[PATCH 06/13] config: Add rtems_malloc_task_stack_for_idle()
Fri Oct 7 04:25:56 UTC 2022
On 07.10.22 04:57, Chris Johns wrote:
> On 6/10/2022 6:35 pm, Sebastian Huber wrote:
>> On 06/10/2022 00:13, Chris Johns wrote:
>>> Will the IDLE TLS size be based on the
>>> CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE if it is not zero? This effects
>>> libdl once it supports loading TLS based code.
>> Currently, only the actual TLS size is used. We would have to change
>> _TLS_Get_allocation_size() to use the maximum if it is non-zero.
> It would be good to get this sorted and in before a push is made on libdl to
> support TLS. I think the newlib change will make TLS a visible issue in libdl in
> 6 so it needs to be fixed.
I checked _TLS_Get_allocation_size(). It already returns the maximum
size if it is configured:
     if ( _Thread_Maximum_TLS_size != 0 ) {
       if ( allocation_size <= _Thread_Maximum_TLS_size ) {
         _Assert( _Thread_Maximum_TLS_size % CPU_STACK_ALIGNMENT == 0 );
         allocation_size = _Thread_Maximum_TLS_size;
       } else {
         _Internal_error( INTERNAL_ERROR_TOO_LARGE_TLS_SIZE );
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
