CLR_EN_1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x24)
>>>>>> +#define BCM2711_ARMC_IRQ0_CLR_EN_2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x28)
>>>>>> +#define BCM2711_ARMC_IRQ_STATUS0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x30)
>>>>>> +#define BCM2711_ARMC_IRQ_STATUS1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x34)
>>>>>> +#define BCM2711_ARMC_IRQ_STATUS2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x38)
>>>>>> +#define BCM2711_ARMC_IRQ1_PENDING0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x40)
>>>>>> +#define BCM2711_ARMC_IRQ1_PENDING1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x44)
>>>>>> +#define BCM2711_ARMC_IRQ1_PENDING2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x48)
>>>>>> +#define BCM2711_ARMC_IRQ1_SET_EN_0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x50)
>>>>>> +#define BCM2711_ARMC_IRQ1_SET_EN_1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x54)
>>>>>> +#define BCM2711_ARMC_IRQ1_SET_EN_2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x58)
>>>>>> +#define BCM2711_ARMC_IRQ1_CLR_EN_0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x60)
>>>>>> +#define BCM2711_ARMC_IRQ1_CLR_EN_1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x64)
>>>>>> +#define BCM2711_ARMC_IRQ1_CLR_EN_2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x68)
>>>>>> +#define BCM2711_ARMC_IRQ2_PENDING0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x80)
>>>>>> +#define BCM2711_ARMC_IRQ2_PENDING1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x84)
>>>>>> +#define BCM2711_ARMC_IRQ2_PENDING2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x88)
>>>>>> +#define BCM2711_ARMC_IRQ2_SET_EN_0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x90)
>>>>>> +#define BCM2711_ARMC_IRQ2_SET_EN_1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x94)
>>>>>> +#define BCM2711_ARMC_IRQ2_SET_EN_2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x98)
>>>>>> +#define BCM2711_ARMC_IRQ2_CLR_EN_0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0xA0)
>>>>>> +#define BCM2711_ARMC_IRQ2_CLR_EN_1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0xA4)
>>>>>> +#define BCM2711_ARMC_IRQ2_CLR_EN_2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0xA8)
>>>>>> +#define BCM2711_ARMC_IRQ3_PENDING0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0xC0)
>>>>>> +#define BCM2711_ARMC_IRQ3_PENDING1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0xC4)
>>>>>> +#define BCM2711_ARMC_IRQ3_PENDING2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0xC8)
>>>>>> +#define BCM2711_ARMC_IRQ3_SET_EN_0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0xD0)
>>>>>> +#define BCM2711_ARMC_IRQ3_SET_EN_1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0xD4)
>>>>>> +#define BCM2711_ARMC_IRQ3_SET_EN_2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0xD8)
>>>>>> +#define BCM2711_ARMC_IRQ3_CLR_EN_0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0xE0)
>>>>>> +#define BCM2711_ARMC_IRQ3_CLR_EN_1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0xE4)
>>>>>> +#define BCM2711_ARMC_IRQ3_CLR_EN_2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0xE8)
>>>>>> +#define BCM2711_ARMC_FIQ0_PENDING0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x100)
>>>>>> +#define BCM2711_ARMC_FIQ0_PENDING1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x104)
>>>>>> +#define BCM2711_ARMC_FIQ0_PENDING2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x108)
>>>>>> +#define BCM2711_ARMC_FIQ0_SET_EN_0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x110)
>>>>>> +#define BCM2711_ARMC_FIQ0_SET_EN_1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x114)
>>>>>> +#define BCM2711_ARMC_FIQ0_SET_EN_2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x118)
>>>>>> +#define BCM2711_ARMC_FIQ0_CLR_EN_0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x120)
>>>>>> +#define BCM2711_ARMC_FIQ0_CLR_EN_1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x124)
>>>>>> +#define BCM2711_ARMC_FIQ0_CLR_EN_2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x128)
