[PATCH 06/13] config: Add rtems_malloc_task_stack_for_idle()
Chris Johns
chrisj at rtems.org
Fri Oct 7 02:57:02 UTC 2022
On 6/10/2022 6:35 pm, Sebastian Huber wrote:
> On 06/10/2022 00:13, Chris Johns wrote:
>> Will the IDLE TLS size be based on the
>> CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE if it is not zero? This effects
>> libdl once it supports loading TLS based code.
> Currently, only the actual TLS size is used. We would have to change
> _TLS_Get_allocation_size() to use the maximum if it is non-zero.
It would be good to get this sorted and in before a push is made on libdl to
support TLS. I think the newlib change will make TLS a visible issue in libdl in
6 so it needs to be fixed.