>>>>>> +#define BCM2711_ARMC_FIQ1_PENDING0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x140)
>>>>>> +#define BCM2711_ARMC_FIQ1_PENDING1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x144)
>>>>>> +#define BCM2711_ARMC_FIQ1_PENDING2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x148)
>>>>>> +#define BCM2711_ARMC_FIQ1_SET_EN_0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x150)
>>>>>> +#define BCM2711_ARMC_FIQ1_SET_EN_1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x154)
>>>>>> +#define BCM2711_ARMC_FIQ1_SET_EN_2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x158)
>>>>>> +#define BCM2711_ARMC_FIQ1_CLR_EN_0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x160)
>>>>>> +#define BCM2711_ARMC_FIQ1_CLR_EN_1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x164)
>>>>>> +#define BCM2711_ARMC_FIQ1_CLR_EN_2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x168)
>>>>>> +#define BCM2711_ARMC_FIQ2_PENDING0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x180)
>>>>>> +#define BCM2711_ARMC_FIQ2_PENDING1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x184)
>>>>>> +#define BCM2711_ARMC_FIQ2_PENDING2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x188)
>>>>>> +#define BCM2711_ARMC_FIQ2_SET_EN_0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x190)
>>>>>> +#define BCM2711_ARMC_FIQ2_SET_EN_1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x194)
>>>>>> +#define BCM2711_ARMC_FIQ2_SET_EN_2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x198)
>>>>>> +#define BCM2711_ARMC_FIQ2_CLR_EN_0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x1A0)
>>>>>> +#define BCM2711_ARMC_FIQ2_CLR_EN_1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x1A4)
>>>>>> +#define BCM2711_ARMC_FIQ2_CLR_EN_2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x1A8)
>>>>>> +#define BCM2711_ARMC_FIQ3_PENDING0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x1C0)
>>>>>> +#define BCM2711_ARMC_FIQ3_PENDING1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x1C4)
>>>>>> +#define BCM2711_ARMC_FIQ3_PENDING2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x1C8)
>>>>>> +#define BCM2711_ARMC_FIQ3_SET_EN_0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x1D0)
>>>>>> +#define BCM2711_ARMC_FIQ3_SET_EN_1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x1D4)
>>>>>> +#define BCM2711_ARMC_FIQ3_SET_EN_2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x1D8)
>>>>>> +#define BCM2711_ARMC_FIQ3_CLR_EN_0
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x1E0)
>>>>>> +#define BCM2711_ARMC_FIQ3_CLR_EN_1
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x1E4)
>>>>>> +#define BCM2711_ARMC_FIQ3_CLR_EN_2
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x1E8)
>>>>>> +#define BCM2711_ARMC_SWIRQ_SET
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x1F0)
>>>>>> +#define BCM2711_ARMC_SWIRQ_CLEAR
>>>>>>  (BCM2711_ARMC_REGS_BASE + 0x1F4)
>>>>>> +#endif /* LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H */
>>>>>> diff --git a/bsps/aarch64/raspberrypi/include/tm27.h
>>>>>> b/bsps/aarch64/raspberrypi/include/tm27.h
>>>>>> index 0000000000..653f88ed01
>>>>>> --- /dev/null
>>>>>> +++ b/bsps/aarch64/raspberrypi/include/tm27.h
>>>>>> @@ -0,0 +1,46 @@
>>>>>> + * @file
>>>>>> + * @brief BSP tm27 header
>>>>>> + * are met:
>>>>>> copyright
>>>>>> in the
>>>>>> distribution.
>>>>>> TO, THE
>>>>>> PARTICULAR PURPOSE
>>>>>> CONTRIBUTORS BE
>>>>>> OR
>>>>>> OF
>>>>>> BUSINESS
>>>>>> WHETHER IN
>>>>>> OTHERWISE)
>>>>>> ADVISED OF THE
>>>>>> +#ifndef _RTEMS_TMTEST27
>>>>>> +#error "This is an RTEMS internal file you must not include
>>>>>> directly."
>>>>>> +#endif
>>>>>> +#ifndef __tm27_h
>>>>>> +#define __tm27_h
>>>>>> +#include <dev/irq/arm-gic-tm27.h>
>>>>>> +#endif /* __tm27_h */
>>>>>> \ No newline at end of file
>>>>>> diff --git a/bsps/aarch64/raspberrypi/start/bspstart.c
>>>>>> b/bsps/aarch64/raspberrypi/start/bspstart.c
>>>>>> index 0000000000..56f52a2231
>>>>>> --- /dev/null
>>>>>> +++ b/bsps/aarch64/raspberrypi/start/bspstart.c
>>>>>> @@ -0,0 +1,49 @@
>>>>>> + * @file
>>>>>> + * @brief BSP Startup
>>>>>> + * are met:
>>>>>> copyright
>>>>>> in the
>>>>>> distribution.
>>>>>> TO, THE
>>>>>> PARTICULAR PURPOSE
>>>>>> CONTRIBUTORS BE
>>>>>> OR
>>>>>> OF
>>>>>> BUSINESS
>>>>>> WHETHER IN
>>>>>> OTHERWISE)
>>>>>> ADVISED OF THE
>>>>>> +#include <bsp.h>
>>>>>> +#include <bsp/bootcard.h>
>>>>>> +#include <bsp/irq-generic.h>
>>>>>> +#include <bsp/linker-symbols.h>
>>>>>> +void bsp_start( void )
>>>>>> +  bsp_interrupt_initialize();
>>>>>> +  rtems_cache_coherent_add_area(
>>>>>> +    bsp_section_nocacheheap_begin,
>>>>>> +    (uintptr_t) bsp_section_nocacheheap_size
>>>>>> diff --git a/bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>>>>> b/bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>>>>> index 0000000000..fe0fe77c09
>>>>>> --- /dev/null
>>>>>> +++ b/bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>>>>> @@ -0,0 +1,53 @@
>>>>>> + * @file
>>>>>> + * @brief BSP Startup Hooks
>>>>>> + * are met:
>>>>>> copyright
>>>>>> in the
>>>>>> distribution.
>>>>>> TO, THE
>>>>>> PARTICULAR PURPOSE
>>>>>> CONTRIBUTORS BE
>>>>>> OR
>>>>>> OF
>>>>>> BUSINESS
>>>>>> WHETHER IN
>>>>>> OTHERWISE)
>>>>>> ADVISED OF THE
>>>>>> +#include <bsp.h>
>>>>>> +#include <rtems/score/cpu.h>
>>>>>> +BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
>>>>>> +  /* Do nothing */
>>>>>> +BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
>>>>>> +  AArch64_start_set_vector_base();
>>>>>> +  bsp_start_copy_sections();
>>>>>> +  raspberrypi_4_setup_mmu_and_cache();
>>>>>> +  bsp_start_clear_bss();
>>>>>> diff --git a/bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>>>>> b/bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>>>>> index 0000000000..ab12020a2a
>>>>>> --- /dev/null
>>>>>> +++ b/bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>>>>> @@ -0,0 +1,84 @@
>>>>>> + * @file
>>>>>> + * @brief This source file contains the default MMU tables and setup.
>>>>>> + * are met:
>>>>>> copyright
>>>>>> in the
>>>>>> distribution.
>>>>>> TO, THE
>>>>>> PARTICULAR PURPOSE
>>>>>> CONTRIBUTORS BE
>>>>>> OR
>>>>>> OF
>>>>>> BUSINESS
>>>>>> WHETHER IN
>>>>>> OTHERWISE)
>>>>>> ADVISED OF THE
>>>>>> +#include <bsp.h>
>>>>>> +#include <bsp/aarch64-mmu.h>
>>>>>> +#include <bsp/raspberrypi.h>
>>>>>> +#include <libcpu/mmu-vmsav8-64.h>
>>>>>> +BSP_START_DATA_SECTION static const aarch64_mmu_config_entry
>>>>>> +raspberrypi_4_mmu_config_table[] = {
>>>>>> +  AARCH64_MMU_DEFAULT_SECTIONS,
>>>>>> +  { /* RPI peripheral address */
>>>>>> +    .begin = (unsigned)RPI_PERIPHERAL_BASE,
>>>>>> +    .end = (unsigned)RPI_PERIPHERAL_BASE +
>>>>>> (unsigned)RPI_PERIPHERAL_SIZE,
>>>>>> +    .flags = AARCH64_MMU_DEVICE
>>>>>> +  { /* RPI ARM local registers */
>>>>>> +    .begin = (unsigned)BCM2711_LOCAL_REGS_BASE,
>>>>>> +    .end = (unsigned)BCM2711_LOCAL_REGS_BASE +
>>>>>> (unsigned)BCM2711_LOCAL_REGS_SIZE,
>>>>>> +  { /* RPI GIC Interface address */
>>>>>> +    .begin = 0xFF800000U,
>>>>>> +    .end = 0xFFA00000U,
>>>>>> + * Make weak and let the user override.
>>>>>> +raspberrypi_4_setup_mmu_and_cache( void ) __attribute__ ((weak));
>>>>>> +  aarch64_mmu_setup();
>>>>>> +  aarch64_mmu_setup_translation_table(
>>>>>> +    &raspberrypi_4_mmu_config_table[ 0 ],
>>>>>> +    RTEMS_ARRAY_SIZE( raspberrypi_4_mmu_config_table )
>>>>>> +  aarch64_mmu_enable();
>>>>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/abi.yml
>>>>>> b/spec/build/bsps/aarch64/raspberrypi/abi.yml
>>>>>> index 0000000000..5e3e0a4975
>>>>>> --- /dev/null
>>>>>> +++ b/spec/build/bsps/aarch64/raspberrypi/abi.yml
>>>>>> @@ -0,0 +1,21 @@
>>>>>> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>>>>>> +actions:
>>>>>> +- get-string: null
>>>>>> +- split: null
>>>>>> +- env-append: null
>>>>>> +build-type: option
>>>>>> +copyrights:
>>>>>> +- Copyright (C) 2022 Mohd Noor Aman
>>>>>> +default:
>>>>>> +- -mcpu=cortex-a72
>>>>>> +- -march=armv8-a
>>>>>> +default-by-variant: []
>>>>>> +includes: []
>>>>>> +description: |
>>>>>> +  ABI flags
>>>>>> +links: []
>>>>>> +enabled-by: true
>>>>>> +name: ABI_FLAGS
>>>>>> +type: build
>>>>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>>>>> b/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>>>>> index 0000000000..d2ff76d351
>>>>>> --- /dev/null
>>>>>> +++ b/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>>>>> @@ -0,0 +1,81 @@
>>>>>> +arch: aarch64
>>>>>> +bsp: raspberrypi4b
>>>>>> +build-type: bsp
>>>>>> +cflags: []
>>>>>> +copyrights:
>>>>>> +cppflags: []
>>>>>> +enabled-by: true
>>>>>> +family: raspberrypi
>>>>>> +includes: []
>>>>>> +install:
>>>>>> +- destination: ${BSP_INCLUDEDIR}
>>>>>> +  source:
>>>>>> +  - bsps/aarch64/raspberrypi/include/bsp.h
>>>>>> +  - bsps/aarch64/raspberrypi/include/tm27.h
>>>>>> +- destination: ${BSP_INCLUDEDIR}/bsp
>>>>>> +  source:
>>>>>> +  - bsps/aarch64/raspberrypi/include/bsp/irq.h
>>>>>> +  - bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>>>> +source:
>>>>>> +- bsps/aarch64/raspberrypi/console/console.c
>>>>>> +- bsps/aarch64/raspberrypi/start/bspstart.c
>>>>>> +- bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>>>>> +- bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>>>>> +- bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
>>>>>> +- bsps/aarch64/shared/cache/cache.c
>>>>>> +- bsps/aarch64/shared/mmu/vmsav8-64.c
>>>>>> +- bsps/shared/dev/clock/arm-generic-timer.c
>>>>>> +- bsps/shared/dev/irq/arm-gicv2.c
>>>>>> +- bsps/shared/dev/irq/arm-gicv2-get-attributes.c
>>>>>> +- bsps/shared/dev/serial/console-termios-init.c
>>>>>> +- bsps/shared/dev/serial/console-termios.c
>>>>>> +- bsps/shared/dev/serial/arm-pl011.c
>>>>>> +- bsps/shared/dev/getentropy/getentropy-cpucounter.c
>>>>>> +- bsps/shared/dev/btimer/btimer-cpucounter.c
>>>>>> +- bsps/shared/irq/irq-default-handler.c
>>>>>> +- bsps/shared/irq/irq-handler-install.c
>>>>>> +- bsps/shared/irq/irq-generic.c
>>>>>> +- bsps/shared/irq/irq-lock.c
>>>>>> +- bsps/shared/start/bspfatal-default.c
>>>>>> +- bsps/shared/start/bspreset-arm-psci.c
>>>>>> +- bsps/shared/start/gettargethash-default.c
>>>>>> +- bsps/shared/start/sbrk.c
>>>>>> +- bsps/shared/start/wkspaceinitone.c
>>>>>> +- bsps/shared/start/mallocinitmulti.c
>>>>>> +- bsps/shared/start/bspgetworkarea-default.c
>>>>>> +links:
>>>>>> +- role: build-dependency
>>>>>> +  uid: ../grp
>>>>>> +  uid: ../start
>>>>>> +  uid: ../optmmupages
>>>>>> +  uid: ../optgtusevirt
>>>>>> +  uid: ../optgtuseps
>>>>>> +  uid: abi
>>>>>> +  uid: ../../optcachedata
>>>>>> +  uid: ../../optcacheinst
>>>>>> +  uid: ../../opto2
>>>>>> +  uid: ../../bspopts
>>>>>> +  uid: linkercmds
>>>>>> +  uid: ../../obj
>>>>>> +  uid: ../../objirq
>>>>>> +type: build
>>>>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>>>>> b/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>>>>> index 0000000000..8598b89cba
>>>>>> --- /dev/null
>>>>>> +++ b/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>>>>> @@ -0,0 +1,76 @@
>>>>>> +build-type: config-file
>>>>>> +content: |
>>>>>> +  /* SPDX-License-Identifier: BSD-2-Clause */
>>>>>> without
>>>>>> conditions
>>>>>> +   * are met:
>>>>>> copyright
>>>>>> copyright
>>>>>> in the
>>>>>> distribution.
>>>>>> LIMITED TO, THE
>>>>>> PARTICULAR PURPOSE
>>>>>> CONTRIBUTORS BE
>>>>>> EXEMPLARY, OR
>>>>>> PROCUREMENT OF
>>>>>> BUSINESS
>>>>>> WHETHER IN
>>>>>> OTHERWISE)
>>>>>> ADVISED OF THE
>>>>>> +  MEMORY {
>>>>>> +  RAM_MMU  : ORIGIN = 0x0, LENGTH = (0x1000 *
>>>>>> ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
>>>>>> +  RAM      : ORIGIN = 0x80000, LENGTH = 1024M
>>>>>> +  REGION_ALIAS ("REGION_START",          RAM);
>>>>>> +  REGION_ALIAS ("REGION_VECTOR",         RAM);
>>>>>> +  REGION_ALIAS ("REGION_TEXT",           RAM);
>>>>>> +  REGION_ALIAS ("REGION_TEXT_LOAD",      RAM);
>>>>>> +  REGION_ALIAS ("REGION_RODATA",         RAM);
>>>>>> +  REGION_ALIAS ("REGION_RODATA_LOAD",    RAM);
>>>>>> +  REGION_ALIAS ("REGION_DATA",           RAM);
>>>>>> +  REGION_ALIAS ("REGION_DATA_LOAD",      RAM);
>>>>>> +  REGION_ALIAS ("REGION_FAST_TEXT",      RAM);
>>>>>> +  REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
>>>>>> +  REGION_ALIAS ("REGION_FAST_DATA",      RAM);
>>>>>> +  REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
>>>>>> +  REGION_ALIAS ("REGION_BSS",            RAM);
>>>>>> +  REGION_ALIAS ("REGION_WORK",           RAM);
>>>>>> +  REGION_ALIAS ("REGION_STACK",          RAM);
>>>>>> +  REGION_ALIAS ("REGION_NOCACHE",        RAM);
>>>>>> +  REGION_ALIAS ("REGION_NOCACHE_LOAD",   RAM);
>>>>>> +  bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ?
>>>>>> bsp_stack_abt_size : 1024;
>>>>>> +  bsp_section_rwbarrier_align = DEFINED
>>>>>> (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
>>>>>> +  bsp_stack_exception_size = DEFINED (bsp_stack_exception_size) ?
>>>>>> bsp_stack_exception_size : 1024;
>>>>>> +  bsp_vector_table_in_start_section = 1;
>>>>>> +  bsp_translation_table_base = ORIGIN (RAM_MMU);
>>>>>> +  bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
>>>>>> +  OUTPUT_FORMAT ("elf64-littleaarch64")
>>>>>> +  OUTPUT_ARCH (aarch64)
>>>>>> +  INCLUDE linkcmds.base
>>>>>> +copyrights:
>>>>>> +enabled-by: true
>>>>>> +install-path: ${BSP_LIBDIR}
>>>>>> +links: []
>>>>>> +target: linkcmds
>>>>>> +type: build
>>>>>> 2.37.3
>>>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>> devel mailing list
>>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221004/ae54d556/attachment-0001.htm>
